    Measurment text in black area
    24 Posts 5 Posters 5.9k Views 5 Watching
      Sketchup menu > Window > Preferences > OpenGL ...
      • robertWanR
        robertWan
        Of course, I changed OpenGL in SU. No effects.
        Robert
          Did you try turning off Hardware Acceleration?
          • robertWanR
            robertWan
            Yes. All combinations.
            Robert
            • K
              kaas
              just for testing: have you tried a different pdf-printer like bullzip? Also, the object behind the text wouldn't have opacity applied to it? If so, did you try different opacity settings in the style?
                I can print HLR PDFs using PDF995, without any graphic glitches...
                So it is probably either an issue with your PDF-maker or a Graphics Card issue ?
                • robertWanR
                  robertWan
                  I've noticed that it only happens with measurements which are aligned to dimension line.
                  Robert
                    Yes !
                    A break through...
                    I too confirm that only if the dim-text is 'aligned', then the HLR PDF shows a black rectangle.
                    Without the HLR setting they all print OK !
                    • robertWanR
                      robertWan
                      So it is a bug? In SU2014 same.
                      How is it in SU2015?
                      Robert
                        I don't see it in 2015.
                          I see it in v2015.
                            I wonder why I don't have any issue on my machine with this.
                            • C
                              Charlie__V
                              @tig said:
                              I see it in v2015.
                              +1
                              Camera set to Parallel Projection....default views (top/front/right..etc) gives expected results.
                              Perspective views not so much.
                              Charlie
                              SUv15
                              MS Win7 64 Bit
                              • K
                                kaas
                                maybe its due to different gfx cards / gfx card settings / OS versions / ...?
                                • C
                                  Charlie__V
                                  Could still be Print Driver........I am using Adobe Acrobat ProXI.
                                  Charlie
                                    Charlie
                                    So maybe the issue is more with print drivers? I don't have a printer connected to my PC and the default "printer" is set as One Note.
                                      I get it when using PDF995, which I think uses some 'ghostscript' arcanery...
                                      • C
                                        Charlie__V
                                        Charlie
                                        My WAG......Printing w/HLR yields a partially vector based file....no? (lines are vector...& text appears to be raster....to me anyway)
                                        I tested this using windows XPS writer.......which I am pretty sure saves as a .jpg or similar image file. (all raster)
                                        I do not have any other print driver installed to test further.
                                        Charlie
                                        PS:
                                        XPS Writer does not black out the text.
                                        MS_XPS_Writer_HLR
                                        • C
                                          Charlie__V
                                          Just following up........I looked to the Trimble SU........Knowledge center.......(search) HLR.
                                          As I suspected.......the HLR print (output) option is vector based output.
                                          So...somewhere......somehow.....the black dimension boxes are cause/effect of......??
                                          SU dimension text fails to convert/display as vector?
                                          User "success" in printing to HLR (w/o blacked out dimension text) .....most likely does not contain any vector based attributes. (IOW: print driver is really printing as .jpg/or other "image" file)
                                          I do not have an answer/solution.......but to say the HLR print option......when used with a vector capable print driver.......will unfortunately create the blacked out text/dims. as depicted above.
                                          Best,
                                          C
                                          Trimble_SU_Print_To_HLR
