    [Plugin] ToolbarEditor (1.1.2) – updated 08.06.2014
    122 Posts 40 Posters 76.1k Views 40 Watching
    • F Offline
      function
      its kind of strange for me. i have something like 4 tool bars, they load one icon at a time, and then on the 5th toolbar i made it loads all 6 instantly .. :🤷:
        Aerilius
        I updated the plugin. It now includes custom buttons.
        http://sketchucation.com/pluginrepo/image/ae_ToolbarEditor/screenshot2b.png
        • Rich O BrienR Online
          Incredible.
          • KrisidiousK Offline
            Krisidious
            I can haz all thomthoms in a toolbar?
            By: Kristoff Rand
              Ben Ritter
              Thank you for sharing this with us.
                Krisidious
                does this mean it's time for the Icon Making Challenge?
                By: Kristoff Rand
                  LewisEE
                  I can't enter code for custom (new) buttons using SketchUp Make 2014. Other wise this is a great extension. Thanks
                    driven
                    how did miss this one, very nice...
                    just pondering some additional behaviour...
                    I regularly 'bury' plugins that I use infrequently, but add the tools main icon to a toolbar and use that to 'load' the plugin only when I need it, I tend to do it for plugins that add observers, skp's or materials to my model.
                    I try to do it on my own plugins as well so the 'command' is the loader...
                    example
                          command2 = UI;;Command.new("Add mac batch Icons"){ load( File.join(File.dirname(__FILE__), "Add_icon_logic_batch_skps.rb") ) }
                    could the 'burying' be an option for this plugin?
                    so if I add a complex plugin to a toolbar it is moved into a 'Toolbar 1' folder and only a single icon is added to the 'Toolbar 1' toolbar, but if I click on that 'Icon' 'Toolbar 1' is replace by a second 'Toolbar1' that includes any additional toolset buttons at exactly the same position...
                    I'll see if I can find my simple 2 tool test file, that may clarify what I mean...
                    • alsomarA Offline
                      alsomar Extension Creator
                      Thank you so much Aerilius!
                      It could be nice to export custom toolbars to a *.dat file to get the same toolbars in other computers. Is there any way to do anything like that?
                      Greetings!
                      Alejandro Soriano Visuals · All my links
                        Aerilius
                        The toolbars are stored in the registry
                        HKEY_CURRENT_USER\Software\SketchUp\SketchUp 2014\Plugins_ae\ToolbarEditor.
                        You can copy and paste it in the same key on another SketchUp installation or version. You can also use the File → Export functionality of the registry. I'm not sure whether I should add an export button to each of my plugins, I hope SketchUp will provide an efficient and central place to migrate settings.
                        From a developer side, I want to emphasis again that most of us want plugin settings to be namespaced and bundled in one sub-key, and not mixed within SketchUp's internal keys.
                        • alsomarA Offline
                          Thank you for your response! Greetings! 😄
                            Lushi
                            i would love this tool could create groups of nested buttons, like those in the bar "getting started"
                            http://sketchucation.com/images/news/sketchup-2014-review/sketchup-2014-review-007.png
                              Aerilius
                              I would love this too!
                              But they are neither user-editable nor available for plugins.
                                glro
                                i can't enter snippets either
                                su8, win7
                                  Aerilius
                                  What happens when you can't enter snippets? What do you do and what does not happen?
                                    glro
                                    nothing happens...
                                    after i fill in the form (name, category, ...), and i choose a file for the icon, it is then impossible for me to type anything in the area below the icon file address
                                      Aerilius
                                      I cannot reproduce this. For me the webdialog accepts input in all input fields in SU 2014, SU 2013, SU8, WinXP, Win7.
                                      • What version of Internet Explorer do you have installed?
                                      • Does the text area for Ruby code never accept input or only after you selected an icon?
                                      • Can you see that it is a text area (or is it possible that it just has a zero size)?
                                        glro
                                        internet explorer 11
                                        never accepts input
                                        cannot see that it is a text area (screen copy added)add a button window
                                        hope it helps
                                          Jim
                                          Same here - no input area for code.
                                          Win 8.1, SU-2014 Pro, IE 11 (never used outside of SketchUp.)
                                            titou
                                            me too, same problem, cannot whrite anything in the text zone
                                            • 4 / 7
