    [Plugin] ToolbarEditor (1.1.2) – updated 08.06.2014
    122 Posts 40 Posters 70.2k Views 40 Watching
    • ely862meE Offline
      ely862me
      What about these ones ?
      After choosing yes I get this :
      Elisei (sketchupper)
      Come and See EliseiDesign
        Aerilius
        Are you sure you use the latest version?
        • ely862meE Offline
          ely862me
          I installed it from the scf plugin store and I thought it was the last version but it was not, now it works !
          Thank you !
            Andreas updated this toolset twice on the same day, so the second version was not automatically picked up... v1.0.6 will be added to the 'SketchUcation Plugin Store' shortly...
              Andreas, here's a nice idea that I liked. That in addition to customize toolbar one could paste a snippet for a completely new command: http://sketchucation.com/forums/viewtopic.php?f=15&t=52454&p=475992#p475990
              This would be a great tool. You think this tool can be tweaked for that?
              • Bob JamesB Offline
                Bob James
                1. Can someone write a sample ruby script to make an icon for a native command that has no icon so I can use it to add the icon to a toolbar made with ToolbarEditor?
                2. How do you delete an icon in a toolbar made with ToolbarEditor?
                3. How do you delete a toolbar made with ToolbarEditor?
                • CadFatherC Offline
                  CadFather
                  1 - which one?
                  2 - click on the icon and drag it slowly on the right panel
                  3 - click on the minus sign - top right of your toolbar header
                    Bob James
                    @cadfather said:
                    1 - which one?
                    Generically so I could modify it for any command
                    Thank you
                    duh 😳
                      Aerilius
                      As in the API documentation… http://www.sketchup.com/intl/en/developer/docs/ourdoc/command.php
                      cmd = UI;;Command.new("name of the command"){
                        AuthorModule;;PluginName.name_of_the_main_method()
                      cmd.tooltip = "tooltip that describes the command"
                      cmd.status_bar_text = "text that tells how to use the command"
                      cmd.large_icon = "./path/to/a/icon24px.png"
                      cmd.small_icon = "./path/to/a/icon16px.png"
                      It still can only be used with understanding of what it does, and you would have to look up how a certain plugin is started.
                      It would probably be sufficient and much easier to edit the plugin's own ruby file, look for "UI::Command.new" and add the icons. The icon path can either be relative to the ruby file or absolute (to the system's root, ie. "C:/" on Windows).
                      Some plugins add themself only to the menu without creating a command. That looks like this:
                      UI.menu("plugins").add_item("name of the command"){ name_of_the_method }
                      and can be replaced by a command object (as above) plus
                      UI.menu("plugins").add_item(cmd)
                        danb
                        Hello, could anyone help. I used this plugin with 2013 but it does not seem to work with 2014. I find it very useful, particularly as I use a mac and you can't stack the toolbars as you do on windows
                        many thanks
                        Dan
                        Macbook Pro
                        OSX 10.9
                        Sketchup Pro 2014
                        Sketchup Pro 2019/20
                        OSX 10.15.3
                        Macbook Pro
                        • BoxB Offline
                          It throws a load error in SU2014
                            Aerilius
                            If you are curious, you can have a sneak-peak on the next version 1.1.0 with custom buttons. You will be able to create your own toolbar buttons for Ruby one-liners, code snippets or other things found on the forum.
                            fixed LoadError
                              Aerilius
                              Thanks, I fixed the load error.
                                BUT you haven't published it 😒
                                • BoxB Offline
                                  It's on the previous page Tig, not the first post. It's a teaser/beta and the fix worked for me.
                                    So the version in that mid-thread post has been updated - it was not clear... 😕
                                    • F Offline
                                      function
                                      I've noticed that this plugin takes a fairly long time to load all the icons at startup. Is there any other negative affects to performance?
                                        Aerilius
                                        It has an arbitrary timeout of five seconds. It's not doing much processing, it just needs to be sure that SketchUp has finished loading all other plugins. I wish SketchUp had (or will have) a proper API method for that. When I come back I'll see if it still works reliably wirh a shorter timeout.
                                        • F Offline
                                          function
                                          its kind of strange for me. i have something like 4 tool bars, they load one icon at a time, and then on the 5th toolbar i made it loads all 6 instantly .. :🤷:
                                            Aerilius
                                            I updated the plugin. It now includes custom buttons.
                                            http://sketchucation.com/pluginrepo/image/ae_ToolbarEditor/screenshot2b.png
                                            • 3 / 7
