    [Plugin] ToolbarEditor (1.1.2) – updated 08.06.2014
    122 Posts 40 Posters 72.2k Views 40 Watching
    • BoxB Offline
      It's on the previous page Tig, not the first post. It's a teaser/beta and the fix worked for me.
        So the version in that mid-thread post has been updated - it was not clear... 😕
        • F Offline
          function
          I've noticed that this plugin takes a fairly long time to load all the icons at startup. Is there any other negative affects to performance?
            Aerilius
            It has an arbitrary timeout of five seconds. It's not doing much processing, it just needs to be sure that SketchUp has finished loading all other plugins. I wish SketchUp had (or will have) a proper API method for that. When I come back I'll see if it still works reliably wirh a shorter timeout.
            • F Offline
              function
              its kind of strange for me. i have something like 4 tool bars, they load one icon at a time, and then on the 5th toolbar i made it loads all 6 instantly .. :🤷:
                Aerilius
                I updated the plugin. It now includes custom buttons.
                http://sketchucation.com/pluginrepo/image/ae_ToolbarEditor/screenshot2b.png
                  Incredible.
                  • KrisidiousK Offline
                    Krisidious
                    I can haz all thomthoms in a toolbar?
                    By: Kristoff Rand
                      Ben Ritter
                      Thank you for sharing this with us.
                        Krisidious
                        does this mean it's time for the Icon Making Challenge?
                        By: Kristoff Rand
                          LewisEE
                          I can't enter code for custom (new) buttons using SketchUp Make 2014. Other wise this is a great extension. Thanks
                            driven
                            how did miss this one, very nice...
                            just pondering some additional behaviour...
                            I regularly 'bury' plugins that I use infrequently, but add the tools main icon to a toolbar and use that to 'load' the plugin only when I need it, I tend to do it for plugins that add observers, skp's or materials to my model.
                            I try to do it on my own plugins as well so the 'command' is the loader...
                            example
                                  command2 = UI;;Command.new("Add mac batch Icons"){ load( File.join(File.dirname(__FILE__), "Add_icon_logic_batch_skps.rb") ) }
                            could the 'burying' be an option for this plugin?
                            so if I add a complex plugin to a toolbar it is moved into a 'Toolbar 1' folder and only a single icon is added to the 'Toolbar 1' toolbar, but if I click on that 'Icon' 'Toolbar 1' is replace by a second 'Toolbar1' that includes any additional toolset buttons at exactly the same position...
                            I'll see if I can find my simple 2 tool test file, that may clarify what I mean...
                            • alsomarA Offline
                              alsomar Extension Creator
                              Thank you so much Aerilius!
                              It could be nice to export custom toolbars to a *.dat file to get the same toolbars in other computers. Is there any way to do anything like that?
                              Greetings!
                              Alejandro Soriano Visuals · All my links
                                Aerilius
                                The toolbars are stored in the registry
                                HKEY_CURRENT_USER\Software\SketchUp\SketchUp 2014\Plugins_ae\ToolbarEditor.
                                You can copy and paste it in the same key on another SketchUp installation or version. You can also use the File → Export functionality of the registry. I'm not sure whether I should add an export button to each of my plugins, I hope SketchUp will provide an efficient and central place to migrate settings.
                                From a developer side, I want to emphasis again that most of us want plugin settings to be namespaced and bundled in one sub-key, and not mixed within SketchUp's internal keys.
                                • alsomarA Offline
                                  Thank you for your response! Greetings! 😄
                                    Lushi
                                    i would love this tool could create groups of nested buttons, like those in the bar "getting started"
                                    http://sketchucation.com/images/news/sketchup-2014-review/sketchup-2014-review-007.png
                                      Aerilius
                                      I would love this too!
                                      But they are neither user-editable nor available for plugins.
                                        glro
                                        i can't enter snippets either
                                        su8, win7
                                          Aerilius
                                          What happens when you can't enter snippets? What do you do and what does not happen?
                                            glro
                                            nothing happens...
                                            after i fill in the form (name, category, ...), and i choose a file for the icon, it is then impossible for me to type anything in the area below the icon file address
                                            • 4 / 7
