    Triangulate triangles ?
    41 Posts 8 Posters 8.6k Views 8 Watching
    • Rich O BrienR Online
        4 ? Like what ? Please an image! You speak of a quadrangle hidden on a triangle ?
        No 3 triangles!
        A simple triangle(s)( any number ) with this simple construction of 3 medians πŸ˜„
        • renderizaR Offline
          renderiza
          Adding the feature to slit multiple face by automatically finding the center point will be great addition! This should triangulate any type of face aka trig, quad, ect... Because your connecting a line from center to every other vertex. Maybe adding things like skip one vertex every time you add a line will be interesting to see.
          Rich O Brian that would be great as well!
          [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
            It is Artisan subdivide. Thank you Catmull Clark πŸ˜‰
              So no! πŸ˜„ And why not the connections with middles ?
              Medians are wanted! πŸ˜„
              But if you a have the plugin why not, that can be used for other thing πŸ˜„
                Yep cool, but not like the first post πŸ˜„
                And I should know it! πŸ˜‰
                  Alas I have deserted the Ruby language for a while! 😞
                  If you can make a little plugin that will be wonderful 😎
                    renderiza
                    Here is an example code for achieving what you want Pilou...
                    model = Sketchup.active_model
                    ents = model.active_entities
                    sel = model.selection
                    faces = ents.grep(Sketchup;;Face)
                    faces.each do |face|
                      vertices = face.vertices
                      bbox = face.bounds
                      cpoint = bbox.center
                      vertices.each do |vertex|
                        p1 = cpoint
                        p2 = vertex
                        line = ents.add_line p1,p2
                    Note: Some very pretty geometry start appearing when you keep splitting! πŸ‘
                      renderiza
                      I will do that! πŸ‘
                        Beat me to it πŸ˜‰
                        You might want to change the
                        faces = ents.grep(Sketchup::Face)
                        to
                        faces = **sel**.grep(Sketchup::Face)
                        So then the user changes only selected faces ?
                        OR perhaps
                        faces = sel.grep(Sketchup::Face) faces = ents.grep(Sketchup::Face) **unless faces[0]**
                        so it works on a selection OR everything if there is no selection...
                        Also you want to make it undoable, so add
                        **model.start_operation('subtri')** faces.each... ...end **model.commit_operation**
                        πŸ€“
                          renderiza
                          Hahaha!
                          TIG I would be very happy if you modify your existing plugin to add Pilou is feature request. πŸ‘
                          I am interested in making this for learning and I have some additional ideas I want to explore. I consider you my mentor TIG and there will never be competition between you and me I promise! πŸ’š
                          By the way thanks for the suggestion! πŸ‘
                          Here is updated code...
                          faces = sel.grep(Sketchup;;Face)
                          model.start_operation('csplit')
                              bbox = face.bounds
                                p1 = cpoint
                                p2 = vertex
                            sel.clear
                            OK
                            I'll make a simple script and publish it shortly...
                              renderiza
                              Thank you TIG! πŸ‘
                                anar
                                Thanks Pilou !
                                You convinced TIG...
                                And Thanks TIG, I think it's a must have !
                                http://www.polyloop.net/attachment.php?attachmentid=32959&d=1382032801
                                  Try this http://sketchucation.com/forums/viewtopic.php?p=495430#p495430
                                  TriangulateAllFaces...
                                  • cottyC Offline
                                    cotty
                                    I think the triangulation is not the same...
                                    my SketchUp gallery
                                      renderiza
                                      Both of these are very useful so maybe add an option to choose between the two.
                                      http://s23.postimg.org/sp0h6r557/e_1.png
                                        To do the former you need to first triangulate all faces, then find each triangle's center using the angles' bisectors' intersections...
                                        πŸ˜•
                                          renderiza
                                          Not as easy as using the center of face.bounds.center is it. πŸ˜•
                                          If I find the best way to do it with code I'll let you know...Best of luck! πŸ‘
                                            renderiza
                                            I sure don't call the code below a success but its definitely interesting...
                                            http://s13.postimg.org/yerdljl8n/eee.jpg
                                                edges = face.edges
                                                bbox = face.bounds
                                               edges.each do |e|
                                                  e1 = e.start.position
                                                  e2 = e.end.position
                                                  x = (e2.x + e1.x) / 2
                                                  y = (e2.y + e1.y) / 2
                                                  z = (e2.z + e1.z) / 2
                                                    p1 = [x, y, z]
                                                    p2 = vertex
                                              sel.clear
                                            Note: I also find strange that new edges don't intersect with each othere making a new vertex...why is this?
                                            • 3 / 3
