    Custom components import to origin...???
    36 Posts 5 Posters 3.1k Views 5 Watching
      The 'lock' icon is bitlocker that bundled in Win Pro/Ultmate. It encrypts files.
      • utilerU
        utiler
        And how do I get rid of it...?
        Just Curious...
        • utilerU
          utiler
          @dave r said:
          I'm glad that method worked for you.
          Just tried it on my work machine, Dave..... no good; still snaps to the origin!!!! 😑 😑 😑
          Just Curious...
            Did you try it with a new component?
            • utilerU
              utiler
              Yep, created a new one....
              I think I might re-install SU completely this weekend. It'll take for ever to try and work out what this problem is.... 😠
              Just Curious...
                Andrew, before you reinstall SU, try renaming your Plugins folder so the plugins don't load and see what happens.
                  No such app
                  (lmgtfy.com)
                  • utilerU
                    utiler
                    I will try that, Dave. πŸ‘
                    Thanks Rich, silly question I guess..... πŸ˜‰
                    Just Curious...
                    • utilerU
                      utiler
                      So after much hair pulling, a total re-install and numerous trouble shooting ebbs and flow I realised it was something with my template file that was causing the problem. I may have avoided the the re-install but SU has never looked so good with all the unused crap I have loaded over the years....!
                      Thanks for helping out guys; if there's one on-line community that feels line we are all under the same roof its this one.... πŸŽ‰
                      πŸ‘
                      Now, where's that Pinterest link.....
                      Just Curious...
                      • O
                        optimaforever
                        πŸ‘
                        Hello, can you develop please?
                        I have the same issue with several of my components that import exactly at the origin and I can't avoid that. When working with heavy models it's always a pita to have to dezoom to pick the compo at 0,0,0 and move it to the wanted place...
                          If a model [or a component created from it] is 'geo-located' then the first time it's inserted in a new model it snaps to the origin with no user input.
                          To avoid this remove the component's geo-location under the relevant item in its Model Info.
                          Always take care with imported SKPs that they are not geo-located !
                          • O
                            optimaforever
                            Ah! interesting info, thanks Tig!
                              You could try running some code in the Ruby Console...
                              e.g. this might remove the geo-location from all of your model's current component definitions...
                              Sketchup.active_model.definitions.each{|d| d.attribute_dictionaries.delete("GeoReference") }
                                Can you access this 'geo remove' data via api? Would be a nice addition to your Purge plugin.
                                • utilerU
                                  utiler
                                  Agreed Rich!!
                                  Just Curious...
                                    I've looked at automating this but my suggested fix seems to fail when resetting the component's attributes....
                                    So I won't be adding it to PurgeAll any time soon 😞
                                    • 2 / 2
