    Custom components import to origin...???
    36 Posts 5 Posters 3.4k Views 5 Watching
    • utilerU
      utiler
      I'm currently on my machine at home and tried it her; your way works fine, Dave!!! I'll give it a try when I get to work....
      Cheers! πŸ‘
      Just Curious...
        @utiler said:
        Anyway, what is the second pane for?
        It's for saving components the easy way. It also gives you access to two different libraries at the same time. Neither one has to be set to In Model. The cool thing on the PC is that the Materials browser works exactly the same way. So you can create materials in a SketchUp model and save them off for use later by dragging their thumbnails from one library to the other.
        I'm glad that method worked for you.
          The 'lock' icon is bitlocker that bundled in Win Pro/Ultmate. It encrypts files.
          • utilerU
            utiler
            And how do I get rid of it...?
            Just Curious...
            • utilerU
              utiler
              Just tried it on my work machine, Dave..... no good; still snaps to the origin!!!! 😑 😑 😑
              Just Curious...
                Did you try it with a new component?
                • utilerU
                  utiler
                  Yep, created a new one....
                  I think I might re-install SU completely this weekend. It'll take for ever to try and work out what this problem is.... 😠
                  Just Curious...
                    Andrew, before you reinstall SU, try renaming your Plugins folder so the plugins don't load and see what happens.
                      No such app
                      (lmgtfy.com)
                      • utilerU
                        utiler
                        I will try that, Dave. πŸ‘
                        Thanks Rich, silly question I guess..... πŸ˜‰
                        Just Curious...
                        • utilerU
                          utiler
                          So after much hair pulling, a total re-install and numerous trouble shooting ebbs and flow I realised it was something with my template file that was causing the problem. I may have avoided the the re-install but SU has never looked so good with all the unused crap I have loaded over the years....!
                          Thanks for helping out guys; if there's one on-line community that feels line we are all under the same roof its this one.... πŸŽ‰
                          πŸ‘
                          Now, where's that Pinterest link.....
                          Just Curious...
                          • O
                            optimaforever
                            πŸ‘
                            Hello, can you develop please?
                            I have the same issue with several of my components that import exactly at the origin and I can't avoid that. When working with heavy models it's always a pita to have to dezoom to pick the compo at 0,0,0 and move it to the wanted place...
                              If a model [or a component created from it] is 'geo-located' then the first time it's inserted in a new model it snaps to the origin with no user input.
                              To avoid this remove the component's geo-location under the relevant item in its Model Info.
                              Always take care with imported SKPs that they are not geo-located !
                              • O
                                optimaforever
                                Ah! interesting info, thanks Tig!
                                  You could try running some code in the Ruby Console...
                                  e.g. this might remove the geo-location from all of your model's current component definitions...
                                  Sketchup.active_model.definitions.each{|d| d.attribute_dictionaries.delete("GeoReference") }
                                    Can you access this 'geo remove' data via api? Would be a nice addition to your Purge plugin.
                                    • utilerU
                                      utiler
                                      Agreed Rich!!
                                      Just Curious...
                                        I've looked at automating this but my suggested fix seems to fail when resetting the component's attributes....
                                        So I won't be adding it to PurgeAll any time soon 😞
                                        • 2 / 2
