    [Plugin] Soften/Unsoften
    26 Posts 13 Posters 41.2k Views 13 Watching
    • ___olo_
      ___olo
      CadFather, can you post this Ruby again. Because, I did down it , but it may has a mistake.
      Xin chào nhau giữa con đường
      Mùa xuân phía trước, miên trường phía sau
      • CadFatherC
        CadFather
        done - look up for new download
        • CadFatherC
          CadFather
          • C
            chango70
            Wow this answered my prayers!
            • W
              watkins
              Dear Matthieu,
              I have downloaded and installed the plugin. When I open SU I find a toolbar but no Icons. Is this an oversight?
              Kind regards,
              Bob
              • CadFatherC
                CadFather
                Bob, you need both the plug in and the folder called smooze (with the icons)
                • W
                  watkins
                  Dear CadFather,
                  Many thanks for that. As an aside, are you Italian? I ask because I spent a very happy year at the University of Trento.
                  Kind regards,
                  Bob
                  • W
                    watkins
                    Dear Matthieu and Cadfather,
                    I am a little confused about what to download. I have the icons showing, but nothing works. The last thing I downloaded and tried is the very last .zip file posted by Cadfather.
                    Regards,
                    Bob
                      Matt666
                      Hi CadFather !
                      I updated the code, with another tool. It softens edges whose angle normal faces is below 20 degrees.
                      So now you've got three tools :
                      Mildly Soft edges
                      Completely Soft edges
                      Unsoft edges
                      You forgot a bit of code at the end...
                      if (not file_loaded?("Soften.rb"))
                      Now the tool will be loaded just one time !
                      and the code is also changed following the RickW notices (I hope 😉 )
                      Good luck for the next icon 😄
                      EDIT : Version 1.1
                      Soften.rb
                      Frenglish at its best !
                      My scripts
                      • CadFatherC
                        CadFather
                        will post a working final version from Matt very soon - need to finish a couple of things first.
                        Bob, yes one of those... 😉
                        • CadFatherC
                          CadFather
                          Hi Matt, i have a problem with the new version: nothing happens 😕
                          still works with the old one
                          i have updated the script with the 3 icons (changed the name for the new command icon)
                          • CadFatherC
                            CadFather
                            small update for whoever likes this idea:
                            tweaked Matt's plugin so i get 2 icons (if you ever needed) enable in view > toolbars > soften
                            (i removed menus in plugins)
                            now it is a quick step!
                            Thanks Matt! 👍
                            • W
                              watkins
                              • P
                                publied
                                oh my hero, my savior! this plugin is very useful for me! thanks!
                                hire me@ http://www.publied.it !
                                • T
                                  tedvitale
                                  Does anybody know of a plugin that allows me to soften multiple grouped objects? I have a lot of 3DS models that i import that need to be smoothed and cleaned up, but I have to open each group and soften them individually, which is quite painstaking. Any Suggestions?
                                  Ted Vitale
                                  3D Artist and designer
                                  Sketchup 2013 Pro
                                  • massimoM
                                    massimo Moderator
                                    404 Not Found
                                    (sketchucation.com)
                                      shri
                                      very handy tool..thanks alot
                                        rv1974
                                        I can't find a way to assign shortcuts for these tools. Does the needs to be updated, or it's me missing something?
                                          Remember that this script is ~10 years old !
                                          Because it only makes a toolbar there are no menu items to shortcut onto !
                                          However, the native smooth/soften toolset is easily accessed via a shortcut, as that has context and menu items...
                                          Why do you need this tool in preference to the built-in native one - the old code uses the very slow 'typename' entity checker, the native one also has more controls over what is changed... ?
                                          • designerbursaD
                                            designerbursa
                                            jhs powerbar 3d rotate error fix
                                            def onLButtonDown(flags, x, y, view)
                                            nothing with this click if nothing is selected
                                            puts 'nil' if(Sketchup.active_model.selection.length == 0)
                                            Keep what's currently selected.
                                            Might be temporarily selected because its hovered if there was no selection when tool was selected
                                            @hasSelection = true
                                            Select point when and draw when clicking
                                            first 3 clicks select points and set jaw & pitch. 4th and 5th click are optional and sets roll
                                            if @state == 0
                                            # Select anchorpoint
                                            #@pAnchor.pick view, x, y
                                            if @pAnchor.valid?
                                            @state = 1
                                            @status_text = "Grab entity." # first status text defined in reset()
                                            Sketchup::set_status_text(@status_text, SB_PROMPT)
                                            elsif @state == 1
                                            # Select startpoint 1
                                            #@pStart1.pick view, x, y, @pAnchor
                                            if @pStart1.valid?
                                            @state = 2
                                            @status_text = "Pick target to drag entity towards."
                                            elsif @state == 2
                                            # Select targetpoint 1 and set yaw and pitch for selection
                                            #@pTarget1.pick view, x, y, @pAnchor
                                            if @pTarget1.valid?
                                            @state = 3
                                            @status_text = "(Optional) Grab entity again."
                                              self.rotateYawPitch(@pAnchor.position, @pStart1.position, @pTarget1.position)
                                              # Set rotated flag so script knows whether to update view or not when leaving tool
                                              @rotated = true
                                            elsif @state == 3
                                            # Select startpoint 2
                                            #@pStart2.pick view, x, y, @pAnchor
                                            if @pStart2.valid?
                                            @state = 4
                                            elsif @state == 4
                                            # Select targetpoint 2 and set roll for selection
                                            #@pTarget2.pick view, x, y, @pAnchor
                                            if @pTarget2.valid?
                                            self.rotateRoll(@pAnchor.position, @pStart2.position, @pTarget2.position, (@pTarget1.position - @pAnchor.position))
                                              self.reset(view)
                                            end#def
