    [Plugin] ToolbarEditor (1.1.2) – updated 08.06.2014
    122 Posts 40 Posters 62.3k Views 40 Watching
      danb
      Hello, could anyone help. I used this plugin with 2013 but it does not seem to work with 2014. I find it very useful, particularly as I use a mac and you can't stack the toolbars as you do on windows
      many thanks
      Dan
      Macbook Pro
      OSX 10.9
      Sketchup Pro 2014
      Sketchup Pro 2019/20
      OSX 10.15.3
      Macbook Pro
      • BoxB Offline
        It throws a load error in SU2014
          Aerilius
          If you are curious, you can have a sneak-peak on the next version 1.1.0 with custom buttons. You will be able to create your own toolbar buttons for Ruby one-liners, code snippets or other things found on the forum.
          fixed LoadError
            Aerilius
            Thanks, I fixed the load error.
              BUT you haven't published it πŸ˜’
              • BoxB Offline
                It's on the previous page Tig, not the first post. It's a teaser/beta and the fix worked for me.
                  So the version in that mid-thread post has been updated - it was not clear... πŸ˜•
                  • F Offline
                    function
                    I've noticed that this plugin takes a fairly long time to load all the icons at startup. Is there any other negative affects to performance?
                      Aerilius
                      It has an arbitrary timeout of five seconds. It's not doing much processing, it just needs to be sure that SketchUp has finished loading all other plugins. I wish SketchUp had (or will have) a proper API method for that. When I come back I'll see if it still works reliably wirh a shorter timeout.
                      • F Offline
                        function
                        its kind of strange for me. i have something like 4 tool bars, they load one icon at a time, and then on the 5th toolbar i made it loads all 6 instantly .. :🀷:
                          Aerilius
                          I updated the plugin. It now includes custom buttons.
                          http://sketchucation.com/pluginrepo/image/ae_ToolbarEditor/screenshot2b.png
                          • Rich O BrienR Online
                            Incredible.
                            • KrisidiousK Offline
                              Krisidious
                              I can haz all thomthoms in a toolbar?
                              By: Kristoff Rand
                                Ben Ritter
                                Thank you for sharing this with us.
                                  Krisidious
                                  does this mean it's time for the Icon Making Challenge?
                                  By: Kristoff Rand
                                    LewisEE
                                    I can't enter code for custom (new) buttons using SketchUp Make 2014. Other wise this is a great extension. Thanks
                                      driven
                                      how did miss this one, very nice...
                                      just pondering some additional behaviour...
                                      I regularly 'bury' plugins that I use infrequently, but add the tools main icon to a toolbar and use that to 'load' the plugin only when I need it, I tend to do it for plugins that add observers, skp's or materials to my model.
                                      I try to do it on my own plugins as well so the 'command' is the loader...
                                      example
                                            command2 = UI;;Command.new("Add mac batch Icons"){ load( File.join(File.dirname(__FILE__), "Add_icon_logic_batch_skps.rb") ) }
                                      could the 'burying' be an option for this plugin?
                                      so if I add a complex plugin to a toolbar it is moved into a 'Toolbar 1' folder and only a single icon is added to the 'Toolbar 1' toolbar, but if I click on that 'Icon' 'Toolbar 1' is replace by a second 'Toolbar1' that includes any additional toolset buttons at exactly the same position...
                                      I'll see if I can find my simple 2 tool test file, that may clarify what I mean...
                                      • alsomarA Offline
                                        alsomar Extension Creator
                                        Thank you so much Aerilius!
                                        It could be nice to export custom toolbars to a *.dat file to get the same toolbars in other computers. Is there any way to do anything like that?
                                        Greetings!
                                        Alejandro Soriano Visuals Β· All my links
                                          Aerilius
                                          The toolbars are stored in the registry
                                          HKEY_CURRENT_USER\Software\SketchUp\SketchUp 2014\Plugins_ae\ToolbarEditor.
                                          You can copy and paste it in the same key on another SketchUp installation or version. You can also use the File β†’ Export functionality of the registry. I'm not sure whether I should add an export button to each of my plugins, I hope SketchUp will provide an efficient and central place to migrate settings.
                                          From a developer side, I want to emphasis again that most of us want plugin settings to be namespaced and bundled in one sub-key, and not mixed within SketchUp's internal keys.
                                          • alsomarA Offline
                                            Thank you for your response! Greetings! πŸ˜„
                                            • 4 / 7
