    Triangulate triangles ?
    41 Posts 8 Posters 12.2k Views 8 Watching
      Seems that is not the trick!
      You must find first the middle point intersection on the face! πŸ˜„
      And works only face by face!
      I have tried your "Add Center Point": alas that don't work for a triangle! (for it's edges yes but not for the face itself)
      I have tried your "Center of Gravity": alas that don't work with a face
      There is something cool with your roof plugin, alas that works only one trangular face by one triangular face (and the minimum angle of roof is 1Β° and not 0Β° πŸ˜„
      (the angle problem will be not a problem : we can flatten the result - but face one by one is a problem πŸ˜„
      And there is a little deviation / view top / Camera projection Parallel
        seems it's also the connections of the medians and the gravity center of a triangle so
        an interesting thing! πŸ˜„
          Does it need to be 3 tris? Can it be 4?
              4 ? Like what ? Please an image! You speak of a quadrangle hidden on a triangle ?
              No 3 triangles!
              A simple triangle(s)( any number ) with this simple construction of 3 medians πŸ˜„
              • renderizaR
                renderiza
                Adding the feature to slit multiple face by automatically finding the center point will be great addition! This should triangulate any type of face aka trig, quad, ect... Because your connecting a line from center to every other vertex. Maybe adding things like skip one vertex every time you add a line will be interesting to see.
                Rich O Brian that would be great as well!
                [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
                  It is Artisan subdivide. Thank you Catmull Clark πŸ˜‰
                    So no! πŸ˜„ And why not the connections with middles ?
                    Medians are wanted! πŸ˜„
                    But if you a have the plugin why not, that can be used for other thing πŸ˜„
                      Yep cool, but not like the first post πŸ˜„
                      And I should know it! πŸ˜‰
                        Alas I have deserted the Ruby language for a while! 😞
                        If you can make a little plugin that will be wonderful 😎
                        • renderizaR
                          renderiza
                          Here is an example code for achieving what you want Pilou...
                          model = Sketchup.active_model
                          ents = model.active_entities
                          sel = model.selection
                          faces = ents.grep(Sketchup;;Face)
                          faces.each do |face|
                            vertices = face.vertices
                            bbox = face.bounds
                            cpoint = bbox.center
                            vertices.each do |vertex|
                              p1 = cpoint
                              p2 = vertex
                              line = ents.add_line p1,p2
                          Note: Some very pretty geometry start appearing when you keep splitting! πŸ‘
                          • renderizaR
                            renderiza
                            I will do that! πŸ‘
                              Beat me to it πŸ˜‰
                              You might want to change the
                              faces = ents.grep(Sketchup::Face)
                              to
                              faces = **sel**.grep(Sketchup::Face)
                              So then the user changes only selected faces ?
                              OR perhaps
                              faces = sel.grep(Sketchup::Face) faces = ents.grep(Sketchup::Face) **unless faces[0]**
                              so it works on a selection OR everything if there is no selection...
                              Also you want to make it undoable, so add
                              **model.start_operation('subtri')** faces.each... ...end **model.commit_operation**
                              πŸ€“
                              • renderizaR
                                renderiza
                                Hahaha!
                                TIG I would be very happy if you modify your existing plugin to add Pilou is feature request. πŸ‘
                                I am interested in making this for learning and I have some additional ideas I want to explore. I consider you my mentor TIG and there will never be competition between you and me I promise! πŸ’š
                                By the way thanks for the suggestion! πŸ‘
                                Here is updated code...
                                faces = sel.grep(Sketchup;;Face)
                                model.start_operation('csplit')
                                    bbox = face.bounds
                                      p1 = cpoint
                                      p2 = vertex
                                  sel.clear
                                  OK
                                  I'll make a simple script and publish it shortly...
                                  • renderizaR
                                    renderiza
                                    Thank you TIG! πŸ‘
                                      anar
                                      Thanks Pilou !
                                      You convinced TIG...
                                      And Thanks TIG, I think it's a must have !
                                      http://www.polyloop.net/attachment.php?attachmentid=32959&d=1382032801
                                        Try this http://sketchucation.com/forums/viewtopic.php?p=495430#p495430
                                        TriangulateAllFaces...
                                        • cottyC
                                          cotty
                                          I think the triangulation is not the same...
                                          my SketchUp gallery
                                          • renderizaR
                                            renderiza
                                            Both of these are very useful so maybe add an option to choose between the two.
                                            http://s23.postimg.org/sp0h6r557/e_1.png
                                            • 1 / 3
