    [Plugin] FredoTools::ThruPaint - v1.3a - 20 Oct 16
    331 Posts 102 Posters 610.7k Views 102 Watching
    • sadyoS
      sadyo
      This is an Awesome Plugin Mr Fredo,
      Just wanna ask, how to get rid or fixing these Red area beside click the Esc button?
      http://photoserver.ws/images/30gI4f8a92aa048fa.jpg
      And one thing,
      If i'm using the Natural UV, material on the Top is look nice, but look a bit mesh at the back.
      http://photoserver.ws/images/X1Sv4f8a9608d00fc.jpg
      Is that something i should do ❓
      Thanks Mr. Fredo
      • fredo6F
        @sadyo
        In the case of your cushion, you could maybe split it in 2 symmetrical parts since the upper face and borders looks fine.
        The Mesh UV mode looks less adpated because the shape is not generated as a Quadface mesh but with random triangles. Visually, you could however make it a quad mesh if you guide the reconstruction of the mesh by marking diagonals.
        Keep in mind that ThruPaint is not at all an UV Mapping tool (you should use SketchUV for that). The natural mode just extend the UVs of the initial face to all adjacent faces with a few corrections. But it cannot solve the geometrical problem that it is not possible to warp an arbitray 3D Shape with a flat piece of paper.
          rv1974
          Fredo this is yet another pearl!
          A couple of questions\wishes:
          1/ How could I get back the native Alt-key eyedropper?
          2/ How to correct the UVW mapping on the surface #1 (see attached)?
          3/ If only the Thrupaint could bend the textures along selected curves (AB) (upon unquadrified surfaces (#2) it'd really amazing!
          Thank you for your efforts!
          asphalt.skp
          • fredo6F
            You can call the native Paint Tool from ThruPaint (key F9 or small button on the right of palette).
            There is a sampler in ThruPaint (press Enter when you mouseover a face), but it is restricted to the model and does not detect projected textures, as this is not available from Ruby.
            Unfortunately, this is not possible, because Sketchup uses only Perspective mapping, not bilinear mapping.
            This perspective effect is attenuated if you grid the face into smaller cells (quads or triangles), for instance with Curviloft.
            I will need to find or develop a small algorithm for quadifying a face nicely. Then you are back to case 2) above. But with a mesh which is dense enough it should work.
              rv1974
              what a comprehensive support! Frankly I don't deserve it )
              The last sentence improvement would be a killer!
              Thank you so much!
                QuadfaceTools by Thomthom ?
                Or the quadrilaterizer by TiG ?
                  La quadrature du cercle alors! πŸ˜‰
                  • fredo6F
                    Just to be clearer, the density of the mesh is the only way to get the texture 'reasonably' distorted. When quads are too much like a triangle, the perspective distortion shifts the texture mapping.
                    In the case of your texture, that may help to do the trick, but it's a pity to have to generate so many faces
                    @Pilou
                    It is not so easy to generate the right mesh in the general case (and in this particular case).
                    ...and QuadFaceTools only manages quad meshes which it can triangulate, but not any polygon.
                    I think Whaat has developed an more adapted algorithm as part of SketchUV.
                    • alvisA
                      alvis
                      Thank you very very very very much.
                      • T
                        tina0603
                        thanks!!!!
                        • P
                          Pherim
                          Absolutely stunning! One of the best plugins I have seen so far (besides your others)! I think I will never use the native paint tool again.
                          And it's free! You are amazing!
                          • W
                            wolfy
                            @wolfi,
                            It might be a conflict with another plugin, which you would not have in the PC at the office.
                            Do you have any plugins dealing with materials or UV mapping?
                            For this, ould you type in the Ruby Console Sketchup::Material.instance_methods.join("\n") and advise on what it returns.
                            Fredo,
                            Entered your code into ruby console and it returned the following (sorry in advance for the length):
                            dclone
                            write_thumbnail
                            profile_member?
                            methods
                            attribute_dictionaries
                            get_attributes
                            remove_observer
                            instance_variable_defined?
                            taint
                            name
                            name=
                            id
                            set_attribute
                            singleton_methods
                            respond_to?
                            entityID
                            nil?
                            send
                            protected_methods
                            get_attribute
                            tainted?
                            display_name
                            untaint
                            instance_of?
                            typename
                            equal?
                            method
                            hash
                            private_methods
                            attribute_dictionary
                            send
                            materialType
                            kind_of?
                            freeze
                            eql?
                            object_id
                            has_attributes?
                            id
                            public_methods
                            instance_eval
                            deleted?
                            is_a?
                            delete_attribute
                            type
                            valid?
                            instance_variables
                            use_alpha?
                            frozen?
                            alpha
                            to_a
                            alpha=
                            class
                            instance_variable_get
                            between?
                            parent
                            color
                            to_s
                            extend
                            color=
                            clone
                            instance_variable_set
                            model
                            texture
                            inspect
                            texture=
                            display
                            add_observer
                            dup
                              SpookyChick1013
                              Thank You Fredo. This looks like the answer to many of my prayers. Looks like it shall be an interesting week, finally revising some old projects.
                              https://kuromatsudriveyards.com
                              Fo-su to tomo ni aran koto o...
                              • C
                                cmoreink
                                Amazing plugin Mr. Fredo! Thank you so much for all your plugins and hard work. Can't call you a G.O.D. but you are sitting right next to him πŸ˜‰
                                my portfolio
                                • pep75P
                                  pep75
                                  Jiiiiiihhhaaaaaaaaaaaaaaa!!!!!!! 😳
                                  • P
                                    Pherim
                                    Played around with it for quite some time now and still I am amazed about what this plugin can do.
                                    If I may ask, would it be possible to add an option that allows to chose the scale of the texture before applying it and then keep that value until it is changed? That would save a lot of time in comparison to changing the scale of each texture manually after it was applied.
                                    • fredo6F
                                      That's a good idea, but I would put it as an option.
                                      Note you can also change the material definition (i.e. the dimensions).
                                      • P
                                        Pherim
                                        Of course you can but often enough I have a model where I wish to use the same material in different scales and having an option to choose a different scale before applying a material would be great!
                                        • KrisidiousK
                                          Krisidious
                                          Remembering of last scaling and rotation factors by material.
                                          OH MY... AWESOMENESS....
                                          By: Kristoff Rand
                                            About the first option
                                            Yet existing for a multiple selection with normal use of SU?
                                            • 16
                                            • 17
                                            • 3 / 17
