    Custom components import to origin...???
    36 Posts 5 Posters 2.9k Views 5 Watching
      @utiler said:
      And how do I get rid of it...?
      No such app
      (lmgtfy.com)
      • utilerU Offline
        utiler
        I will try that, Dave. πŸ‘
        Thanks Rich, silly question I guess..... πŸ˜‰
        Just Curious...
        • utilerU Offline
          utiler
          So after much hair pulling, a total re-install and numerous trouble shooting ebbs and flow I realised it was something with my template file that was causing the problem. I may have avoided the the re-install but SU has never looked so good with all the unused crap I have loaded over the years....!
          Thanks for helping out guys; if there's one on-line community that feels line we are all under the same roof its this one.... πŸŽ‰
          πŸ‘
          Now, where's that Pinterest link.....
          Just Curious...
          • O Offline
            optimaforever
            πŸ‘
            Hello, can you develop please?
            I have the same issue with several of my components that import exactly at the origin and I can't avoid that. When working with heavy models it's always a pita to have to dezoom to pick the compo at 0,0,0 and move it to the wanted place...
              If a model [or a component created from it] is 'geo-located' then the first time it's inserted in a new model it snaps to the origin with no user input.
              To avoid this remove the component's geo-location under the relevant item in its Model Info.
              Always take care with imported SKPs that they are not geo-located !
              • O Offline
                optimaforever
                Ah! interesting info, thanks Tig!
                  You could try running some code in the Ruby Console...
                  e.g. this might remove the geo-location from all of your model's current component definitions...
                  Sketchup.active_model.definitions.each{|d| d.attribute_dictionaries.delete("GeoReference") }
                    Can you access this 'geo remove' data via api? Would be a nice addition to your Purge plugin.
                    • utilerU Offline
                      utiler
                      Agreed Rich!!
                      Just Curious...
                        I've looked at automating this but my suggested fix seems to fail when resetting the component's attributes....
                        So I won't be adding it to PurgeAll any time soon 😞
                        • 2 / 2
