    Measurment text in black area
    24 Posts 5 Posters 5.9k Views 5 Watching
    • K
      kaas
      just for testing: have you tried a different pdf-printer like bullzip? Also, the object behind the text wouldn't have opacity applied to it? If so, did you try different opacity settings in the style?
        I can print HLR PDFs using PDF995, without any graphic glitches...
        So it is probably either an issue with your PDF-maker or a Graphics Card issue ?
        • robertWanR
          robertWan
          I've noticed that it only happens with measurements which are aligned to dimension line.
          Robert
            Yes !
            A break through...
            I too confirm that only if the dim-text is 'aligned', then the HLR PDF shows a black rectangle.
            Without the HLR setting they all print OK !
            • robertWanR
              robertWan
              So it is a bug? In SU2014 same.
              How is it in SU2015?
              Robert
                I don't see it in 2015.
                  I see it in v2015.
                    I wonder why I don't have any issue on my machine with this.
                    • C
                      Charlie__V
                      @tig said:
                      I see it in v2015.
                      +1
                      Camera set to Parallel Projection....default views (top/front/right..etc) gives expected results.
                      Perspective views not so much.
                      Charlie
                      SUv15
                      MS Win7 64 Bit
                      • K
                        kaas
                        maybe its due to different gfx cards / gfx card settings / OS versions / ...?
                        • C
                          Charlie__V
                          Could still be Print Driver........I am using Adobe Acrobat ProXI.
                          Charlie
                            Charlie
                            So maybe the issue is more with print drivers? I don't have a printer connected to my PC and the default "printer" is set as One Note.
                              I get it when using PDF995, which I think uses some 'ghostscript' arcanery...
                              • C
                                Charlie__V
                                Charlie
                                My WAG......Printing w/HLR yields a partially vector based file....no? (lines are vector...& text appears to be raster....to me anyway)
                                I tested this using windows XPS writer.......which I am pretty sure saves as a .jpg or similar image file. (all raster)
                                I do not have any other print driver installed to test further.
                                Charlie
                                PS:
                                XPS Writer does not black out the text.
                                MS_XPS_Writer_HLR
                                • C
                                  Charlie__V
                                  Just following up........I looked to the Trimble SU........Knowledge center.......(search) HLR.
                                  As I suspected.......the HLR print (output) option is vector based output.
                                  So...somewhere......somehow.....the black dimension boxes are cause/effect of......??
                                  SU dimension text fails to convert/display as vector?
                                  User "success" in printing to HLR (w/o blacked out dimension text) .....most likely does not contain any vector based attributes. (IOW: print driver is really printing as .jpg/or other "image" file)
                                  I do not have an answer/solution.......but to say the HLR print option......when used with a vector capable print driver.......will unfortunately create the blacked out text/dims. as depicted above.
                                  Best,
                                  C
                                  Trimble_SU_Print_To_HLR
