    Sample Model for Rendering - Water
    25 Posts 17 Posters 8.3k Views 17 Watching
    • CarlohC Offline
      Carloh
      once again an attempt with lumion free version.
      • CarlohC Offline
        Carloh
        as lumion is almost predicted for it i also made a quick animation.
        • Al HartA Offline
          Al Hart
          Nice work on the video.
          It really highlights how the water is a procedural bump map and not just a flat material
          Al Hart
          IRender nXt from Render Plus
          • jo-keJ Offline
            jo-ke
            left all materials, changed only settings and bumps,
            placed lights, placed a background sphere
            removed backsides,
            took a rough water procedural (by madjid)
            used twilight render Preset low
            no postpro
            http://www.zz7.de
              pibuz
              Nice scene Al!
              Could you post a v7 skp file too?
              WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
              • Al HartA Offline
                Al Hart
                @pibuz said:
                Nice scene Al!
                Tye 3D Warehouse page has both SU7 and SU8 downloads: D Warehouse page
                Al Hart
                • Al HartA Offline
                  Al Hart
                  For this image, I placed some lights below the water level, turned off the sun, turned down the sun and placed a procedural bump on on the water, and zoomed in on the shark.
                  Rendered with IRender nXt - using alternate Rendering Engine 4 - which s better for caustic effects. Allowed to "cook" overnight for 625 passes. No post-processing
                  Al Hart
                  • V Offline
                    vidy
                    using Renderin, no post pro, everything pretty much what is existing on the file, just touch it with reflection and refraction only, for night scene added illumination on existing spot light and adding pool light.
                    Rendered on my AMD Dual Core 2.61 GHz, 1 GB RAM (pretty cheap old spec here)
                    regards,
                    rendered time 34 minutes
                    rendered time 5 Hr
                    still so much to learn..
                    • massimoM Offline
                      massimo Moderator
                      The shark attacks! 😮
                      A very quick set up, just trying out some (true) sun pool caustics with Thea's new TR1 improved preset. Motion blur and CRF in Thea and only a very slight colour correction in post pro.
                      • O Offline
                        Ollo81
                        Here is my attempt. This was a 3 and a half hour render with 70 passes using Thea with TR1. I kept the original materials and only added custom bump and reflection maps. I also did some post processing work with Gimp and DenoiseMyImage_Free. The HDR image that I used is form http://www.hdrlabs.com
                          sketchgeek
                          Good thread - like seeing the different styles/rendering engines. My attempt with Lumion. Left all the original materials.
                          (edit: forgot to post the stats - scene setup time approx 30-40mins. render time approx 7 secs. No post work)
                          Marc
                          • V Offline
                            vidy
                            indeed.. i'd love to see all the render that provides for SU..(i know it's a long listing) but it will be very fun..
                            unity in diversity 👍
                            regards,
                              pibuz
                              @al hart said:
                              @pibuz said:
                              Nice scene Al!
                              ....so sorry Al... 😳 😳 😳
                              Thanks....
                              • micioneM Offline
                                micione
                                Hello, Here is a test Renditioner. time: 4 minutes.
                                  giomelkadze
                                  Hi, anyone can you teach me how do same realistic water with twilight render, i want to get realistic transparent water. thanks.
                                    jpalm32
                                    Why don't you post on Twilight site?
                                    They have plenty of examples and tuts.
                                    • jo-keJ Offline
                                      jo-ke
                                      Download majid's poolwater, it works fine
                                      http://www.zz7.de
                                        kaas
                                        Here a go at this scene with LightUp.
                                        Added some light emitters in front of the windows. Changed the transparency of the roof because the scene was too bright. Changed several materials, added a watershader, turned some backfaces. Added a hdr as a background and as lighting source from http://www.hdrlabs.com
                                        Calculation time: 6 minutes 15 seconds.
                                        Edit:No post-processing.
                                        Greetings, Max
                                          Brighter3D
                                          Brighter3D 1.15.0 PRO, 283 seconds (a lot of time for antialiasing),
                                          daylight + HDR as a background,
                                          P3 tone mapper with contrast and glare
                                          • V Offline
                                            vidy
                                            @rick27 said:
                                            I am a member at his forum for some time now, but never really posted something.
                                            When i saw this thread i decided to give it a try:
                                            Rick.
                                            Hi Rick,
                                            Mind to shared us about the render engine you use, and what time it takes to render it?
                                            Regards
                                            VD
