    [Plugin] TIG-Smart_offset
    143 Posts 55 Posters 199.8k Views 54 Watching
    • jeff hammondJ
      i'm all greyed out (on two separate computers with different OS & different versions of sketchup on them).. will investigate more tomorrow
      (skindigo toolbar as reference to what the blue/blacks should look like)
      • N
        notareal
        Merry Christmas to you too!
          Jim
          in cmd.set_validation_proc (and other places) you want to give the full scope of the suitable? method since it is being called from SketchUp outside the scope of your module.
          Also, combine the MF_ bits.
          cmd=UI;;Command.new('TIG.Smart_offset'){self.dialog()}
          if TIG;;Smart_offsetter.suitable?()
          MF_ENABLED
          else
          MF_DISABLED | MF_GRAYED
          • cottyC
            cotty
            Nice gift! Thank you and Merry Christmas! (Are we allowed to use it before 24.12.?)
            my SketchUp gallery
              Yeeeeeeees! Works like a charm now! ๐Ÿ‘
              You are the Ruby's king! ๐Ÿ˜Ž
              And lucky because I can't more test your tricky plugin before the next year! ๐Ÿ˜„
                > MF_ENABLED
                > else
                > end
                Thanks, knew it was obvious... This only affected MACs though ???
                This was collecting dust on a virtual dust, until Pilou reminded me that I'd written it, so sometimes things get 'forgotten'... ๐Ÿ˜’
                  Here's v1.2 http://sketchucation.com/forums/viewtopic.php?p=446462#p446462
                  Further robustness in enabling/disabling/graying and suitable? tests [thanks to Jim!].
                  Seems to be especially for MACs ๐Ÿ˜„
                    Jim
                    I am not sure - it was just a guess and I don't have a Mac. Did you try it? ๐Ÿ˜†
                      I don't have a MAC either. ๐Ÿ˜•
                      Driven's reported issue was on a MAC and Jeff had other issues on a MAC too...
                      Hopefully this recent v1.2 [...20121221b.rbz !] will address the suitable? check and MF_ issues with the menus/toolbar...
                      It still works fine on a PC, but then v1.1 did too ๐Ÿ˜• ๐Ÿ˜„
                      • elmerE
                        elmer
                        Nice Christmas gift Tig, thanks a lot, it works perfectly on my Mac.
                        • alvisA
                          alvis
                          Thanx TIG
                          • guanjinG
                            guanjin
                            TIG: Merry Christmas
                            • jeff hammondJ
                              Hi Tig
                              i'm still getting the same greyed out problem.
                              is there anything i can type in the console or ?? to help figure out what the problem is?
                              thanks
                                Is there no difference at all - if you have nothing preselected, or one edge preselected, or one face preselected, or lots of things [including some edges] preselected ?
                                The menu/toolbar are only enabled if there's at least one face in the current selection.
                                The context-menu only appears if there's at least one face in the current selection.
                                Copy/paste+<enter> these into the Ruby Console and report the results:
                                with nothing preselected TIG::Smart_offsetter.suitable?()
                                with one edge preselected TIG::Smart_offsetter.suitable?()
                                with one face preselected TIG::Smart_offsetter.suitable?()
                                with lots of things [including some edges] preselected TIG::Smart_offsetter.suitable?()
                                with one edge preselected TIG::Smart_offsetter.dialog()
                                with one face preselected TIG::Smart_offsetter.dialog()
                                ๐Ÿ˜•
                                • jeff hammondJ
                                  oops ๐Ÿ˜ณ
                                  it actually is working now..
                                  it's just the toolbar that remains greyed out at all times but the menu item becomes available once an appropriate selection has been made..
                                  (which, for me personally, is fine.. i more likely than not wont want the toolbar anyway.. i think id use it with a modifier key added to my offset shortcut)
                                  • jeff hammondJ
                                    here are these results.. (since you took the time to write them.. i better take the time to report ๐Ÿ˜‰ )
                                    false
                                    false
                                    true
                                    true (drew two squares and selected all)
                                    warning- PreSelect Face[s !]
                                    ruby - nil
                                    (works as expected)
                                    • jeff hammondJ
                                      uh.. not sure what the deal is but..
                                      upon entering all of that stuff in the console, the toolbar is now working
                                      ๐Ÿ˜•
                                      [edit] but then.. i quit sketchup then relaunched and the toolbar is greyed out again regardless of selection.. the menu item is working though
                                      • Chris FullmerC
                                        voodoo. definitely voodoo at work here.
                                        • jeff hammondJ
                                          ha.. that darn voodoo! ๐Ÿ˜„
                                          some more info:
                                          so here's what the deal with the toolbar is.. (in this example, i have 3 squares with faces drawn)
                                          โ€ขcmmdA (select all)
                                          โ€ขtoolbar remains greyed out (menu item is live)
                                          โ€ขdo something else (rotate, pan, etc)
                                          โ€ขtoolbar becomes active
                                          โ€ขdeselect all
                                          โ€ขtoolbar remains active (menu item greys out)
                                          โ€ขdo something else (switch tool, orbit, etc)
                                          โ€ขtoolbar greys out
                                          so it appears, on mac, that something has to happen other than simply selecting in order to jump start the toolbar into updating it's state
                                          • C
                                            ccbiggs
                                            Hey Tig,
                                            I am getting the same thing Jeff has. But since Jeff actually knows what he is doing, he can do the ruby troubleshooting. Will stay tuned to see what you fellas figure out.
                                            It works great on my windows machine at home.
                                            Thanks Tig
                                            Update
                                            Jeff says his works. It does not work on my mac.
                                            false
                                            false
                                            true
                                            true
                                            TIG.Smart_offset:
                                            PreSelect Face[s] !
                                            Offset [+/-ve=out/
                                            My drop down "Tools" Menu works with a face preselected. The toolbar does not.
                                            Nothing works with just edges selected.
                                            If you need me to check anything else, and I do not get right back to ya, I am not ignoring you I am just here there and everywhere today.
                                            • 2 / 8
