    [Plugin] FredoTools::ThruPaint - v1.3a - 20 Oct 16
    331 Posts 102 Posters 525.5k Views 102 Watching
    • fredo6F Offline
      NEW RELEASE: ThruPaint v1.2a - 08 May 12
      This update fixes some bugs and introduces 2 functional evolutions
      1) Painting of components / groups, text labels and dimensions
      This is a new option in the palette, very similar to the native SU Paint tool. Originally, ThruPaint was painting faces within the boundaries of containers. There are however cases where you wish to assign a material to the component or group itself. This material becomes then the default material for the faces of the component
      2) Modifier for Sampler
      If you press Shift key, the cursor changes to sampling instead of painting. In the native SU Paint tool, this feature is covered by the Alt key (on Windows), but this is not possible in Ruby.
      See main post of this thread for more information on ThruPaint.
      See main post of FredoTools thread for download of FredoTools, which includes the ThruPaint script.
      • fredo6F Offline
        NEW RELEASE: ThruPaint v1.0n - 21 Apr 12
        This update introduces 2 functional evolutions
        1) Painting of a preselection of faces or edges
        If you select faces or edges before launching ThruPaint, the painted faces or edges will be those of the preselection whenever you mouse over them (regardless of the face selection settings in the palette).
        • When the material is a color or for edge painting, the painting applies to the whole pre-selection
        • When the material is a texture, you have to paint by groups of faces in the preselection
        2) Remembering of last scaling and rotation factors by material.
        This is inspired from a request by Pherim
        If you apply a textured material to a face and then scale it and/or rotate it, the scaling and rotation factors will be remembered the next time you apply this material.
        Likewise, the sampling of material within the model also copy the scaling and rotation factors.
        See main post of FredoTools thread for download of FredoTools, which includes the script.
          tomislavm
          Thank You.
          • N Offline
            numerobis
            Really a fantastic plugin! I have to say it again! Thanks a lot!
            But i have noticed a problem with exporting textured object for rendering, maxwell in my case...
            The problem is that the exporter writes a seperated material and texture for each face! So with a complex gepmetry this results in thousands of textures and materials.
            My question is now, is it possible to avoid this behavior? I'm painting as QuadMesh.
            Or is this problem maxwell related? I noticed the same thing when i use photomatch for texturing.
            Can anyone say how this works with vray?
            edit: ok, problem solved... disabling texture distortions in maxwell uv export options did it. I thought this would result in distorted mapping but for now it works.
            Thanks again for this incredible tool, Fredo!!!
            Trimble should buy this from you as standart mapping method! 😎
              shri
              many many thanks for your great tool.. πŸ‘
              • majidM Offline
                majid
                unique genius Fredeo!!!!! many many thank you, this is greaaat
                • pietervP Offline
                  pieterv
                  Hey Fredo,
                  Thanks a lot for the great plugin! You are a hero.
                  I have a slight problem tho. I used your plugin and in sketchup it looks like this
                  http://www.citypixels.be/wp-content/uploads/2012/10/sketchup-thrupaint-01.png
                  but when I render it in Maxwell Render it looks like this:
                  http://www.citypixels.be/wp-content/uploads/2012/10/simpel-huis-render-017.jpg
                  The yellow stones in the little wall have become much smaller and the middle part of the street has become darker. Do you have an idea what the problem could be?
                  Pieter
                  This is my website:
                  Citypixels - 3d Visualisatie Architectuur
                    Check if the two surfaces have the material applied in a different way.
                    I suspect that one has the material applied to the face itself while the other has the material applied to the 'container' [group/component-instance] - check this by using 'Entity Info' and selecting the actual faces in each case - the 'mapping' cannot persist into exported formats when applied to a container rather than the face itself... Of course it might be a Maxwell issue with it mis-handing the UVmapping ?
                      Contact Maxwell support - as this is their render engine that doesn't properly process the UV mapping.
                      • pietervP Offline
                        pieterv
                        I have checked, and the two materials are axactly the same. I have the free version of Maxwell Render, so I'll repost this under "extensions & applications". Thanks for answering!
                        This is my website:
                          I'd still recommend you contact Maxwell - as this would then be something that presumably affects all users. Reporting issues to the developers is important - otherwise it'll never get fixed.
                            cadmunkey
                            Is this plugin for premium members only? If I click the download icon I get a banner.png.
                            • massimoM Offline
                              massimo Moderator
                              ThruPaint is installed as part of FredoTools.. It requires LibFredo6 4.4 or above.
                              See the main post for this plugin for Installation of FredoTools
                              So you have to go to Fredo tools thread to download the plugin. Scroll down the page and you'll find it below the "download" icon.
                                cadmunkey
                                Cheers!
                                • masterpaulM Offline
                                  masterpaul
                                  I cant seem to texture this irregular surface, it just wont do it, textures wont align no matter what, and they also rotated differently everywhere.
                                  Edit: Uploaded the file also.
                                  Trickeywall.skp
                                  • fredo6F Offline
                                    The surafce is very 'irregular' actually. Unless it is made of Quads (with Thomthom's convention), I am afraid it cannot be properly mapped with ThruPaint.
                                    I would recommend you try with SketchUV plugin, which is more specialized in UV-mapping any kind of surface.
                                      masterpaul
                                      Thanks πŸ˜„
                                      • OxerO Offline
                                        Oxer
                                        Hi Fredo,
                                        I'm user of Thea4SU plugin and I have found a conflict with your plugin, before to install Thea4SU, ThruPaint worked fine but after, it appears this Error in Ruby Console:
                                        I don't know if you can help me, I'll comment it to Tomasz (plugin developer) too.
                                        • fredo6F Offline
                                          Oxer,
                                          Thanks for signaling.
                                          Could you type the following in the Ruby console and send me the output
                                          Sketchup.read_default "FredoTools_ThruPaint", "Param"
                                          • OxerO Offline
                                            Oxer
                                            This is the output in Ruby Console:
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 16 / 17
