    [Plugin][$] Vertex Tools
    667 Posts 92 Posters 483.2k Views 92 Watching
      I didn't know this....
      Do you have to have Vert mode avtivated to set it?
      I've have Vert Tools set to Alt + V and the tools to Alt + M, S, R etc....
        Nope! Just reassign the shortcuts you have for the native Move, Roate, Scale and Select to Tools/Vertex Tools/Move etc.
        See screenshot on this page: http://www.thomthom.net/software/vertex_tools/manual/shortcuts
        An annoying limitation with SketchUp though, if you try to reassign Ctrl+A, Ctrl+T for Select All and Select None then it works only during that session. When you restart they are reverted. 😞
          @Thomthom not TT_SU
          Is it possible that VT could respect CPoints?
          • tt_suT Offline
            tt_su
            Adding to wish-list. Will take a look at it.
              Add these too...
              Edge Slide
              Vertex Move parallel to view direction. Without gizmo
              Vertex Extrude
              Quad Face Fill
              Will i stop?
              • cottyC Offline
                cotty
                @rich o brien said:
                Vertex Extrude
                You know vertex move + CTRL?
                my SketchUp gallery
                • charly2008C Offline
                  charly2008
                  I do not know what I'm doing wrong. For me smoothing doesn't work although the function is checked. I thank you in advance for any help.
                  Charly
                    It is working. Turn off hidden geometry and you will see all the faces have 4 edges.
                    • tt_suT Offline
                      tt_su
                      I assume you mean the soft selection? When you have the Select tool activated, enter a radius in the VCB.
                        charly2008
                        Hi Thomas,
                        Yes that was what I meant. Thanks for the hint.
                          If any OSX Mavericks users tried to register Vertex Tools recently and failed to do so there is a fix released (1.1.7) that takes care of the issue.
                          • cottyC Offline
                            cotty
                            I've tried to create a simple star with vertex scaling (see screencast), but it's getting unsymmetrical, any ideas?
                            my SketchUp gallery
                              Did you try Shift + Blue scale?
                              Sent from my iPad
                              • BoxB Offline
                                It works if you use a 10 sided circle rather than a polygon.
                                • cottyC Offline
                                  cotty
                                  Yes, it's the same.
                                  Same behaviour for polygon, circle, exploded edges, ...
                                  I think the reason is the not centered position of the gizmo (with every second vertex selected):
                                  my SketchUp gallery
                                    Yes, that's because the center of the five selected vertices isn't the center of the polygon.
                                    You can right-click the Gizmo > Gizmo > Align Custom and then set the position of the gizmo. Note that it works like the Align Axis tool, so you must pick center point and then the X and Y axes.
                                    You can then scale and get your start. Note that after scaling the gizmo re-centers itself.
                                    • panixiaP Offline
                                      panixia
                                      align gizmo to custom πŸ˜‰
                                      edit: didn't see page 13 of this post 😳
                                      πŸ˜†
                                      • xiombargX Offline
                                        xiombarg
                                        I know Vertex Tools has been around for a little while but I only recently downloaded the trial version and I just have to say that this plugin finally fills in such a huge hole that Sketchup has been missing in advanced modelling tools and techniques. I only wish I had noticed it before. I was especially STOKED with the scale tool implementation that not only aligns vertices to a single axis, but that we can finally get rid of artifact lines by scaling a plane to absolute zero. Ya-freakin-hoo, it's about time.
                                        Also love the extrude edge and merge vertex options. Beautiful man.
                                          HAppy you like it! πŸ˜„
                                            @xiombarg said:
                                            ...this plugin finally fills in such a huge hole that Sketchup has been missing in advanced modelling tools and techniques....
                                            nice testimonial/endorsement πŸ‘
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 33
                                            • 34
                                            • 18 / 34
