    [Plugin] Soften/Unsoften
    26 Posts 13 Posters 40.7k Views 13 Watching
    • CadFatherC Offline
      CadFather
      Hi Matt, i have a problem with the new version: nothing happens πŸ˜•
      still works with the old one
      i have updated the script with the 3 icons (changed the name for the new command icon)
        CadFather
        small update for whoever likes this idea:
        tweaked Matt's plugin so i get 2 icons (if you ever needed) enable in view > toolbars > soften
        (i removed menus in plugins)
        now it is a quick step!
        Thanks Matt! πŸ‘
        • W Offline
          watkins
            publied
            oh my hero, my savior! this plugin is very useful for me! thanks!
            hire me@ http://www.publied.it !
              tedvitale
              Does anybody know of a plugin that allows me to soften multiple grouped objects? I have a lot of 3DS models that i import that need to be smoothed and cleaned up, but I have to open each group and soften them individually, which is quite painstaking. Any Suggestions?
              Ted Vitale
              3D Artist and designer
              Sketchup 2013 Pro
              • massimoM Offline
                massimo Moderator
                404 Not Found
                (sketchucation.com)
                  shri
                  very handy tool..thanks alot
                    rv1974
                    I can't find a way to assign shortcuts for these tools. Does the needs to be updated, or it's me missing something?
                      Remember that this script is ~10 years old !
                      Because it only makes a toolbar there are no menu items to shortcut onto !
                      However, the native smooth/soften toolset is easily accessed via a shortcut, as that has context and menu items...
                      Why do you need this tool in preference to the built-in native one - the old code uses the very slow 'typename' entity checker, the native one also has more controls over what is changed... ?
                      • designerbursaD Offline
                        designerbursa
                        jhs powerbar 3d rotate error fix
                        def onLButtonDown(flags, x, y, view)
                        nothing with this click if nothing is selected
                        puts 'nil' if(Sketchup.active_model.selection.length == 0)
                        Keep what's currently selected.
                        Might be temporarily selected because its hovered if there was no selection when tool was selected
                        @hasSelection = true
                        Select point when and draw when clicking
                        first 3 clicks select points and set jaw & pitch. 4th and 5th click are optional and sets roll
                        if @state == 0
                        # Select anchorpoint
                        #@pAnchor.pick view, x, y
                        if @pAnchor.valid?
                        @state = 1
                        @status_text = "Grab entity." # first status text defined in reset()
                        Sketchup::set_status_text(@status_text, SB_PROMPT)
                        elsif @state == 1
                        # Select startpoint 1
                        #@pStart1.pick view, x, y, @pAnchor
                        if @pStart1.valid?
                        @state = 2
                        @status_text = "Pick target to drag entity towards."
                        elsif @state == 2
                        # Select targetpoint 1 and set yaw and pitch for selection
                        #@pTarget1.pick view, x, y, @pAnchor
                        if @pTarget1.valid?
                        @state = 3
                        @status_text = "(Optional) Grab entity again."
                          self.rotateYawPitch(@pAnchor.position, @pStart1.position, @pTarget1.position)
                          # Set rotated flag so script knows whether to update view or not when leaving tool
                          @rotated = true
                        elsif @state == 3
                        # Select startpoint 2
                        #@pStart2.pick view, x, y, @pAnchor
                        if @pStart2.valid?
                        @state = 4
                        elsif @state == 4
                        # Select targetpoint 2 and set roll for selection
                        #@pTarget2.pick view, x, y, @pAnchor
                        if @pTarget2.valid?
                        self.rotateRoll(@pAnchor.position, @pStart2.position, @pTarget2.position, (@pTarget1.position - @pAnchor.position))
                          self.reset(view)
                        end#def
                        • 2 / 2
