    [Plugin] TIG-Smart_offset
    143 Posts 55 Posters 192.3k Views 54 Watching
      Bon courage! πŸ‘
        kargall
        Works very well. Merry Xmas to you too. Thanks πŸ˜‰
          driven
          undefined methodsuitable?' for TIG::Smart_offsetter:ModuleError Loading File TIG-Smart_offset.rb
          undefined method suitable?' for TIG::Smart_offsetter:Module
          but worked to a degree, the new border and face are separate and I can't seem to get them to merge with the original face?
            Strange there is a method called that ?
            It checks selection for suitability and affects how the menu, toolbar and context-menu items display/enabled...
            Are you on MAC ?
            Was there a line number with that error ?
            I'm about to issue v1.1 to resolve Pilou's tolerance issue...
            I'll swap some code around to see if making that method earlier fixes it for you...
            Let me know whatever you can... πŸ˜•
            If it's still an issue a sample SKP might help...
              Here's v1.1 http://sketchucation.com/forums/viewtopic.php?p=446462#p446462
              It's been made more robust.
                driven
                Hi Tig,
                I'll try the new one but something really odd is going on, and yes I'm on a mac.
                I used SU to instal, and had line numbers then, so I removed it from 'plugins' to do again, but
                this has been uninstalled, moved to trash, emptied trash, restarted computer, but it still there and it works, as well as it did, although sketchup can't find the file.... it's crazy, I don't have hidden files either.
                I'll over write with the new
                  driven
                  found it, a new 'finder. replacement doesn't update instantly... bin that
                  ok no errors. menu cmd works, context cmd work, toolbar cmd dosen't do anything
                  It works if I split if the validation proc
                  cmd2=UI::Command.new('TIG.Smart_offset'){self.dialog()} cmd2.small_icon=File.join(dir, 'TIG-Smart_offset.png') cmd2.large_icon=File.join(dir, 'TIG-Smart_offset.png') toolbar=UI::Toolbar.new('TIG.Smart_offset') toolbar.add_item(cmd2)
                  • Mistro11M Offline
                    Mistro11
                    You have no idea how many times I got frustrated doing an offset and have to get in there and clean up the shape. Thanks TIG!
                    i7-4930k @3.4/3.7GHz, 32Gb RAM, NVidia GTX 980Ti 6Gb, Windows 7 Pro 64bit
                    Structural Integrity is Not Just Physical...It's in the Design and Purpose
                    • jeff hammondJ Offline
                      i'm all greyed out (on two separate computers with different OS & different versions of sketchup on them).. will investigate more tomorrow
                      (skindigo toolbar as reference to what the blue/blacks should look like)
                      • N Offline
                        notareal
                        Merry Christmas to you too!
                          Jim
                          in cmd.set_validation_proc (and other places) you want to give the full scope of the suitable? method since it is being called from SketchUp outside the scope of your module.
                          Also, combine the MF_ bits.
                          cmd=UI;;Command.new('TIG.Smart_offset'){self.dialog()}
                          if TIG;;Smart_offsetter.suitable?()
                          MF_ENABLED
                          else
                          MF_DISABLED | MF_GRAYED
                          • cottyC Offline
                            cotty
                            Nice gift! Thank you and Merry Christmas! (Are we allowed to use it before 24.12.?)
                            my SketchUp gallery
                              Yeeeeeeees! Works like a charm now! πŸ‘
                              You are the Ruby's king! 😎
                              And lucky because I can't more test your tricky plugin before the next year! πŸ˜„
                                > MF_ENABLED
                                > else
                                > end
                                Thanks, knew it was obvious... This only affected MACs though ???
                                This was collecting dust on a virtual dust, until Pilou reminded me that I'd written it, so sometimes things get 'forgotten'... πŸ˜’
                                  Here's v1.2 http://sketchucation.com/forums/viewtopic.php?p=446462#p446462
                                  Further robustness in enabling/disabling/graying and suitable? tests [thanks to Jim!].
                                  Seems to be especially for MACs πŸ˜„
                                    Jim
                                    I am not sure - it was just a guess and I don't have a Mac. Did you try it? πŸ˜†
                                      I don't have a MAC either. πŸ˜•
                                      Driven's reported issue was on a MAC and Jeff had other issues on a MAC too...
                                      Hopefully this recent v1.2 [...20121221b.rbz !] will address the suitable? check and MF_ issues with the menus/toolbar...
                                      It still works fine on a PC, but then v1.1 did too πŸ˜• πŸ˜„
                                      • elmerE Offline
                                        elmer
                                        Nice Christmas gift Tig, thanks a lot, it works perfectly on my Mac.
                                        • alvisA Offline
                                          alvis
                                          Thanx TIG
                                          • guanjinG Offline
                                            guanjin
                                            TIG: Merry Christmas
                                            • 1 / 8
