    [Plugin][$] Vertex Tools
    667 Posts 92 Posters 655.8k Views 92 Watching
      @rich o brien said:
      Do you have to have Vert mode avtivated to set it?
      Nope! Just reassign the shortcuts you have for the native Move, Roate, Scale and Select to Tools/Vertex Tools/Move etc.
      See screenshot on this page: http://www.thomthom.net/software/vertex_tools/manual/shortcuts
      An annoying limitation with SketchUp though, if you try to reassign Ctrl+A, Ctrl+T for Select All and Select None then it works only during that session. When you restart they are reverted. 😞
        @Thomthom not TT_SU
        Is it possible that VT could respect CPoints?
        • tt_suT
          tt_su
          Adding to wish-list. Will take a look at it.
            Add these too...
            Edge Slide
            Vertex Move parallel to view direction. Without gizmo
            Vertex Extrude
            Quad Face Fill
            Will i stop?
            • cottyC
              cotty
              @rich o brien said:
              Vertex Extrude
              You know vertex move + CTRL?
              my SketchUp gallery
              • charly2008C
                charly2008
                I do not know what I'm doing wrong. For me smoothing doesn't work although the function is checked. I thank you in advance for any help.
                Charly
                  It is working. Turn off hidden geometry and you will see all the faces have 4 edges.
                  • tt_suT
                    tt_su
                    I assume you mean the soft selection? When you have the Select tool activated, enter a radius in the VCB.
                    • charly2008C
                      charly2008
                      Hi Thomas,
                      Yes that was what I meant. Thanks for the hint.
                        If any OSX Mavericks users tried to register Vertex Tools recently and failed to do so there is a fix released (1.1.7) that takes care of the issue.
                        • cottyC
                          cotty
                          I've tried to create a simple star with vertex scaling (see screencast), but it's getting unsymmetrical, any ideas?
                          my SketchUp gallery
                            Did you try Shift + Blue scale?
                            Sent from my iPad
                            • BoxB
                              It works if you use a 10 sided circle rather than a polygon.
                              • cottyC
                                cotty
                                Yes, it's the same.
                                Same behaviour for polygon, circle, exploded edges, ...
                                I think the reason is the not centered position of the gizmo (with every second vertex selected):
                                my SketchUp gallery
                                  Yes, that's because the center of the five selected vertices isn't the center of the polygon.
                                  You can right-click the Gizmo > Gizmo > Align Custom and then set the position of the gizmo. Note that it works like the Align Axis tool, so you must pick center point and then the X and Y axes.
                                  You can then scale and get your start. Note that after scaling the gizmo re-centers itself.
                                  • panixiaP
                                    panixia
                                    align gizmo to custom πŸ˜‰
                                    edit: didn't see page 13 of this post 😳
                                    πŸ˜†
                                    • xiombargX
                                      xiombarg
                                      I know Vertex Tools has been around for a little while but I only recently downloaded the trial version and I just have to say that this plugin finally fills in such a huge hole that Sketchup has been missing in advanced modelling tools and techniques. I only wish I had noticed it before. I was especially STOKED with the scale tool implementation that not only aligns vertices to a single axis, but that we can finally get rid of artifact lines by scaling a plane to absolute zero. Ya-freakin-hoo, it's about time.
                                      Also love the extrude edge and merge vertex options. Beautiful man.
                                        HAppy you like it! πŸ˜„
                                          @xiombarg said:
                                          ...this plugin finally fills in such a huge hole that Sketchup has been missing in advanced modelling tools and techniques....
                                          nice testimonial/endorsement πŸ‘
                                          • BoxB
                                            I was just trolling through the thread and noticed a number of times you asked for action shots of the tool in use. Here's a quick doodle I did the other day for fun.
                                            Fantastic tool, couldn't live without it.
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 33
                                            • 34
                                            • 18 / 34
