    [Plugin][$] Vertex Tools
    667 Posts 92 Posters 483.3k Views 92 Watching
      @plot-paris said:
      The VertexTools Plugin has a Select, Move, Rotate and Scale tool of its own. But when I make a soft selection and then hit lets say "E" for the Rotate Tool, I will activate SketchUp's Rotate Tool, hence exiting the plugin.
      Instead I would like the plugin to intercept this keyboard shortcut, that usually activates SketchUp's Rotate Tool, and enable VertexTools' own Rotate Tool instead.
      Proxy commands for the rescue!
      http://www.thomthom.net/software/vertex_tools/manual/shortcuts#proxy_functions
      • plot-parisP Offline
        plot-paris
        man, thats genius! exactly what I was looking for!!!
        and the trick of pressing a shortcut twice to exit the tool.... fantastic 😲
          I think I should make a video on setting up those. Because I don't think many people knows about them.
            I didn't know this....
            Do you have to have Vert mode avtivated to set it?
            I've have Vert Tools set to Alt + V and the tools to Alt + M, S, R etc....
              Nope! Just reassign the shortcuts you have for the native Move, Roate, Scale and Select to Tools/Vertex Tools/Move etc.
              See screenshot on this page: http://www.thomthom.net/software/vertex_tools/manual/shortcuts
              An annoying limitation with SketchUp though, if you try to reassign Ctrl+A, Ctrl+T for Select All and Select None then it works only during that session. When you restart they are reverted. 😞
                @Thomthom not TT_SU
                Is it possible that VT could respect CPoints?
                • tt_suT Offline
                  tt_su
                  Adding to wish-list. Will take a look at it.
                    Add these too...
                    Edge Slide
                    Vertex Move parallel to view direction. Without gizmo
                    Vertex Extrude
                    Quad Face Fill
                    Will i stop?
                    • cottyC Offline
                      cotty
                      @rich o brien said:
                      Vertex Extrude
                      You know vertex move + CTRL?
                      my SketchUp gallery
                      • charly2008C Offline
                        charly2008
                        I do not know what I'm doing wrong. For me smoothing doesn't work although the function is checked. I thank you in advance for any help.
                        Charly
                          It is working. Turn off hidden geometry and you will see all the faces have 4 edges.
                          • tt_suT Offline
                            tt_su
                            I assume you mean the soft selection? When you have the Select tool activated, enter a radius in the VCB.
                              charly2008
                              Hi Thomas,
                              Yes that was what I meant. Thanks for the hint.
                                If any OSX Mavericks users tried to register Vertex Tools recently and failed to do so there is a fix released (1.1.7) that takes care of the issue.
                                • cottyC Offline
                                  cotty
                                  I've tried to create a simple star with vertex scaling (see screencast), but it's getting unsymmetrical, any ideas?
                                  my SketchUp gallery
                                    Did you try Shift + Blue scale?
                                    Sent from my iPad
                                    • BoxB Offline
                                      It works if you use a 10 sided circle rather than a polygon.
                                      • cottyC Offline
                                        cotty
                                        Yes, it's the same.
                                        Same behaviour for polygon, circle, exploded edges, ...
                                        I think the reason is the not centered position of the gizmo (with every second vertex selected):
                                        my SketchUp gallery
                                          Yes, that's because the center of the five selected vertices isn't the center of the polygon.
                                          You can right-click the Gizmo > Gizmo > Align Custom and then set the position of the gizmo. Note that it works like the Align Axis tool, so you must pick center point and then the X and Y axes.
                                          You can then scale and get your start. Note that after scaling the gizmo re-centers itself.
                                          • panixiaP Offline
                                            panixia
                                            align gizmo to custom πŸ˜‰
                                            edit: didn't see page 13 of this post 😳
                                            πŸ˜†
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 33
                                            • 34
                                            • 18 / 34
