    [Plugin] ToolbarEditor (1.1.2) – updated 08.06.2014
    122 Posts 40 Posters 79.2k Views 40 Watching
      Aerilius
      If you are curious, you can have a sneak-peak on the next version 1.1.0 with custom buttons. You will be able to create your own toolbar buttons for Ruby one-liners, code snippets or other things found on the forum.
      fixed LoadError
        Aerilius
        Thanks, I fixed the load error.
          BUT you haven't published it 😒
          • BoxB
            It's on the previous page Tig, not the first post. It's a teaser/beta and the fix worked for me.
              So the version in that mid-thread post has been updated - it was not clear... 😕
              • F
                function
                I've noticed that this plugin takes a fairly long time to load all the icons at startup. Is there any other negative affects to performance?
                  Aerilius
                  It has an arbitrary timeout of five seconds. It's not doing much processing, it just needs to be sure that SketchUp has finished loading all other plugins. I wish SketchUp had (or will have) a proper API method for that. When I come back I'll see if it still works reliably wirh a shorter timeout.
                  • F
                    function
                    its kind of strange for me. i have something like 4 tool bars, they load one icon at a time, and then on the 5th toolbar i made it loads all 6 instantly .. :🤷:
                      Aerilius
                      I updated the plugin. It now includes custom buttons.
                      http://sketchucation.com/pluginrepo/image/ae_ToolbarEditor/screenshot2b.png
                        Incredible.
                        • KrisidiousK
                          Krisidious
                          I can haz all thomthoms in a toolbar?
                          By: Kristoff Rand
                          • B
                            Ben Ritter
                            Thank you for sharing this with us.
                            • KrisidiousK
                              Krisidious
                              does this mean it's time for the Icon Making Challenge?
                              By: Kristoff Rand
                              • L
                                LewisEE
                                I can't enter code for custom (new) buttons using SketchUp Make 2014. Other wise this is a great extension. Thanks
                                  driven
                                  how did miss this one, very nice...
                                  just pondering some additional behaviour...
                                  I regularly 'bury' plugins that I use infrequently, but add the tools main icon to a toolbar and use that to 'load' the plugin only when I need it, I tend to do it for plugins that add observers, skp's or materials to my model.
                                  I try to do it on my own plugins as well so the 'command' is the loader...
                                  example
                                        command2 = UI;;Command.new("Add mac batch Icons"){ load( File.join(File.dirname(__FILE__), "Add_icon_logic_batch_skps.rb") ) }
                                  could the 'burying' be an option for this plugin?
                                  so if I add a complex plugin to a toolbar it is moved into a 'Toolbar 1' folder and only a single icon is added to the 'Toolbar 1' toolbar, but if I click on that 'Icon' 'Toolbar 1' is replace by a second 'Toolbar1' that includes any additional toolset buttons at exactly the same position...
                                  I'll see if I can find my simple 2 tool test file, that may clarify what I mean...
                                  • alsomarA
                                    alsomar Extension Creator
                                    Thank you so much Aerilius!
                                    It could be nice to export custom toolbars to a *.dat file to get the same toolbars in other computers. Is there any way to do anything like that?
                                    Greetings!
                                    Alejandro Soriano Visuals · All my links
                                      Aerilius
                                      The toolbars are stored in the registry
                                      HKEY_CURRENT_USER\Software\SketchUp\SketchUp 2014\Plugins_ae\ToolbarEditor.
                                      You can copy and paste it in the same key on another SketchUp installation or version. You can also use the File → Export functionality of the registry. I'm not sure whether I should add an export button to each of my plugins, I hope SketchUp will provide an efficient and central place to migrate settings.
                                      From a developer side, I want to emphasis again that most of us want plugin settings to be namespaced and bundled in one sub-key, and not mixed within SketchUp's internal keys.
                                      • alsomarA
                                        Thank you for your response! Greetings! 😄
                                        • L
                                          Lushi
                                          i would love this tool could create groups of nested buttons, like those in the bar "getting started"
                                          http://sketchucation.com/images/news/sketchup-2014-review/sketchup-2014-review-007.png
                                            Aerilius
                                            I would love this too!
                                            But they are neither user-editable nor available for plugins.
                                            • 4 / 7
