    Sample Model for Rendering - Water
    25 Posts 17 Posters 7.9k Views 17 Watching
    • jo-keJ Offline
      jo-ke
      left all materials, changed only settings and bumps,
      placed lights, placed a background sphere
      removed backsides,
      took a rough water procedural (by madjid)
      used twilight render Preset low
      no postpro
      http://www.zz7.de
        pibuz
        Nice scene Al!
        Could you post a v7 skp file too?
        WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
        • Al HartA Offline
          Al Hart
          @pibuz said:
          Nice scene Al!
          Tye 3D Warehouse page has both SU7 and SU8 downloads: D Warehouse page
          Al Hart
          IRender nXt from Render Plus
          • Al HartA Offline
            Al Hart
            For this image, I placed some lights below the water level, turned off the sun, turned down the sun and placed a procedural bump on on the water, and zoomed in on the shark.
            Rendered with IRender nXt - using alternate Rendering Engine 4 - which s better for caustic effects. Allowed to "cook" overnight for 625 passes. No post-processing
            Al Hart
            • V Offline
              vidy
              using Renderin, no post pro, everything pretty much what is existing on the file, just touch it with reflection and refraction only, for night scene added illumination on existing spot light and adding pool light.
              Rendered on my AMD Dual Core 2.61 GHz, 1 GB RAM (pretty cheap old spec here)
              regards,
              rendered time 34 minutes
              rendered time 5 Hr
              still so much to learn..
              • massimoM Offline
                massimo Moderator
                The shark attacks! 😮
                A very quick set up, just trying out some (true) sun pool caustics with Thea's new TR1 improved preset. Motion blur and CRF in Thea and only a very slight colour correction in post pro.
                • O Offline
                  Ollo81
                  Here is my attempt. This was a 3 and a half hour render with 70 passes using Thea with TR1. I kept the original materials and only added custom bump and reflection maps. I also did some post processing work with Gimp and DenoiseMyImage_Free. The HDR image that I used is form http://www.hdrlabs.com
                    sketchgeek
                    Good thread - like seeing the different styles/rendering engines. My attempt with Lumion. Left all the original materials.
                    (edit: forgot to post the stats - scene setup time approx 30-40mins. render time approx 7 secs. No post work)
                    Marc
                    • V Offline
                      vidy
                      indeed.. i'd love to see all the render that provides for SU..(i know it's a long listing) but it will be very fun..
                      unity in diversity 👍
                      regards,
                        pibuz
                        @al hart said:
                        @pibuz said:
                        Nice scene Al!
                        ....so sorry Al... 😳 😳 😳
                        Thanks....
                        • micioneM Offline
                          micione
                          Hello, Here is a test Renditioner. time: 4 minutes.
                            giomelkadze
                            Hi, anyone can you teach me how do same realistic water with twilight render, i want to get realistic transparent water. thanks.
                              jpalm32
                              Why don't you post on Twilight site?
                              They have plenty of examples and tuts.
                              • jo-keJ Offline
                                jo-ke
                                Download majid's poolwater, it works fine
                                http://www.zz7.de
                                  kaas
                                  Here a go at this scene with LightUp.
                                  Added some light emitters in front of the windows. Changed the transparency of the roof because the scene was too bright. Changed several materials, added a watershader, turned some backfaces. Added a hdr as a background and as lighting source from http://www.hdrlabs.com
                                  Calculation time: 6 minutes 15 seconds.
                                  Edit:No post-processing.
                                  Greetings, Max
                                    Brighter3D
                                    Brighter3D 1.15.0 PRO, 283 seconds (a lot of time for antialiasing),
                                    daylight + HDR as a background,
                                    P3 tone mapper with contrast and glare
                                    • V Offline
                                      vidy
                                      @rick27 said:
                                      I am a member at his forum for some time now, but never really posted something.
                                      When i saw this thread i decided to give it a try:
                                      Rick.
                                      Hi Rick,
                                      Mind to shared us about the render engine you use, and what time it takes to render it?
                                      Regards
                                      VD
                                        Rick27
                                        Helle everyone,
                                        EDIT: i used kerkythea MLT, did some noise reduction, aprox. 4hours render time.
                                        Rick.
                                        • regnarR Offline
                                          regnar
                                          Seeing this old thread reminded me of a couple renders I had
                                          done last August, but haven't posted.
                                          The rendering where done in Maxwell Render Suite Ver 2.7
                                          the sample levels for both images where around 13.0 with a
                                          rendering time of hour and forty minutes and a benchmark of 146
                                          View 1
                                          View 2
                                          Windows 10 Professional 64 bit
                                          Intel I9 7900X Asus Prime X299-Delux
                                          EVGA GeForce RTX 3080 TI 12gb
                                          64 GB Ram Samsung 960 EVO Series 1TB PCIe NVMe M.2
                                            dtrarch
                                            Artlantis 4.1 added to the mix
                                            Water fresnel shader
                                            No post-pro anything
                                            Just water adjustment.
                                            3:0 minutes
                                            3200 px
                                            i7 quad
                                            Win 7 Pro
                                            dtr
