    [Plugin] ToolbarEditor (1.1.2) – updated 08.06.2014
    122 Posts 40 Posters 71.9k Views 40 Watching
    • Bob JamesB Offline
      Bob James
      @cadfather said:
      1 - which one?
      Generically so I could modify it for any command
      @cadfather said:
      2 - click on the icon and drag it slowly on the right panel
      Thank you
      @cadfather said:
      3 - click on the minus sign - top right of your toolbar header
      duh 😳
        Aerilius
        As in the API documentation… http://www.sketchup.com/intl/en/developer/docs/ourdoc/command.php
        cmd = UI;;Command.new("name of the command"){
          AuthorModule;;PluginName.name_of_the_main_method()
        cmd.tooltip = "tooltip that describes the command"
        cmd.status_bar_text = "text that tells how to use the command"
        cmd.large_icon = "./path/to/a/icon24px.png"
        cmd.small_icon = "./path/to/a/icon16px.png"
        It still can only be used with understanding of what it does, and you would have to look up how a certain plugin is started.
        It would probably be sufficient and much easier to edit the plugin's own ruby file, look for "UI::Command.new" and add the icons. The icon path can either be relative to the ruby file or absolute (to the system's root, ie. "C:/" on Windows).
        Some plugins add themself only to the menu without creating a command. That looks like this:
        UI.menu("plugins").add_item("name of the command"){ name_of_the_method }
        and can be replaced by a command object (as above) plus
        UI.menu("plugins").add_item(cmd)
          danb
          Hello, could anyone help. I used this plugin with 2013 but it does not seem to work with 2014. I find it very useful, particularly as I use a mac and you can't stack the toolbars as you do on windows
          many thanks
          Dan
          Macbook Pro
          OSX 10.9
          Sketchup Pro 2014
          Sketchup Pro 2019/20
          OSX 10.15.3
          Macbook Pro
          • BoxB Offline
            It throws a load error in SU2014
              Aerilius
              If you are curious, you can have a sneak-peak on the next version 1.1.0 with custom buttons. You will be able to create your own toolbar buttons for Ruby one-liners, code snippets or other things found on the forum.
              fixed LoadError
                Aerilius
                Thanks, I fixed the load error.
                  BUT you haven't published it 😒
                  • BoxB Offline
                    It's on the previous page Tig, not the first post. It's a teaser/beta and the fix worked for me.
                      So the version in that mid-thread post has been updated - it was not clear... 😕
                      • F Offline
                        function
                        I've noticed that this plugin takes a fairly long time to load all the icons at startup. Is there any other negative affects to performance?
                          Aerilius
                          It has an arbitrary timeout of five seconds. It's not doing much processing, it just needs to be sure that SketchUp has finished loading all other plugins. I wish SketchUp had (or will have) a proper API method for that. When I come back I'll see if it still works reliably wirh a shorter timeout.
                          • F Offline
                            function
                            its kind of strange for me. i have something like 4 tool bars, they load one icon at a time, and then on the 5th toolbar i made it loads all 6 instantly .. :🤷:
                              Aerilius
                              I updated the plugin. It now includes custom buttons.
                              http://sketchucation.com/pluginrepo/image/ae_ToolbarEditor/screenshot2b.png
                                Incredible.
                                • KrisidiousK Offline
                                  Krisidious
                                  I can haz all thomthoms in a toolbar?
                                  By: Kristoff Rand
                                    Ben Ritter
                                    Thank you for sharing this with us.
                                      Krisidious
                                      does this mean it's time for the Icon Making Challenge?
                                      By: Kristoff Rand
                                        LewisEE
                                        I can't enter code for custom (new) buttons using SketchUp Make 2014. Other wise this is a great extension. Thanks
                                          driven
                                          how did miss this one, very nice...
                                          just pondering some additional behaviour...
                                          I regularly 'bury' plugins that I use infrequently, but add the tools main icon to a toolbar and use that to 'load' the plugin only when I need it, I tend to do it for plugins that add observers, skp's or materials to my model.
                                          I try to do it on my own plugins as well so the 'command' is the loader...
                                          example
                                                command2 = UI;;Command.new("Add mac batch Icons"){ load( File.join(File.dirname(__FILE__), "Add_icon_logic_batch_skps.rb") ) }
                                          could the 'burying' be an option for this plugin?
                                          so if I add a complex plugin to a toolbar it is moved into a 'Toolbar 1' folder and only a single icon is added to the 'Toolbar 1' toolbar, but if I click on that 'Icon' 'Toolbar 1' is replace by a second 'Toolbar1' that includes any additional toolset buttons at exactly the same position...
                                          I'll see if I can find my simple 2 tool test file, that may clarify what I mean...
                                          • alsomarA Offline
                                            alsomar Extension Creator
                                            Thank you so much Aerilius!
                                            It could be nice to export custom toolbars to a *.dat file to get the same toolbars in other computers. Is there any way to do anything like that?
                                            Greetings!
                                            Alejandro Soriano Visuals · All my links
                                            • 4 / 7
