    [Plugin] Soften/Unsoften
    26 Posts 13 Posters 40.1k Views 13 Watching
      Matt666
      This plugin will help someone, finally... 😄
      As always, great icons CadFather !
      Frenglish at its best !
      My scripts
      • CadFatherC Offline
        CadFather
        Thanks Matt - and i even learned how to create toolbar items (by copying Jim's scripts).. 😄
        • ___olo_ Offline
          ___olo
          CadFather, can you post this Ruby again. Because, I did down it , but it may has a mistake.
          Xin chào nhau giữa con đường
          Mùa xuân phía trước, miên trường phía sau
            CadFather
            done - look up for new download
              CadFather
                chango70
                Wow this answered my prayers!
                • W Offline
                  watkins
                  Dear Matthieu,
                  I have downloaded and installed the plugin. When I open SU I find a toolbar but no Icons. Is this an oversight?
                  Kind regards,
                  Bob
                    CadFather
                    Bob, you need both the plug in and the folder called smooze (with the icons)
                    • W Offline
                      watkins
                      Dear CadFather,
                      Many thanks for that. As an aside, are you Italian? I ask because I spent a very happy year at the University of Trento.
                      Kind regards,
                      Bob
                      • W Offline
                        watkins
                        Dear Matthieu and Cadfather,
                        I am a little confused about what to download. I have the icons showing, but nothing works. The last thing I downloaded and tried is the very last .zip file posted by Cadfather.
                        Regards,
                        Bob
                          Matt666
                          Hi CadFather !
                          I updated the code, with another tool. It softens edges whose angle normal faces is below 20 degrees.
                          So now you've got three tools :
                          Mildly Soft edges
                          Completely Soft edges
                          Unsoft edges
                          You forgot a bit of code at the end...
                          if (not file_loaded?("Soften.rb"))
                          Now the tool will be loaded just one time !
                          and the code is also changed following the RickW notices (I hope 😉 )
                          Good luck for the next icon 😄
                          EDIT : Version 1.1
                          Soften.rb
                          My scripts
                            CadFather
                            will post a working final version from Matt very soon - need to finish a couple of things first.
                            Bob, yes one of those... 😉
                              CadFather
                              Hi Matt, i have a problem with the new version: nothing happens 😕
                              still works with the old one
                              i have updated the script with the 3 icons (changed the name for the new command icon)
                                CadFather
                                small update for whoever likes this idea:
                                tweaked Matt's plugin so i get 2 icons (if you ever needed) enable in view > toolbars > soften
                                (i removed menus in plugins)
                                now it is a quick step!
                                Thanks Matt! 👍
                                • W Offline
                                  watkins
                                    publied
                                    oh my hero, my savior! this plugin is very useful for me! thanks!
                                    hire me@ http://www.publied.it !
                                      tedvitale
                                      Does anybody know of a plugin that allows me to soften multiple grouped objects? I have a lot of 3DS models that i import that need to be smoothed and cleaned up, but I have to open each group and soften them individually, which is quite painstaking. Any Suggestions?
                                      Ted Vitale
                                      3D Artist and designer
                                      Sketchup 2013 Pro
                                      • massimoM Offline
                                        massimo Moderator
                                        http://sketchucation.com/forums/viewtopic.php?t=22920
                                          shri
                                          very handy tool..thanks alot
                                            rv1974
                                            I can't find a way to assign shortcuts for these tools. Does the needs to be updated, or it's me missing something?
