    Sample Model for Rendering - Water
    25 Posts 17 Posters 6.9k Views 17 Watching
    • Al HartA Offline
      Al Hart
      Nice work on the video.
      It really highlights how the water is a procedural bump map and not just a flat material
      Al Hart
      IRender nXt from Render Plus
      • jo-keJ Offline
        jo-ke
        left all materials, changed only settings and bumps,
        placed lights, placed a background sphere
        removed backsides,
        took a rough water procedural (by madjid)
        used twilight render Preset low
        no postpro
        http://www.zz7.de
          pibuz
          Nice scene Al!
          Could you post a v7 skp file too?
          WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
          • Al HartA Offline
            Al Hart
            @pibuz said:
            Nice scene Al!
            Tye 3D Warehouse page has both SU7 and SU8 downloads: D Warehouse page
            Al Hart
            • Al HartA Offline
              Al Hart
              For this image, I placed some lights below the water level, turned off the sun, turned down the sun and placed a procedural bump on on the water, and zoomed in on the shark.
              Rendered with IRender nXt - using alternate Rendering Engine 4 - which s better for caustic effects. Allowed to "cook" overnight for 625 passes. No post-processing
              Al Hart
              • V Offline
                vidy
                using Renderin, no post pro, everything pretty much what is existing on the file, just touch it with reflection and refraction only, for night scene added illumination on existing spot light and adding pool light.
                Rendered on my AMD Dual Core 2.61 GHz, 1 GB RAM (pretty cheap old spec here)
                regards,
                rendered time 34 minutes
                rendered time 5 Hr
                still so much to learn..
                • massimoM Offline
                  massimo Moderator
                  The shark attacks! 😮
                  A very quick set up, just trying out some (true) sun pool caustics with Thea's new TR1 improved preset. Motion blur and CRF in Thea and only a very slight colour correction in post pro.
                  • O Offline
                    Ollo81
                    Here is my attempt. This was a 3 and a half hour render with 70 passes using Thea with TR1. I kept the original materials and only added custom bump and reflection maps. I also did some post processing work with Gimp and DenoiseMyImage_Free. The HDR image that I used is form http://www.hdrlabs.com
                      sketchgeek
                      Good thread - like seeing the different styles/rendering engines. My attempt with Lumion. Left all the original materials.
                      (edit: forgot to post the stats - scene setup time approx 30-40mins. render time approx 7 secs. No post work)
                      Marc
                      • V Offline
                        vidy
                        indeed.. i'd love to see all the render that provides for SU..(i know it's a long listing) but it will be very fun..
                        unity in diversity 👍
                        regards,
                          pibuz
                          @al hart said:
                          @pibuz said:
                          Nice scene Al!
                          ....so sorry Al... 😳 😳 😳
                          Thanks....
                          • micioneM Offline
                            micione
                            Hello, Here is a test Renditioner. time: 4 minutes.
                              giomelkadze
                              Hi, anyone can you teach me how do same realistic water with twilight render, i want to get realistic transparent water. thanks.
                                jpalm32
                                Why don't you post on Twilight site?
                                They have plenty of examples and tuts.
                                • jo-keJ Offline
                                  jo-ke
                                  Download majid's poolwater, it works fine
                                  http://www.zz7.de
                                    kaas
                                    Here a go at this scene with LightUp.
                                    Added some light emitters in front of the windows. Changed the transparency of the roof because the scene was too bright. Changed several materials, added a watershader, turned some backfaces. Added a hdr as a background and as lighting source from http://www.hdrlabs.com
                                    Calculation time: 6 minutes 15 seconds.
                                    Edit:No post-processing.
                                    Greetings, Max
                                      Brighter3D
                                      Brighter3D 1.15.0 PRO, 283 seconds (a lot of time for antialiasing),
                                      daylight + HDR as a background,
                                      P3 tone mapper with contrast and glare
                                      • V Offline
                                        vidy
                                        @rick27 said:
                                        I am a member at his forum for some time now, but never really posted something.
                                        When i saw this thread i decided to give it a try:
                                        Rick.
                                        Hi Rick,
                                        Mind to shared us about the render engine you use, and what time it takes to render it?
                                        Regards
                                        VD
                                          Rick27
                                          Helle everyone,
                                          EDIT: i used kerkythea MLT, did some noise reduction, aprox. 4hours render time.
                                          Rick.
                                          • regnarR Offline
                                            regnar
                                            Seeing this old thread reminded me of a couple renders I had
                                            done last August, but haven't posted.
                                            The rendering where done in Maxwell Render Suite Ver 2.7
                                            the sample levels for both images where around 13.0 with a
                                            rendering time of hour and forty minutes and a benchmark of 146
                                            View 1
                                            View 2
                                            Windows 10 Professional 64 bit
                                            Intel I9 7900X Asus Prime X299-Delux
                                            EVGA GeForce RTX 3080 TI 12gb
                                            64 GB Ram Samsung 960 EVO Series 1TB PCIe NVMe M.2
                                            • 2 / 2
