    [Plugin] FredoTools::ThruPaint - v1.3a - 20 Oct 16
    331 Posts 102 Posters 634.0k Views 102 Watching
    • charly2008C
      charly2008
      It is wonderful that here in the forum are many talented Ruby programmers. Fredo, thanks a million for this additional excellent tool.
      Charly
      • Didier BurD
        Didier Bur
        I think I'm gonna vote for you to be the next president of France...
        And I'm candidate to be his prime minister 🤣
        DB
        • fredo6F
          NEW RELEASE: ThruPaint v1.0m - 14 Apr 12
          This update fixes a few issues found in ThruPaint and integrate the translation to Spanish - Spain (Oxer), Spanish - Latin America (Defisto) and Chinese (guanjin)
          See main post of this thread for more information on ThruPaint.
          See main post of FredoTools thread for download of FredoTools, which includes the script.
          • urgenU
            urgen
            ....O-O-O! ☀ thank you Fredo! 👍
            --pupil forever...------
            • W
              wolfy
              @wolfy said:
              @wolfi
              Just a few other questions, as I am unable to reproduce it (and apparently it does not happen for the first users of ThruPaint)
              1. Which version of SU
              2. After you use ThruPaint with a material in the model (so no bugsplat) and you try a material in the Library, do you still get a bugsplat?
              3. do you get a bugsplat if instead of a group, you paint a shape at top level of the model, or a true Component?
              Fredo,
              It seems to work beautifully on my work computer. ☀
              I will reinstall again and hopefully eliminate this bugsplat deal.
              Thank you for your responses and I'll be sure to post my reinstall status.
              Hi Fredo,
              Well the bugsplat continues on my laptop. I've installed the new version with the same result.
              Again, if the material already lives in the model it works just great. Only when a new material is applied using the plugin do I get a bugsplat.
              I've tried all types of shapes, groups, components, materails, you name it, all with the same result.
              I'm using the latest version of SU Pro, Windows 7 64 bit if that helps, and all your other plugins run perfectly smooth.
              Thanks again Fredo for your excellent work!
              • fredo6F
                @wolfi,
                It might be a conflict with another plugin, which you would not have in the PC at the office.
                Do you have any plugins dealing with materials or UV mapping?
                For this, ould you type in the Ruby Console Sketchup::Material.instance_methods.join("\n") and advise on what it returns.
                • sadyoS
                  sadyo
                  This is an Awesome Plugin Mr Fredo,
                  Just wanna ask, how to get rid or fixing these Red area beside click the Esc button?
                  http://photoserver.ws/images/30gI4f8a92aa048fa.jpg
                  And one thing,
                  If i'm using the Natural UV, material on the Top is look nice, but look a bit mesh at the back.
                  http://photoserver.ws/images/X1Sv4f8a9608d00fc.jpg
                  Is that something i should do ❓
                  Thanks Mr. Fredo
                  • fredo6F
                    @sadyo
                    In the case of your cushion, you could maybe split it in 2 symmetrical parts since the upper face and borders looks fine.
                    The Mesh UV mode looks less adpated because the shape is not generated as a Quadface mesh but with random triangles. Visually, you could however make it a quad mesh if you guide the reconstruction of the mesh by marking diagonals.
                    Keep in mind that ThruPaint is not at all an UV Mapping tool (you should use SketchUV for that). The natural mode just extend the UVs of the initial face to all adjacent faces with a few corrections. But it cannot solve the geometrical problem that it is not possible to warp an arbitray 3D Shape with a flat piece of paper.
                      rv1974
                      Fredo this is yet another pearl!
                      A couple of questions\wishes:
                      1/ How could I get back the native Alt-key eyedropper?
                      2/ How to correct the UVW mapping on the surface #1 (see attached)?
                      3/ If only the Thrupaint could bend the textures along selected curves (AB) (upon unquadrified surfaces (#2) it'd really amazing!
                      Thank you for your efforts!
                      asphalt.skp
                      • fredo6F
                        You can call the native Paint Tool from ThruPaint (key F9 or small button on the right of palette).
                        There is a sampler in ThruPaint (press Enter when you mouseover a face), but it is restricted to the model and does not detect projected textures, as this is not available from Ruby.
                        Unfortunately, this is not possible, because Sketchup uses only Perspective mapping, not bilinear mapping.
                        This perspective effect is attenuated if you grid the face into smaller cells (quads or triangles), for instance with Curviloft.
                        I will need to find or develop a small algorithm for quadifying a face nicely. Then you are back to case 2) above. But with a mesh which is dense enough it should work.
                          rv1974
                          what a comprehensive support! Frankly I don't deserve it )
                          The last sentence improvement would be a killer!
                          Thank you so much!
                            QuadfaceTools by Thomthom ?
                            Or the quadrilaterizer by TiG ?
                              La quadrature du cercle alors! 😉
                              • fredo6F
                                Just to be clearer, the density of the mesh is the only way to get the texture 'reasonably' distorted. When quads are too much like a triangle, the perspective distortion shifts the texture mapping.
                                In the case of your texture, that may help to do the trick, but it's a pity to have to generate so many faces
                                @Pilou
                                It is not so easy to generate the right mesh in the general case (and in this particular case).
                                ...and QuadFaceTools only manages quad meshes which it can triangulate, but not any polygon.
                                I think Whaat has developed an more adapted algorithm as part of SketchUV.
                                • alvisA
                                  alvis
                                  Thank you very very very very much.
                                  • T
                                    tina0603
                                    thanks!!!!
                                    • P
                                      Pherim
                                      Absolutely stunning! One of the best plugins I have seen so far (besides your others)! I think I will never use the native paint tool again.
                                      And it's free! You are amazing!
                                      • W
                                        wolfy
                                        @wolfi,
                                        Fredo,
                                        Entered your code into ruby console and it returned the following (sorry in advance for the length):
                                        dclone
                                        write_thumbnail
                                        profile_member?
                                        methods
                                        attribute_dictionaries
                                        get_attributes
                                        remove_observer
                                        instance_variable_defined?
                                        taint
                                        name
                                        name=
                                        id
                                        set_attribute
                                        singleton_methods
                                        respond_to?
                                        entityID
                                        nil?
                                        send
                                        protected_methods
                                        get_attribute
                                        tainted?
                                        display_name
                                        untaint
                                        instance_of?
                                        typename
                                        equal?
                                        method
                                        hash
                                        private_methods
                                        attribute_dictionary
                                        send
                                        materialType
                                        kind_of?
                                        freeze
                                        eql?
                                        object_id
                                        has_attributes?
                                        id
                                        public_methods
                                        instance_eval
                                        deleted?
                                        is_a?
                                        delete_attribute
                                        type
                                        valid?
                                        instance_variables
                                        use_alpha?
                                        frozen?
                                        alpha
                                        to_a
                                        alpha=
                                        class
                                        instance_variable_get
                                        between?
                                        parent
                                        color
                                        to_s
                                        extend
                                        color=
                                        clone
                                        instance_variable_set
                                        model
                                        texture
                                        inspect
                                        texture=
                                        display
                                        add_observer
                                        dup
                                          SpookyChick1013
                                          Thank You Fredo. This looks like the answer to many of my prayers. Looks like it shall be an interesting week, finally revising some old projects.
                                          https://kuromatsudriveyards.com
                                          Fo-su to tomo ni aran koto o...
                                          • C
                                            cmoreink
                                            Amazing plugin Mr. Fredo! Thank you so much for all your plugins and hard work. Can't call you a G.O.D. but you are sitting right next to him 😉
                                            my portfolio
                                            • 16
                                            • 17
                                            • 3 / 17
