    [Plugin] FredoTools::ThruPaint - v1.3a - 20 Oct 16
    331 Posts 102 Posters 625.0k Views 102 Watching
    • fredo6F
      @sadyo
      In the case of your cushion, you could maybe split it in 2 symmetrical parts since the upper face and borders looks fine.
      The Mesh UV mode looks less adpated because the shape is not generated as a Quadface mesh but with random triangles. Visually, you could however make it a quad mesh if you guide the reconstruction of the mesh by marking diagonals.
      Keep in mind that ThruPaint is not at all an UV Mapping tool (you should use SketchUV for that). The natural mode just extend the UVs of the initial face to all adjacent faces with a few corrections. But it cannot solve the geometrical problem that it is not possible to warp an arbitray 3D Shape with a flat piece of paper.
        rv1974
        Fredo this is yet another pearl!
        A couple of questions\wishes:
        1/ How could I get back the native Alt-key eyedropper?
        2/ How to correct the UVW mapping on the surface #1 (see attached)?
        3/ If only the Thrupaint could bend the textures along selected curves (AB) (upon unquadrified surfaces (#2) it'd really amazing!
        Thank you for your efforts!
        asphalt.skp
        • fredo6F
          You can call the native Paint Tool from ThruPaint (key F9 or small button on the right of palette).
          There is a sampler in ThruPaint (press Enter when you mouseover a face), but it is restricted to the model and does not detect projected textures, as this is not available from Ruby.
          Unfortunately, this is not possible, because Sketchup uses only Perspective mapping, not bilinear mapping.
          This perspective effect is attenuated if you grid the face into smaller cells (quads or triangles), for instance with Curviloft.
          I will need to find or develop a small algorithm for quadifying a face nicely. Then you are back to case 2) above. But with a mesh which is dense enough it should work.
            rv1974
            what a comprehensive support! Frankly I don't deserve it )
            The last sentence improvement would be a killer!
            Thank you so much!
              QuadfaceTools by Thomthom ?
              Or the quadrilaterizer by TiG ?
                La quadrature du cercle alors! πŸ˜‰
                • fredo6F
                  Just to be clearer, the density of the mesh is the only way to get the texture 'reasonably' distorted. When quads are too much like a triangle, the perspective distortion shifts the texture mapping.
                  In the case of your texture, that may help to do the trick, but it's a pity to have to generate so many faces
                  @Pilou
                  It is not so easy to generate the right mesh in the general case (and in this particular case).
                  ...and QuadFaceTools only manages quad meshes which it can triangulate, but not any polygon.
                  I think Whaat has developed an more adapted algorithm as part of SketchUV.
                  • alvisA
                    alvis
                    Thank you very very very very much.
                    • T
                      tina0603
                      thanks!!!!
                      • P
                        Pherim
                        Absolutely stunning! One of the best plugins I have seen so far (besides your others)! I think I will never use the native paint tool again.
                        And it's free! You are amazing!
                        • W
                          wolfy
                          @wolfi,
                          It might be a conflict with another plugin, which you would not have in the PC at the office.
                          Do you have any plugins dealing with materials or UV mapping?
                          For this, ould you type in the Ruby Console Sketchup::Material.instance_methods.join("\n") and advise on what it returns.
                          Fredo,
                          Entered your code into ruby console and it returned the following (sorry in advance for the length):
                          dclone
                          write_thumbnail
                          profile_member?
                          methods
                          attribute_dictionaries
                          get_attributes
                          remove_observer
                          instance_variable_defined?
                          taint
                          name
                          name=
                          id
                          set_attribute
                          singleton_methods
                          respond_to?
                          entityID
                          nil?
                          send
                          protected_methods
                          get_attribute
                          tainted?
                          display_name
                          untaint
                          instance_of?
                          typename
                          equal?
                          method
                          hash
                          private_methods
                          attribute_dictionary
                          send
                          materialType
                          kind_of?
                          freeze
                          eql?
                          object_id
                          has_attributes?
                          id
                          public_methods
                          instance_eval
                          deleted?
                          is_a?
                          delete_attribute
                          type
                          valid?
                          instance_variables
                          use_alpha?
                          frozen?
                          alpha
                          to_a
                          alpha=
                          class
                          instance_variable_get
                          between?
                          parent
                          color
                          to_s
                          extend
                          color=
                          clone
                          instance_variable_set
                          model
                          texture
                          inspect
                          texture=
                          display
                          add_observer
                          dup
                            SpookyChick1013
                            Thank You Fredo. This looks like the answer to many of my prayers. Looks like it shall be an interesting week, finally revising some old projects.
                            https://kuromatsudriveyards.com
                            Fo-su to tomo ni aran koto o...
                            • C
                              cmoreink
                              Amazing plugin Mr. Fredo! Thank you so much for all your plugins and hard work. Can't call you a G.O.D. but you are sitting right next to him πŸ˜‰
                              my portfolio
                              • pep75P
                                pep75
                                Jiiiiiihhhaaaaaaaaaaaaaaa!!!!!!! 😳
                                • P
                                  Pherim
                                  Played around with it for quite some time now and still I am amazed about what this plugin can do.
                                  If I may ask, would it be possible to add an option that allows to chose the scale of the texture before applying it and then keep that value until it is changed? That would save a lot of time in comparison to changing the scale of each texture manually after it was applied.
                                  • fredo6F
                                    That's a good idea, but I would put it as an option.
                                    Note you can also change the material definition (i.e. the dimensions).
                                    • P
                                      Pherim
                                      Of course you can but often enough I have a model where I wish to use the same material in different scales and having an option to choose a different scale before applying a material would be great!
                                      • KrisidiousK
                                        Krisidious
                                        Remembering of last scaling and rotation factors by material.
                                        OH MY... AWESOMENESS....
                                        By: Kristoff Rand
                                          About the first option
                                          Yet existing for a multiple selection with normal use of SU?
                                            jorge2011
                                            fredo, thank you very much for this new update.
                                            A query. Is possible to copy the material properties (rotation, scale, etc ...) and paste those properties to other faces?
                                            • 16
                                            • 17
                                            • 3 / 17
