    Custom components import to origin...???
    36 Posts 5 Posters 2.9k Views 5 Watching
    • utilerU Offline
      utiler
      @dave r said:
      I'm glad that method worked for you.
      Just tried it on my work machine, Dave..... no good; still snaps to the origin!!!! 😑 😑 😑
      Just Curious...
        Did you try it with a new component?
        • utilerU Offline
          utiler
          Yep, created a new one....
          I think I might re-install SU completely this weekend. It'll take for ever to try and work out what this problem is.... 😠
          Just Curious...
            Andrew, before you reinstall SU, try renaming your Plugins folder so the plugins don't load and see what happens.
              @utiler said:
              And how do I get rid of it...?
              No such app
              (lmgtfy.com)
              • utilerU Offline
                utiler
                I will try that, Dave. πŸ‘
                Thanks Rich, silly question I guess..... πŸ˜‰
                Just Curious...
                • utilerU Offline
                  utiler
                  So after much hair pulling, a total re-install and numerous trouble shooting ebbs and flow I realised it was something with my template file that was causing the problem. I may have avoided the the re-install but SU has never looked so good with all the unused crap I have loaded over the years....!
                  Thanks for helping out guys; if there's one on-line community that feels line we are all under the same roof its this one.... πŸŽ‰
                  πŸ‘
                  Now, where's that Pinterest link.....
                  Just Curious...
                  • O Offline
                    optimaforever
                    πŸ‘
                    Hello, can you develop please?
                    I have the same issue with several of my components that import exactly at the origin and I can't avoid that. When working with heavy models it's always a pita to have to dezoom to pick the compo at 0,0,0 and move it to the wanted place...
                      If a model [or a component created from it] is 'geo-located' then the first time it's inserted in a new model it snaps to the origin with no user input.
                      To avoid this remove the component's geo-location under the relevant item in its Model Info.
                      Always take care with imported SKPs that they are not geo-located !
                      • O Offline
                        optimaforever
                        Ah! interesting info, thanks Tig!
                          You could try running some code in the Ruby Console...
                          e.g. this might remove the geo-location from all of your model's current component definitions...
                          Sketchup.active_model.definitions.each{|d| d.attribute_dictionaries.delete("GeoReference") }
                            Can you access this 'geo remove' data via api? Would be a nice addition to your Purge plugin.
                            • utilerU Offline
                              utiler
                              Agreed Rich!!
                              Just Curious...
                                I've looked at automating this but my suggested fix seems to fail when resetting the component's attributes....
                                So I won't be adding it to PurgeAll any time soon 😞
                                • 2 / 2
