    Measurment text in black area
    24 Posts 5 Posters 4.9k Views 5 Watching
      I don't see it in 2015.
        I see it in v2015.
          I wonder why I don't have any issue on my machine with this.
            Charlie__V
            @tig said:
            I see it in v2015.
            +1
            Camera set to Parallel Projection....default views (top/front/right..etc) gives expected results.
            Perspective views not so much.
            Charlie
            SUv15
            MS Win7 64 Bit
              kaas
              maybe its due to different gfx cards / gfx card settings / OS versions / ...?
                Charlie__V
                Could still be Print Driver........I am using Adobe Acrobat ProXI.
                Charlie
                  Charlie
                  So maybe the issue is more with print drivers? I don't have a printer connected to my PC and the default "printer" is set as One Note.
                    I get it when using PDF995, which I think uses some 'ghostscript' arcanery...
                      Charlie__V
                      Charlie
                      My WAG......Printing w/HLR yields a partially vector based file....no? (lines are vector...& text appears to be raster....to me anyway)
                      I tested this using windows XPS writer.......which I am pretty sure saves as a .jpg or similar image file. (all raster)
                      I do not have any other print driver installed to test further.
                      Charlie
                      PS:
                      XPS Writer does not black out the text.
                      MS_XPS_Writer_HLR
                        Charlie__V
                        Just following up........I looked to the Trimble SU........Knowledge center.......(search) HLR.
                        As I suspected.......the HLR print (output) option is vector based output.
                        So...somewhere......somehow.....the black dimension boxes are cause/effect of......??
                        SU dimension text fails to convert/display as vector?
                        User "success" in printing to HLR (w/o blacked out dimension text) .....most likely does not contain any vector based attributes. (IOW: print driver is really printing as .jpg/or other "image" file)
                        I do not have an answer/solution.......but to say the HLR print option......when used with a vector capable print driver.......will unfortunately create the blacked out text/dims. as depicted above.
                        Best,
                        C
                        Trimble_SU_Print_To_HLR
                        • 2 / 2
