    [Plugin] FredoTools::ThruPaint - v1.3a - 20 Oct 16
    331 Posts 102 Posters 610.7k Views 102 Watching
    • W
      wolfy
      @wolfy said:
      @wolfi
      Just a few other questions, as I am unable to reproduce it (and apparently it does not happen for the first users of ThruPaint)
      1. Which version of SU
      2. After you use ThruPaint with a material in the model (so no bugsplat) and you try a material in the Library, do you still get a bugsplat?
      3. do you get a bugsplat if instead of a group, you paint a shape at top level of the model, or a true Component?
      Fredo,
      It seems to work beautifully on my work computer. ☀
      I will reinstall again and hopefully eliminate this bugsplat deal.
      Thank you for your responses and I'll be sure to post my reinstall status.
      Hi Fredo,
      Well the bugsplat continues on my laptop. I've installed the new version with the same result.
      Again, if the material already lives in the model it works just great. Only when a new material is applied using the plugin do I get a bugsplat.
      I've tried all types of shapes, groups, components, materails, you name it, all with the same result.
      I'm using the latest version of SU Pro, Windows 7 64 bit if that helps, and all your other plugins run perfectly smooth.
      Thanks again Fredo for your excellent work!
      • fredo6F
        @wolfi,
        It might be a conflict with another plugin, which you would not have in the PC at the office.
        Do you have any plugins dealing with materials or UV mapping?
        For this, ould you type in the Ruby Console Sketchup::Material.instance_methods.join("\n") and advise on what it returns.
        • sadyoS
          sadyo
          This is an Awesome Plugin Mr Fredo,
          Just wanna ask, how to get rid or fixing these Red area beside click the Esc button?
          http://photoserver.ws/images/30gI4f8a92aa048fa.jpg
          And one thing,
          If i'm using the Natural UV, material on the Top is look nice, but look a bit mesh at the back.
          http://photoserver.ws/images/X1Sv4f8a9608d00fc.jpg
          Is that something i should do ❓
          Thanks Mr. Fredo
          • fredo6F
            @sadyo
            In the case of your cushion, you could maybe split it in 2 symmetrical parts since the upper face and borders looks fine.
            The Mesh UV mode looks less adpated because the shape is not generated as a Quadface mesh but with random triangles. Visually, you could however make it a quad mesh if you guide the reconstruction of the mesh by marking diagonals.
            Keep in mind that ThruPaint is not at all an UV Mapping tool (you should use SketchUV for that). The natural mode just extend the UVs of the initial face to all adjacent faces with a few corrections. But it cannot solve the geometrical problem that it is not possible to warp an arbitray 3D Shape with a flat piece of paper.
              rv1974
              Fredo this is yet another pearl!
              A couple of questions\wishes:
              1/ How could I get back the native Alt-key eyedropper?
              2/ How to correct the UVW mapping on the surface #1 (see attached)?
              3/ If only the Thrupaint could bend the textures along selected curves (AB) (upon unquadrified surfaces (#2) it'd really amazing!
              Thank you for your efforts!
              asphalt.skp
              • fredo6F
                You can call the native Paint Tool from ThruPaint (key F9 or small button on the right of palette).
                There is a sampler in ThruPaint (press Enter when you mouseover a face), but it is restricted to the model and does not detect projected textures, as this is not available from Ruby.
                Unfortunately, this is not possible, because Sketchup uses only Perspective mapping, not bilinear mapping.
                This perspective effect is attenuated if you grid the face into smaller cells (quads or triangles), for instance with Curviloft.
                I will need to find or develop a small algorithm for quadifying a face nicely. Then you are back to case 2) above. But with a mesh which is dense enough it should work.
                  rv1974
                  what a comprehensive support! Frankly I don't deserve it )
                  The last sentence improvement would be a killer!
                  Thank you so much!
                    QuadfaceTools by Thomthom ?
                    Or the quadrilaterizer by TiG ?
                      La quadrature du cercle alors! 😉
                      • fredo6F
                        Just to be clearer, the density of the mesh is the only way to get the texture 'reasonably' distorted. When quads are too much like a triangle, the perspective distortion shifts the texture mapping.
                        In the case of your texture, that may help to do the trick, but it's a pity to have to generate so many faces
                        @Pilou
                        It is not so easy to generate the right mesh in the general case (and in this particular case).
                        ...and QuadFaceTools only manages quad meshes which it can triangulate, but not any polygon.
                        I think Whaat has developed an more adapted algorithm as part of SketchUV.
                        • alvisA
                          alvis
                          Thank you very very very very much.
                          • T
                            tina0603
                            thanks!!!!
                            • P
                              Pherim
                              Absolutely stunning! One of the best plugins I have seen so far (besides your others)! I think I will never use the native paint tool again.
                              And it's free! You are amazing!
                              • W
                                wolfy
                                @wolfi,
                                Fredo,
                                Entered your code into ruby console and it returned the following (sorry in advance for the length):
                                dclone
                                write_thumbnail
                                profile_member?
                                methods
                                attribute_dictionaries
                                get_attributes
                                remove_observer
                                instance_variable_defined?
                                taint
                                name
                                name=
                                id
                                set_attribute
                                singleton_methods
                                respond_to?
                                entityID
                                nil?
                                send
                                protected_methods
                                get_attribute
                                tainted?
                                display_name
                                untaint
                                instance_of?
                                typename
                                equal?
                                method
                                hash
                                private_methods
                                attribute_dictionary
                                send
                                materialType
                                kind_of?
                                freeze
                                eql?
                                object_id
                                has_attributes?
                                id
                                public_methods
                                instance_eval
                                deleted?
                                is_a?
                                delete_attribute
                                type
                                valid?
                                instance_variables
                                use_alpha?
                                frozen?
                                alpha
                                to_a
                                alpha=
                                class
                                instance_variable_get
                                between?
                                parent
                                color
                                to_s
                                extend
                                color=
                                clone
                                instance_variable_set
                                model
                                texture
                                inspect
                                texture=
                                display
                                add_observer
                                dup
                                  SpookyChick1013
                                  Thank You Fredo. This looks like the answer to many of my prayers. Looks like it shall be an interesting week, finally revising some old projects.
                                  https://kuromatsudriveyards.com
                                  Fo-su to tomo ni aran koto o...
                                  • C
                                    cmoreink
                                    Amazing plugin Mr. Fredo! Thank you so much for all your plugins and hard work. Can't call you a G.O.D. but you are sitting right next to him 😉
                                    my portfolio
                                    • pep75P
                                      pep75
                                      Jiiiiiihhhaaaaaaaaaaaaaaa!!!!!!! 😳
                                      • P
                                        Pherim
                                        Played around with it for quite some time now and still I am amazed about what this plugin can do.
                                        If I may ask, would it be possible to add an option that allows to chose the scale of the texture before applying it and then keep that value until it is changed? That would save a lot of time in comparison to changing the scale of each texture manually after it was applied.
                                        • fredo6F
                                          That's a good idea, but I would put it as an option.
                                          Note you can also change the material definition (i.e. the dimensions).
                                          • P
                                            Pherim
                                            Of course you can but often enough I have a model where I wish to use the same material in different scales and having an option to choose a different scale before applying a material would be great!
                                            • 16
                                            • 17
                                            • 3 / 17
