    [Plugin] Soften/Unsoften
    26 Posts 13 Posters 41.2k Views 13 Watching
    • CadFatherC
      CadFather
      Bob, you need both the plug in and the folder called smooze (with the icons)
      • W
        watkins
        Dear CadFather,
        Many thanks for that. As an aside, are you Italian? I ask because I spent a very happy year at the University of Trento.
        Kind regards,
        Bob
        • W
          watkins
          Dear Matthieu and Cadfather,
          I am a little confused about what to download. I have the icons showing, but nothing works. The last thing I downloaded and tried is the very last .zip file posted by Cadfather.
          Regards,
          Bob
            Matt666
            Hi CadFather !
            I updated the code, with another tool. It softens edges whose angle normal faces is below 20 degrees.
            So now you've got three tools :
            Mildly Soft edges
            Completely Soft edges
            Unsoft edges
            You forgot a bit of code at the end...
            if (not file_loaded?("Soften.rb"))
            Now the tool will be loaded just one time !
            and the code is also changed following the RickW notices (I hope πŸ˜‰ )
            Good luck for the next icon πŸ˜„
            EDIT : Version 1.1
            Soften.rb
            Frenglish at its best !
            My scripts
            • CadFatherC
              CadFather
              will post a working final version from Matt very soon - need to finish a couple of things first.
              Bob, yes one of those... πŸ˜‰
              • CadFatherC
                CadFather
                Hi Matt, i have a problem with the new version: nothing happens πŸ˜•
                still works with the old one
                i have updated the script with the 3 icons (changed the name for the new command icon)
                • CadFatherC
                  CadFather
                  small update for whoever likes this idea:
                  tweaked Matt's plugin so i get 2 icons (if you ever needed) enable in view > toolbars > soften
                  (i removed menus in plugins)
                  now it is a quick step!
                  Thanks Matt! πŸ‘
                  • W
                    watkins
                    • P
                      publied
                      oh my hero, my savior! this plugin is very useful for me! thanks!
                      hire me@ http://www.publied.it !
                      • T
                        tedvitale
                        Does anybody know of a plugin that allows me to soften multiple grouped objects? I have a lot of 3DS models that i import that need to be smoothed and cleaned up, but I have to open each group and soften them individually, which is quite painstaking. Any Suggestions?
                        Ted Vitale
                        3D Artist and designer
                        Sketchup 2013 Pro
                        • massimoM
                          massimo Moderator
                          404 Not Found
                          (sketchucation.com)
                            shri
                            very handy tool..thanks alot
                              rv1974
                              I can't find a way to assign shortcuts for these tools. Does the needs to be updated, or it's me missing something?
                                Remember that this script is ~10 years old !
                                Because it only makes a toolbar there are no menu items to shortcut onto !
                                However, the native smooth/soften toolset is easily accessed via a shortcut, as that has context and menu items...
                                Why do you need this tool in preference to the built-in native one - the old code uses the very slow 'typename' entity checker, the native one also has more controls over what is changed... ?
                                • designerbursaD
                                  designerbursa
                                  jhs powerbar 3d rotate error fix
                                  def onLButtonDown(flags, x, y, view)
                                  nothing with this click if nothing is selected
                                  puts 'nil' if(Sketchup.active_model.selection.length == 0)
                                  Keep what's currently selected.
                                  Might be temporarily selected because its hovered if there was no selection when tool was selected
                                  @hasSelection = true
                                  Select point when and draw when clicking
                                  first 3 clicks select points and set jaw & pitch. 4th and 5th click are optional and sets roll
                                  if @state == 0
                                  # Select anchorpoint
                                  #@pAnchor.pick view, x, y
                                  if @pAnchor.valid?
                                  @state = 1
                                  @status_text = "Grab entity." # first status text defined in reset()
                                  Sketchup::set_status_text(@status_text, SB_PROMPT)
                                  elsif @state == 1
                                  # Select startpoint 1
                                  #@pStart1.pick view, x, y, @pAnchor
                                  if @pStart1.valid?
                                  @state = 2
                                  @status_text = "Pick target to drag entity towards."
                                  elsif @state == 2
                                  # Select targetpoint 1 and set yaw and pitch for selection
                                  #@pTarget1.pick view, x, y, @pAnchor
                                  if @pTarget1.valid?
                                  @state = 3
                                  @status_text = "(Optional) Grab entity again."
                                    self.rotateYawPitch(@pAnchor.position, @pStart1.position, @pTarget1.position)
                                    # Set rotated flag so script knows whether to update view or not when leaving tool
                                    @rotated = true
                                  elsif @state == 3
                                  # Select startpoint 2
                                  #@pStart2.pick view, x, y, @pAnchor
                                  if @pStart2.valid?
                                  @state = 4
                                  elsif @state == 4
                                  # Select targetpoint 2 and set roll for selection
                                  #@pTarget2.pick view, x, y, @pAnchor
                                  if @pTarget2.valid?
                                  self.rotateRoll(@pAnchor.position, @pStart2.position, @pTarget2.position, (@pTarget1.position - @pAnchor.position))
                                    self.reset(view)
                                  end#def
                                  • 2 / 2
