    [Plugin][$] Vertex Tools
    667 Posts 92 Posters 608.7k Views 92 Watching
      It is working. Turn off hidden geometry and you will see all the faces have 4 edges.
      • tt_suT Offline
        tt_su
        I assume you mean the soft selection? When you have the Select tool activated, enter a radius in the VCB.
        • charly2008C Offline
          charly2008
          Hi Thomas,
          Yes that was what I meant. Thanks for the hint.
            If any OSX Mavericks users tried to register Vertex Tools recently and failed to do so there is a fix released (1.1.7) that takes care of the issue.
            • cottyC Offline
              cotty
              I've tried to create a simple star with vertex scaling (see screencast), but it's getting unsymmetrical, any ideas?
              my SketchUp gallery
                Did you try Shift + Blue scale?
                Sent from my iPad
                • BoxB Offline
                  It works if you use a 10 sided circle rather than a polygon.
                  • cottyC Offline
                    cotty
                    Yes, it's the same.
                    Same behaviour for polygon, circle, exploded edges, ...
                    I think the reason is the not centered position of the gizmo (with every second vertex selected):
                    my SketchUp gallery
                      Yes, that's because the center of the five selected vertices isn't the center of the polygon.
                      You can right-click the Gizmo > Gizmo > Align Custom and then set the position of the gizmo. Note that it works like the Align Axis tool, so you must pick center point and then the X and Y axes.
                      You can then scale and get your start. Note that after scaling the gizmo re-centers itself.
                      • panixiaP Offline
                        panixia
                        align gizmo to custom πŸ˜‰
                        edit: didn't see page 13 of this post 😳
                        πŸ˜†
                        • xiombargX Offline
                          xiombarg
                          I know Vertex Tools has been around for a little while but I only recently downloaded the trial version and I just have to say that this plugin finally fills in such a huge hole that Sketchup has been missing in advanced modelling tools and techniques. I only wish I had noticed it before. I was especially STOKED with the scale tool implementation that not only aligns vertices to a single axis, but that we can finally get rid of artifact lines by scaling a plane to absolute zero. Ya-freakin-hoo, it's about time.
                          Also love the extrude edge and merge vertex options. Beautiful man.
                            HAppy you like it! πŸ˜„
                              @xiombarg said:
                              ...this plugin finally fills in such a huge hole that Sketchup has been missing in advanced modelling tools and techniques....
                              nice testimonial/endorsement πŸ‘
                              • BoxB Offline
                                I was just trolling through the thread and noticed a number of times you asked for action shots of the tool in use. Here's a quick doodle I did the other day for fun.
                                Fantastic tool, couldn't live without it.
                                • pbacotP Offline
                                  Very nice work Box! And a great subject for VT capabilities. Did you subd as well? Other tools?
                                    KrisM
                                    My question is certainly not as interesting as the above post but here goes -
                                    I have need on occasion to introduce a flat area into a terrain. I can move individual vertices but this can sometimes be a lot of work. The planar tool makes a flat surface but not a horizontal surface. What I want to do is select a number of vertices and set them all to the same z elevation. The stamp tool does this somewhat but introduces a bunch of new vertices to do this (unless you create a very exact stamp surface). This option seems like this might be fairly straightforward to incorporate. Any possibilities with this request? Or perhaps there is already a tool around which does what I want. I've looked but haven't found it.
                                    Kris
                                    • BoxB Offline
                                      Pbacot I used a few tools, but mostly VT. A tiny bit of Artisan for sub and smooth mainly because the button is right there. And a bit of poly reduce to keep things under control.
                                      But generally speaking I usually make a blob using either curviloft or Extude tools, this way you can control the structure of vertex' quite well. Then I just use the gizmo to push pull and scale until it looks like what I want. I'm pretty haphazard and free form with it, wouldn't want to have to copy anything this way.
                                      The image shows how I would start, first with a block cut to rough shape then those edges used to create quadfaced forms that I explode and join then start to work with.
                                      • BoxB Offline
                                        Krism, do you have Artisan, another wonderful tool.
                                        It has a make planer tool that you can specify, Best, XY, YZ or XZ.
                                          KrisM
                                          Box, Thanks for that. Yes, I do have Artisan but have not sufficiently explored it's options. I will do that now.
                                          Kris
                                            tspco
                                            I just started using the trial, not sure if I am doing something right. I grab terrains from the file>geolocation, mainly because they look much better than anything I can create.
                                            What I need to do is take an area and make it flat for placing buildings on. I tried make planer on a rectangle of vertices, I an not sure it did what I thought it should do, am I misunderstanding the tool?
                                            SU make 2017, /Twilight Render Hobby
                                            Windows 10,64 bit,16GB ram, quad core Athlon 3.6 gHz proc. Anything else you want to know, ask me.
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 33
                                            • 34
                                            • 19 / 34
