    [Plugin] TIG-Smart_offset
    143 Posts 55 Posters 186.5k Views 54 Watching
      Pilou
      There is a Ruby Console error message saying it can't be done [clearly it can !]
      I knew there was as reason I had never released this code !
      Now I need to find out what's wrong with it ??
      Merry Solstice...
        Tahnks for the gift before the end of world ! 😎
        Seems marvellous but...(maybe I miss something 😳
        The bow tie must not be disapear ?
        (Normal Offset = Native Offset, Nothing = TIG_Smart_Offset )
        Sorry for the inconvenience ! πŸ˜„
        cool_but.skp
          Bon courage! πŸ‘
            kargall
            Works very well. Merry Xmas to you too. Thanks πŸ˜‰
              driven
              undefined methodsuitable?' for TIG::Smart_offsetter:ModuleError Loading File TIG-Smart_offset.rb
              undefined method suitable?' for TIG::Smart_offsetter:Module
              but worked to a degree, the new border and face are separate and I can't seem to get them to merge with the original face?
                Strange there is a method called that ?
                It checks selection for suitability and affects how the menu, toolbar and context-menu items display/enabled...
                Are you on MAC ?
                Was there a line number with that error ?
                I'm about to issue v1.1 to resolve Pilou's tolerance issue...
                I'll swap some code around to see if making that method earlier fixes it for you...
                Let me know whatever you can... πŸ˜•
                If it's still an issue a sample SKP might help...
                  Here's v1.1 http://sketchucation.com/forums/viewtopic.php?p=446462#p446462
                  It's been made more robust.
                    driven
                    Hi Tig,
                    I'll try the new one but something really odd is going on, and yes I'm on a mac.
                    I used SU to instal, and had line numbers then, so I removed it from 'plugins' to do again, but
                    this has been uninstalled, moved to trash, emptied trash, restarted computer, but it still there and it works, as well as it did, although sketchup can't find the file.... it's crazy, I don't have hidden files either.
                    I'll over write with the new
                      driven
                      found it, a new 'finder. replacement doesn't update instantly... bin that
                      ok no errors. menu cmd works, context cmd work, toolbar cmd dosen't do anything
                      It works if I split if the validation proc
                      cmd2=UI::Command.new('TIG.Smart_offset'){self.dialog()} cmd2.small_icon=File.join(dir, 'TIG-Smart_offset.png') cmd2.large_icon=File.join(dir, 'TIG-Smart_offset.png') toolbar=UI::Toolbar.new('TIG.Smart_offset') toolbar.add_item(cmd2)
                      • Mistro11M Offline
                        Mistro11
                        You have no idea how many times I got frustrated doing an offset and have to get in there and clean up the shape. Thanks TIG!
                        i7-4930k @3.4/3.7GHz, 32Gb RAM, NVidia GTX 980Ti 6Gb, Windows 7 Pro 64bit
                        Structural Integrity is Not Just Physical...It's in the Design and Purpose
                        • jeff hammondJ Offline
                          i'm all greyed out (on two separate computers with different OS & different versions of sketchup on them).. will investigate more tomorrow
                          (skindigo toolbar as reference to what the blue/blacks should look like)
                          • N Offline
                            notareal
                            Merry Christmas to you too!
                            Welcome to try [Thea Render](http://www.thearender.com/), Thea support | [kerkythea.net](http://www.kerkythea.net/) -team member
                              Jim
                              in cmd.set_validation_proc (and other places) you want to give the full scope of the suitable? method since it is being called from SketchUp outside the scope of your module.
                              Also, combine the MF_ bits.
                              cmd=UI;;Command.new('TIG.Smart_offset'){self.dialog()}
                              if TIG;;Smart_offsetter.suitable?()
                              MF_ENABLED
                              else
                              MF_DISABLED | MF_GRAYED
                              • cottyC Offline
                                cotty
                                Nice gift! Thank you and Merry Christmas! (Are we allowed to use it before 24.12.?)
                                my SketchUp gallery
                                  Yeeeeeeees! Works like a charm now! πŸ‘
                                  You are the Ruby's king! 😎
                                  And lucky because I can't more test your tricky plugin before the next year! πŸ˜„
                                    > MF_ENABLED
                                    > else
                                    > end
                                    Thanks, knew it was obvious... This only affected MACs though ???
                                    This was collecting dust on a virtual dust, until Pilou reminded me that I'd written it, so sometimes things get 'forgotten'... πŸ˜’
                                      Here's v1.2 http://sketchucation.com/forums/viewtopic.php?p=446462#p446462
                                      Further robustness in enabling/disabling/graying and suitable? tests [thanks to Jim!].
                                      Seems to be especially for MACs πŸ˜„
                                        Jim
                                        I am not sure - it was just a guess and I don't have a Mac. Did you try it? πŸ˜†
                                          I don't have a MAC either. πŸ˜•
                                          Driven's reported issue was on a MAC and Jeff had other issues on a MAC too...
                                          Hopefully this recent v1.2 [...20121221b.rbz !] will address the suitable? check and MF_ issues with the menus/toolbar...
                                          It still works fine on a PC, but then v1.1 did too πŸ˜• πŸ˜„
                                          • elmerE Offline
                                            elmer
                                            Nice Christmas gift Tig, thanks a lot, it works perfectly on my Mac.
                                            • 1 / 8
