    [Plugin] TIG-Smart_offset
    143 Posts 55 Posters 196.6k Views 54 Watching
      Yeeeeeeees! Works like a charm now! ๐Ÿ‘
      You are the Ruby's king! ๐Ÿ˜Ž
      And lucky because I can't more test your tricky plugin before the next year! ๐Ÿ˜„
        @jim said:
        in cmd.set_validation_proc (and other places) you want to give the full scope of the suitable? method since it is being called from SketchUp outside the scope of your module.
        Also, combine the MF_ bits.
        > cmd=UI;;Command.new('TIG.Smart_offset'){self.dialog()}
        > if TIG;;Smart_offsetter.suitable?()
        > MF_ENABLED
        > else
        > MF_DISABLED | MF_GRAYED
        > end
        Thanks, knew it was obvious... This only affected MACs though ???
        This was collecting dust on a virtual dust, until Pilou reminded me that I'd written it, so sometimes things get 'forgotten'... ๐Ÿ˜’
          Here's v1.2 http://sketchucation.com/forums/viewtopic.php?p=446462#p446462
          Further robustness in enabling/disabling/graying and suitable? tests [thanks to Jim!].
          Seems to be especially for MACs ๐Ÿ˜„
            Jim
            I am not sure - it was just a guess and I don't have a Mac. Did you try it? ๐Ÿ˜†
              I don't have a MAC either. ๐Ÿ˜•
              Driven's reported issue was on a MAC and Jeff had other issues on a MAC too...
              Hopefully this recent v1.2 [...20121221b.rbz !] will address the suitable? check and MF_ issues with the menus/toolbar...
              It still works fine on a PC, but then v1.1 did too ๐Ÿ˜• ๐Ÿ˜„
              • elmerE
                elmer
                Nice Christmas gift Tig, thanks a lot, it works perfectly on my Mac.
                • alvisA
                  alvis
                  Thanx TIG
                  • guanjinG
                    guanjin
                    TIG: Merry Christmas
                    • jeff hammondJ
                      Hi Tig
                      i'm still getting the same greyed out problem.
                      is there anything i can type in the console or ?? to help figure out what the problem is?
                      thanks
                        Is there no difference at all - if you have nothing preselected, or one edge preselected, or one face preselected, or lots of things [including some edges] preselected ?
                        The menu/toolbar are only enabled if there's at least one face in the current selection.
                        The context-menu only appears if there's at least one face in the current selection.
                        Copy/paste+<enter> these into the Ruby Console and report the results:
                        with nothing preselected TIG::Smart_offsetter.suitable?()
                        with one edge preselected TIG::Smart_offsetter.suitable?()
                        with one face preselected TIG::Smart_offsetter.suitable?()
                        with lots of things [including some edges] preselected TIG::Smart_offsetter.suitable?()
                        with one edge preselected TIG::Smart_offsetter.dialog()
                        with one face preselected TIG::Smart_offsetter.dialog()
                        ๐Ÿ˜•
                        • jeff hammondJ
                          oops ๐Ÿ˜ณ
                          it actually is working now..
                          it's just the toolbar that remains greyed out at all times but the menu item becomes available once an appropriate selection has been made..
                          (which, for me personally, is fine.. i more likely than not wont want the toolbar anyway.. i think id use it with a modifier key added to my offset shortcut)
                          • jeff hammondJ
                            here are these results.. (since you took the time to write them.. i better take the time to report ๐Ÿ˜‰ )
                            false
                            false
                            true
                            true (drew two squares and selected all)
                            warning- PreSelect Face[s !]
                            ruby - nil
                            (works as expected)
                            • jeff hammondJ
                              uh.. not sure what the deal is but..
                              upon entering all of that stuff in the console, the toolbar is now working
                              ๐Ÿ˜•
                              [edit] but then.. i quit sketchup then relaunched and the toolbar is greyed out again regardless of selection.. the menu item is working though
                              • Chris FullmerC
                                voodoo. definitely voodoo at work here.
                                • jeff hammondJ
                                  ha.. that darn voodoo! ๐Ÿ˜„
                                  some more info:
                                  so here's what the deal with the toolbar is.. (in this example, i have 3 squares with faces drawn)
                                  โ€ขcmmdA (select all)
                                  โ€ขtoolbar remains greyed out (menu item is live)
                                  โ€ขdo something else (rotate, pan, etc)
                                  โ€ขtoolbar becomes active
                                  โ€ขdeselect all
                                  โ€ขtoolbar remains active (menu item greys out)
                                  โ€ขdo something else (switch tool, orbit, etc)
                                  โ€ขtoolbar greys out
                                  so it appears, on mac, that something has to happen other than simply selecting in order to jump start the toolbar into updating it's state
                                  • C
                                    ccbiggs
                                    Hey Tig,
                                    I am getting the same thing Jeff has. But since Jeff actually knows what he is doing, he can do the ruby troubleshooting. Will stay tuned to see what you fellas figure out.
                                    It works great on my windows machine at home.
                                    Thanks Tig
                                    Update
                                    Jeff says his works. It does not work on my mac.
                                    false
                                    false
                                    true
                                    true
                                    TIG.Smart_offset:
                                    PreSelect Face[s] !
                                    Offset [+/-ve=out/
                                    My drop down "Tools" Menu works with a face preselected. The toolbar does not.
                                    Nothing works with just edges selected.
                                    If you need me to check anything else, and I do not get right back to ya, I am not ignoring you I am just here there and everywhere today.
                                      Here's v1.3 http://sketchucation.com/forums/viewtopic.php?p=446462#p446462
                                      Removed 'suitable?' method, to suit MACs, more error traps etc.
                                      Try this and report back... ๐Ÿ˜’
                                      • C
                                        ccbiggs
                                        It works the same for me. With a face selected the drop down tools menu item will work but the single icon toolbar will not.
                                          Which is weird... because they BOTH use 'cmd' and share the same enabled/grayed code...
                                          To check that the toolbar WILL work somehow... can you please edit the file 'TIG-Smart_offset.rb' on your MAC with a plain text editor [BBedit???] and find the three lines starting at #117 reading:
                                          		cmd.set_validation_proc{
                                          			Sketchup.active_model.selection.grep(Sketchup;;Face)[0] ? MF_ENABLED ; MF_GRAYED
                                          and change them to read
                                          		#cmd.set_validation_proc{
                                          			#Sketchup.active_model.selection.grep(Sketchup;;Face)[0] ? MF_ENABLED ; MF_GRAYED
                                          i.e. add a # in front of each of the three lines to disable them.
                                          Now the tool's command should always be 'enabled' in the menu & the toolbar button, if you try to use it without a Face in the Selection you'll get an error messagebox...
                                          Let me know how this goes...
                                          Incidentally, BEFORE [& after] you make the changes... do you get the tool's context-menu item IF there's a Face in the Selection ?
                                          • jeff hammondJ
                                            that does the trick.. the toolbar is always active now and i'll just receive an error if i try to run the tool without an appropriate selection..
                                            [context menu works also.. but it worked prior to disabling the above lines]
                                            • 2 / 8
