    [Plugin][$] Vertex Tools
    667 Posts 92 Posters 608.7k Views 92 Watching
    • plot-parisP Offline
      plot-paris
      man, thats genius! exactly what I was looking for!!!
      and the trick of pressing a shortcut twice to exit the tool.... fantastic ๐Ÿ˜ฒ
        I think I should make a video on setting up those. Because I don't think many people knows about them.
          I didn't know this....
          Do you have to have Vert mode avtivated to set it?
          I've have Vert Tools set to Alt + V and the tools to Alt + M, S, R etc....
            Nope! Just reassign the shortcuts you have for the native Move, Roate, Scale and Select to Tools/Vertex Tools/Move etc.
            See screenshot on this page: http://www.thomthom.net/software/vertex_tools/manual/shortcuts
            An annoying limitation with SketchUp though, if you try to reassign Ctrl+A, Ctrl+T for Select All and Select None then it works only during that session. When you restart they are reverted. ๐Ÿ˜ž
              @Thomthom not TT_SU
              Is it possible that VT could respect CPoints?
              • tt_suT Offline
                tt_su
                Adding to wish-list. Will take a look at it.
                  Add these too...
                  Edge Slide
                  Vertex Move parallel to view direction. Without gizmo
                  Vertex Extrude
                  Quad Face Fill
                  Will i stop?
                  • cottyC Offline
                    cotty
                    @rich o brien said:
                    Vertex Extrude
                    You know vertex move + CTRL?
                    my SketchUp gallery
                    • charly2008C Offline
                      charly2008
                      I do not know what I'm doing wrong. For me smoothing doesn't work although the function is checked. I thank you in advance for any help.
                      Charly
                        It is working. Turn off hidden geometry and you will see all the faces have 4 edges.
                        • tt_suT Offline
                          tt_su
                          I assume you mean the soft selection? When you have the Select tool activated, enter a radius in the VCB.
                            charly2008
                            Hi Thomas,
                            Yes that was what I meant. Thanks for the hint.
                              If any OSX Mavericks users tried to register Vertex Tools recently and failed to do so there is a fix released (1.1.7) that takes care of the issue.
                              • cottyC Offline
                                cotty
                                I've tried to create a simple star with vertex scaling (see screencast), but it's getting unsymmetrical, any ideas?
                                my SketchUp gallery
                                  Did you try Shift + Blue scale?
                                  Sent from my iPad
                                  • BoxB Offline
                                    It works if you use a 10 sided circle rather than a polygon.
                                    • cottyC Offline
                                      cotty
                                      Yes, it's the same.
                                      Same behaviour for polygon, circle, exploded edges, ...
                                      I think the reason is the not centered position of the gizmo (with every second vertex selected):
                                      my SketchUp gallery
                                        Yes, that's because the center of the five selected vertices isn't the center of the polygon.
                                        You can right-click the Gizmo > Gizmo > Align Custom and then set the position of the gizmo. Note that it works like the Align Axis tool, so you must pick center point and then the X and Y axes.
                                        You can then scale and get your start. Note that after scaling the gizmo re-centers itself.
                                        • panixiaP Offline
                                          panixia
                                          align gizmo to custom ๐Ÿ˜‰
                                          edit: didn't see page 13 of this post ๐Ÿ˜ณ
                                          ๐Ÿ˜†
                                          • xiombargX Offline
                                            xiombarg
                                            I know Vertex Tools has been around for a little while but I only recently downloaded the trial version and I just have to say that this plugin finally fills in such a huge hole that Sketchup has been missing in advanced modelling tools and techniques. I only wish I had noticed it before. I was especially STOKED with the scale tool implementation that not only aligns vertices to a single axis, but that we can finally get rid of artifact lines by scaling a plane to absolute zero. Ya-freakin-hoo, it's about time.
                                            Also love the extrude edge and merge vertex options. Beautiful man.
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 33
                                            • 34
                                            • 18 / 34
