    Measurment text in black area
    24 Posts 5 Posters 5.9k Views 5 Watching
    • robertWanR
      robertWan
      Yes. All combinations.
      Robert
      • K
        kaas
        just for testing: have you tried a different pdf-printer like bullzip? Also, the object behind the text wouldn't have opacity applied to it? If so, did you try different opacity settings in the style?
          I can print HLR PDFs using PDF995, without any graphic glitches...
          So it is probably either an issue with your PDF-maker or a Graphics Card issue ?
          • robertWanR
            robertWan
            I've noticed that it only happens with measurements which are aligned to dimension line.
            Robert
              Yes !
              A break through...
              I too confirm that only if the dim-text is 'aligned', then the HLR PDF shows a black rectangle.
              Without the HLR setting they all print OK !
              • robertWanR
                robertWan
                So it is a bug? In SU2014 same.
                How is it in SU2015?
                Robert
                  I don't see it in 2015.
                    I see it in v2015.
                      I wonder why I don't have any issue on my machine with this.
                      • C
                        Charlie__V
                        @tig said:
                        I see it in v2015.
                        +1
                        Camera set to Parallel Projection....default views (top/front/right..etc) gives expected results.
                        Perspective views not so much.
                        Charlie
                        SUv15
                        MS Win7 64 Bit
                        • K
                          kaas
                          maybe its due to different gfx cards / gfx card settings / OS versions / ...?
                          • C
                            Charlie__V
                            Could still be Print Driver........I am using Adobe Acrobat ProXI.
                            Charlie
                              Charlie
                              So maybe the issue is more with print drivers? I don't have a printer connected to my PC and the default "printer" is set as One Note.
                                I get it when using PDF995, which I think uses some 'ghostscript' arcanery...
                                • C
                                  Charlie__V
                                  Charlie
                                  My WAG......Printing w/HLR yields a partially vector based file....no? (lines are vector...& text appears to be raster....to me anyway)
                                  I tested this using windows XPS writer.......which I am pretty sure saves as a .jpg or similar image file. (all raster)
                                  I do not have any other print driver installed to test further.
                                  Charlie
                                  PS:
                                  XPS Writer does not black out the text.
                                  MS_XPS_Writer_HLR
                                  • C
                                    Charlie__V
                                    Just following up........I looked to the Trimble SU........Knowledge center.......(search) HLR.
                                    As I suspected.......the HLR print (output) option is vector based output.
                                    So...somewhere......somehow.....the black dimension boxes are cause/effect of......??
                                    SU dimension text fails to convert/display as vector?
                                    User "success" in printing to HLR (w/o blacked out dimension text) .....most likely does not contain any vector based attributes. (IOW: print driver is really printing as .jpg/or other "image" file)
                                    I do not have an answer/solution.......but to say the HLR print option......when used with a vector capable print driver.......will unfortunately create the blacked out text/dims. as depicted above.
                                    Best,
                                    C
                                    Trimble_SU_Print_To_HLR
