    [Plugin] TIG-Smart_offset
    143 Posts 55 Posters 186.5k Views 54 Watching
      driven
      found it, a new 'finder. replacement doesn't update instantly... bin that
      ok no errors. menu cmd works, context cmd work, toolbar cmd dosen't do anything
      It works if I split if the validation proc
      cmd2=UI::Command.new('TIG.Smart_offset'){self.dialog()} cmd2.small_icon=File.join(dir, 'TIG-Smart_offset.png') cmd2.large_icon=File.join(dir, 'TIG-Smart_offset.png') toolbar=UI::Toolbar.new('TIG.Smart_offset') toolbar.add_item(cmd2)
      • Mistro11M Offline
        Mistro11
        You have no idea how many times I got frustrated doing an offset and have to get in there and clean up the shape. Thanks TIG!
        i7-4930k @3.4/3.7GHz, 32Gb RAM, NVidia GTX 980Ti 6Gb, Windows 7 Pro 64bit
        Structural Integrity is Not Just Physical...It's in the Design and Purpose
        • jeff hammondJ Offline
          i'm all greyed out (on two separate computers with different OS & different versions of sketchup on them).. will investigate more tomorrow
          (skindigo toolbar as reference to what the blue/blacks should look like)
          • N Offline
            notareal
            Merry Christmas to you too!
            Welcome to try [Thea Render](http://www.thearender.com/), Thea support | [kerkythea.net](http://www.kerkythea.net/) -team member
              Jim
              in cmd.set_validation_proc (and other places) you want to give the full scope of the suitable? method since it is being called from SketchUp outside the scope of your module.
              Also, combine the MF_ bits.
              cmd=UI;;Command.new('TIG.Smart_offset'){self.dialog()}
              if TIG;;Smart_offsetter.suitable?()
              MF_ENABLED
              else
              MF_DISABLED | MF_GRAYED
              • cottyC Offline
                cotty
                Nice gift! Thank you and Merry Christmas! (Are we allowed to use it before 24.12.?)
                my SketchUp gallery
                  Yeeeeeeees! Works like a charm now! πŸ‘
                  You are the Ruby's king! 😎
                  And lucky because I can't more test your tricky plugin before the next year! πŸ˜„
                  • TIGT Online
                    > MF_ENABLED
                    > else
                    > end
                    Thanks, knew it was obvious... This only affected MACs though ???
                    This was collecting dust on a virtual dust, until Pilou reminded me that I'd written it, so sometimes things get 'forgotten'... πŸ˜’
                    • TIGT Online
                      Here's v1.2 http://sketchucation.com/forums/viewtopic.php?p=446462#p446462
                      Further robustness in enabling/disabling/graying and suitable? tests [thanks to Jim!].
                      Seems to be especially for MACs πŸ˜„
                        Jim
                        I am not sure - it was just a guess and I don't have a Mac. Did you try it? πŸ˜†
                        • TIGT Online
                          I don't have a MAC either. πŸ˜•
                          Driven's reported issue was on a MAC and Jeff had other issues on a MAC too...
                          Hopefully this recent v1.2 [...20121221b.rbz !] will address the suitable? check and MF_ issues with the menus/toolbar...
                          It still works fine on a PC, but then v1.1 did too πŸ˜• πŸ˜„
                          • elmerE Offline
                            elmer
                            Nice Christmas gift Tig, thanks a lot, it works perfectly on my Mac.
                            • alvisA Offline
                              alvis
                              Thanx TIG
                              • guanjinG Offline
                                guanjin
                                TIG: Merry Christmas
                                  Hi Tig
                                  i'm still getting the same greyed out problem.
                                  is there anything i can type in the console or ?? to help figure out what the problem is?
                                  thanks
                                  • TIGT Online
                                    Is there no difference at all - if you have nothing preselected, or one edge preselected, or one face preselected, or lots of things [including some edges] preselected ?
                                    The menu/toolbar are only enabled if there's at least one face in the current selection.
                                    The context-menu only appears if there's at least one face in the current selection.
                                    Copy/paste+<enter> these into the Ruby Console and report the results:
                                    with nothing preselected TIG::Smart_offsetter.suitable?()
                                    with one edge preselected TIG::Smart_offsetter.suitable?()
                                    with one face preselected TIG::Smart_offsetter.suitable?()
                                    with lots of things [including some edges] preselected TIG::Smart_offsetter.suitable?()
                                    with one edge preselected TIG::Smart_offsetter.dialog()
                                    with one face preselected TIG::Smart_offsetter.dialog()
                                    πŸ˜•
                                      oops 😳
                                      it actually is working now..
                                      it's just the toolbar that remains greyed out at all times but the menu item becomes available once an appropriate selection has been made..
                                      (which, for me personally, is fine.. i more likely than not wont want the toolbar anyway.. i think id use it with a modifier key added to my offset shortcut)
                                        here are these results.. (since you took the time to write them.. i better take the time to report πŸ˜‰ )
                                        false
                                        false
                                        true
                                        true (drew two squares and selected all)
                                        warning- PreSelect Face[s !]
                                        ruby - nil
                                        (works as expected)
                                          uh.. not sure what the deal is but..
                                          upon entering all of that stuff in the console, the toolbar is now working
                                          πŸ˜•
                                          [edit] but then.. i quit sketchup then relaunched and the toolbar is greyed out again regardless of selection.. the menu item is working though
                                          • Chris FullmerC Offline
                                            voodoo. definitely voodoo at work here.
                                            • 2 / 8
