    [Plugin] TIG-Smart_offset
    143 Posts 55 Posters 199.8k Views 54 Watching
    • Mistro11M
      Mistro11
      You have no idea how many times I got frustrated doing an offset and have to get in there and clean up the shape. Thanks TIG!
      Structural Integrity is Not Just Physical...It's in the Design and Purpose
      • jeff hammondJ
        i'm all greyed out (on two separate computers with different OS & different versions of sketchup on them).. will investigate more tomorrow
        (skindigo toolbar as reference to what the blue/blacks should look like)
        • N
          notareal
          Merry Christmas to you too!
            Jim
            in cmd.set_validation_proc (and other places) you want to give the full scope of the suitable? method since it is being called from SketchUp outside the scope of your module.
            Also, combine the MF_ bits.
            cmd=UI;;Command.new('TIG.Smart_offset'){self.dialog()}
            if TIG;;Smart_offsetter.suitable?()
            MF_ENABLED
            else
            MF_DISABLED | MF_GRAYED
            • cottyC
              cotty
              Nice gift! Thank you and Merry Christmas! (Are we allowed to use it before 24.12.?)
              my SketchUp gallery
                Yeeeeeeees! Works like a charm now! 👍
                You are the Ruby's king! 😎
                And lucky because I can't more test your tricky plugin before the next year! 😄
                  > MF_ENABLED
                  > else
                  > end
                  Thanks, knew it was obvious... This only affected MACs though ???
                  This was collecting dust on a virtual dust, until Pilou reminded me that I'd written it, so sometimes things get 'forgotten'... 😒
                    Here's v1.2 http://sketchucation.com/forums/viewtopic.php?p=446462#p446462
                    Further robustness in enabling/disabling/graying and suitable? tests [thanks to Jim!].
                    Seems to be especially for MACs 😄
                      Jim
                      I am not sure - it was just a guess and I don't have a Mac. Did you try it? 😆
                        I don't have a MAC either. 😕
                        Driven's reported issue was on a MAC and Jeff had other issues on a MAC too...
                        Hopefully this recent v1.2 [...20121221b.rbz !] will address the suitable? check and MF_ issues with the menus/toolbar...
                        It still works fine on a PC, but then v1.1 did too 😕 😄
                        • elmerE
                          elmer
                          Nice Christmas gift Tig, thanks a lot, it works perfectly on my Mac.
                          • alvisA
                            alvis
                            Thanx TIG
                            • guanjinG
                              guanjin
                              TIG: Merry Christmas
                              • jeff hammondJ
                                Hi Tig
                                i'm still getting the same greyed out problem.
                                is there anything i can type in the console or ?? to help figure out what the problem is?
                                thanks
                                  Is there no difference at all - if you have nothing preselected, or one edge preselected, or one face preselected, or lots of things [including some edges] preselected ?
                                  The menu/toolbar are only enabled if there's at least one face in the current selection.
                                  The context-menu only appears if there's at least one face in the current selection.
                                  Copy/paste+<enter> these into the Ruby Console and report the results:
                                  with nothing preselected TIG::Smart_offsetter.suitable?()
                                  with one edge preselected TIG::Smart_offsetter.suitable?()
                                  with one face preselected TIG::Smart_offsetter.suitable?()
                                  with lots of things [including some edges] preselected TIG::Smart_offsetter.suitable?()
                                  with one edge preselected TIG::Smart_offsetter.dialog()
                                  with one face preselected TIG::Smart_offsetter.dialog()
                                  • jeff hammondJ
                                    oops 😳
                                    it actually is working now..
                                    it's just the toolbar that remains greyed out at all times but the menu item becomes available once an appropriate selection has been made..
                                    (which, for me personally, is fine.. i more likely than not wont want the toolbar anyway.. i think id use it with a modifier key added to my offset shortcut)
                                    • jeff hammondJ
                                      here are these results.. (since you took the time to write them.. i better take the time to report 😉 )
                                      false
                                      false
                                      true
                                      true (drew two squares and selected all)
                                      warning- PreSelect Face[s !]
                                      ruby - nil
                                      (works as expected)
                                      • jeff hammondJ
                                        uh.. not sure what the deal is but..
                                        upon entering all of that stuff in the console, the toolbar is now working
                                        [edit] but then.. i quit sketchup then relaunched and the toolbar is greyed out again regardless of selection.. the menu item is working though
                                        • Chris FullmerC
                                          voodoo. definitely voodoo at work here.
                                          • jeff hammondJ
                                            ha.. that darn voodoo! 😄
                                            some more info:
                                            so here's what the deal with the toolbar is.. (in this example, i have 3 squares with faces drawn)
                                            •cmmdA (select all)
                                            •toolbar remains greyed out (menu item is live)
                                            •do something else (rotate, pan, etc)
                                            •toolbar becomes active
                                            •deselect all
                                            •toolbar remains active (menu item greys out)
                                            •do something else (switch tool, orbit, etc)
                                            •toolbar greys out
                                            so it appears, on mac, that something has to happen other than simply selecting in order to jump start the toolbar into updating it's state
                                            • 2 / 8
