    [Plugin] Soften/Unsoften
    26 Posts 13 Posters 40.7k Views 13 Watching
    • CadFatherC Offline
      CadFather
      THANKS GUYS!!!
      Pixero for a new interesting plugin
      Matt for a genius 'back to the future plugin' - works just great even for groups and all!
      (and it's much easier for quick smooth/unsmooth)
      will see if i can create a toolbar to the commands..
        Matt666
        This plugin will help someone, finally... 😄
        As always, great icons CadFather !
        Frenglish at its best !
        My scripts
          CadFather
          Thanks Matt - and i even learned how to create toolbar items (by copying Jim's scripts).. 😄
          • ___olo_ Offline
            ___olo
            CadFather, can you post this Ruby again. Because, I did down it , but it may has a mistake.
            Xin chào nhau giữa con đường
            Mùa xuân phía trước, miên trường phía sau
              CadFather
              done - look up for new download
                CadFather
                  chango70
                  Wow this answered my prayers!
                  • W Offline
                    watkins
                    Dear Matthieu,
                    I have downloaded and installed the plugin. When I open SU I find a toolbar but no Icons. Is this an oversight?
                    Kind regards,
                    Bob
                      CadFather
                      Bob, you need both the plug in and the folder called smooze (with the icons)
                      • W Offline
                        watkins
                        Dear CadFather,
                        Many thanks for that. As an aside, are you Italian? I ask because I spent a very happy year at the University of Trento.
                        Kind regards,
                        Bob
                        • W Offline
                          watkins
                          Dear Matthieu and Cadfather,
                          I am a little confused about what to download. I have the icons showing, but nothing works. The last thing I downloaded and tried is the very last .zip file posted by Cadfather.
                          Regards,
                          Bob
                            Matt666
                            Hi CadFather !
                            I updated the code, with another tool. It softens edges whose angle normal faces is below 20 degrees.
                            So now you've got three tools :
                            Mildly Soft edges
                            Completely Soft edges
                            Unsoft edges
                            You forgot a bit of code at the end...
                            if (not file_loaded?("Soften.rb"))
                            Now the tool will be loaded just one time !
                            and the code is also changed following the RickW notices (I hope 😉 )
                            Good luck for the next icon 😄
                            EDIT : Version 1.1
                            Soften.rb
                            My scripts
                              CadFather
                              will post a working final version from Matt very soon - need to finish a couple of things first.
                              Bob, yes one of those... 😉
                                CadFather
                                Hi Matt, i have a problem with the new version: nothing happens 😕
                                still works with the old one
                                i have updated the script with the 3 icons (changed the name for the new command icon)
                                  CadFather
                                  small update for whoever likes this idea:
                                  tweaked Matt's plugin so i get 2 icons (if you ever needed) enable in view > toolbars > soften
                                  (i removed menus in plugins)
                                  now it is a quick step!
                                  Thanks Matt! 👍
                                  • W Offline
                                    watkins
                                      publied
                                      oh my hero, my savior! this plugin is very useful for me! thanks!
                                      hire me@ http://www.publied.it !
                                        tedvitale
                                        Does anybody know of a plugin that allows me to soften multiple grouped objects? I have a lot of 3DS models that i import that need to be smoothed and cleaned up, but I have to open each group and soften them individually, which is quite painstaking. Any Suggestions?
                                        Ted Vitale
                                        3D Artist and designer
                                        Sketchup 2013 Pro
                                        • massimoM Offline
                                          massimo Moderator
                                          404 Not Found
                                          (sketchucation.com)
                                            shri
                                            very handy tool..thanks alot
