    Custom components import to origin...???
    36 Posts 5 Posters 2.9k Views 5 Watching
    • utilerU Offline
      utiler
      Dave - I did all that you said and re-inserted it (from within the drawing) and it works fine everytime...... Yes, my insertion point for the basin is 800mm from the floor and centred on the basin so I can locate it as needed from a known point. Save for the toilet; centre of the toilet (common point of the mirrored halves).
      It is when I save it to a folder and insert it from the Components dialogue that is snaps to the origin.
      TIG - I originally set my axis locations to the preferred insertion point for both the sub-component and also the parent but the problem still arises when inserted from the Component Browser of a common library.
      It's got me buggered...
      Just Curious...
        So what happens if you drag the component from the In Model components library to a local collection in the secondary pane of the Components browser. That's the way I always save components for later use and I never have this problem.
        • utilerU Offline
          utiler
          Haven't done that, Dave but will try it. Always used the 'Save as' function....
          Actually it doesn't seem you can have a secondary pane open Dave. Unless you are doing so in another instance of SU...
          Just Curious...
          • utilerU Offline
            utiler
            Ok, another thing.... I know I've posed the question before as to why by files have a gold lock shown on it in explorer..... something to do with 'read only' but not sure why it does this by default and if that has something to do with this issue.....
            And how do you avoid this gold lock from appearing.
            Just Curious...
            • utilerU Offline
              utiler
              Here's a quick workflow of my issue.
              1. Make a BOX component
              2. Change axis [not critical; the problem even eveidenet if it is left alone...]
              3. Re-insert it from 'Components in Model' Dialogue - no problem
              4. Right-click and 'Save as' to a Google Components directory
              5. Close SU and re-open
              6. Import the component from Google Components directory - it snaps straight to the origin of the SU drawing...
              I had to link it to Dropbox as the short video was a little too large to post:
              https://dl.dropbox.com/u/50004821/ComponentIssue.swf
              I really don't know why all of a sudden this is happening. FWIW, I also tried on a colleagues machine and the exact same thing happened!! πŸ‘Ώ
              Just Curious...
                So what happens if you do it my way?
                4. Open secondary pane in Components browser and open the folder in which you want to store the component
                5. Click and drag on the thumbnail of the component in the In Model pane. Drag it to the secondary pane.
                6. Close SU and re-open
                7. Choose the library where you saved the component.
                8. Select the component and bring it into the model.
                • utilerU Offline
                  utiler
                  In a new file of SU, Dave? Is that what you mean by secondary pane..?
                  Just Curious...
                    No, the secondary pane is part of the Components browser.
                    http://farm9.staticflickr.com/8026/7602450436_463c6dfd16_o.png
                    You get to it by clicking on the little '+' in the upper right corner, above.
                    http://farm9.staticflickr.com/8160/7602450592_2a70da122a_o.png
                    With the secondary pane open, click on its 'Details' icon, the black arrow pointing to the right of the search line where it says, "Google". Choose 'Open or create a local collection' and navigate to the folder in which you want to save your components. After choosing the folder, click on that arrow button again and choose 'Add to favorites.'
                    http://farm9.staticflickr.com/8145/7602450186_772d375171_o.png
                    Click and drag the thumbnail from the In Model library in the top pane to the local collection library in the bottom one. The component is now saved for later use. It might seem like more work than what you're doing but once the local collection is added to your favorites, it'll be in the drop down list accessed from the drop down arrow to the left of the search line. You can add as many collections as you want to that list.
                    http://farm9.staticflickr.com/8002/7602450348_e5705c1f42_o.png
                    NOW, in a new SketchUp session, click on the thumbnail of the component and bring it into the model. Do you get the results you want?, then?
                    • utilerU Offline
                      utiler
                      Ah, that secondary pane..... never use it; hence the confustion... πŸ˜„
                      I'll give it a go, Dave. πŸ‘
                      Anyway, what is the second pane for?
                      Just Curious...
                      • utilerU Offline
                        utiler
                        I'm currently on my machine at home and tried it her; your way works fine, Dave!!! I'll give it a try when I get to work....
                        Cheers! πŸ‘
                        Just Curious...
                          It's for saving components the easy way. It also gives you access to two different libraries at the same time. Neither one has to be set to In Model. The cool thing on the PC is that the Materials browser works exactly the same way. So you can create materials in a SketchUp model and save them off for use later by dragging their thumbnails from one library to the other.
                          I'm glad that method worked for you.
                            The 'lock' icon is bitlocker that bundled in Win Pro/Ultmate. It encrypts files.
                            • utilerU Offline
                              utiler
                              And how do I get rid of it...?
                              Just Curious...
                              • utilerU Offline
                                utiler
                                Just tried it on my work machine, Dave..... no good; still snaps to the origin!!!! 😑 😑 😑
                                Just Curious...
                                  Did you try it with a new component?
                                  • utilerU Offline
                                    utiler
                                    Yep, created a new one....
                                    I think I might re-install SU completely this weekend. It'll take for ever to try and work out what this problem is.... 😠
                                    Just Curious...
                                      Andrew, before you reinstall SU, try renaming your Plugins folder so the plugins don't load and see what happens.
                                        No such app
                                        (lmgtfy.com)
                                        • utilerU Offline
                                          utiler
                                          I will try that, Dave. πŸ‘
                                          Thanks Rich, silly question I guess..... πŸ˜‰
                                          Just Curious...
                                          • utilerU Offline
                                            utiler
                                            So after much hair pulling, a total re-install and numerous trouble shooting ebbs and flow I realised it was something with my template file that was causing the problem. I may have avoided the the re-install but SU has never looked so good with all the unused crap I have loaded over the years....!
                                            Thanks for helping out guys; if there's one on-line community that feels line we are all under the same roof its this one.... πŸŽ‰
                                            πŸ‘
                                            Now, where's that Pinterest link.....
                                            Just Curious...
