    [Plugin] FredoTools::ThruPaint - v1.3a - 20 Oct 16
    331 Posts 102 Posters 602.7k Views 102 Watching
    • W Offline
      wolfy
      @wolfy
      A few questions to help me spot the problem
      1. Is the material a color or a material with texture ?
      2. Does the crash happen when you paint or when you simply mouse over the model
      3. Do you use the options "Paint Faces and Edges"?
      4. Does it happen always, or randomly?
      5. Are you on Mac or Windows and which SU version ?
      6. Could you post the model (and the newly created group) in the forum so that I can see if I can reproduce it.
      Hi Fredo,
      1. I've used both and it bugsplats in both cases.
      2. Crash only happens whilst painting.
      3. I've tried with same bugsplat result.
      4. It happens everytime I try to paint a newly created group. (the 1st one after opening a new model)
      5. Windows.
      6. I simply created a random shape each time to test/try the plugin, no materials in the model and picked material from materials library after I had invoked the plugin. Each random shape/model bugsplats when i try to apply a new material with the plugin.
      When I pick a material already in the model the plugin works fine, it's when I choose a new material from the material library that I get a bugsplat.
      Thanks for the feedback!
        leminilab
        I'm working with Curviloft and Thrupaint...
        I think I'm gonna vote for you to be the next president of France...
        • "Live every day as if it were your last and then some day you'll be right."
        • "ThomThom rules!!!"
        • fredo6F Offline
          @wolfi
          Just a few other questions, as I am unable to reproduce it (and apparently it does not happen for the first users of ThruPaint)
          1. Which version of SU
          2. After you use ThruPaint with a material in the model (so no bugsplat) and you try a material in the Library, do you still get a bugsplat?
          3. do you get a bugsplat if instead of a group, you paint a shape at top level of the model, or a true Component?
          • W Offline
            wolfy
            @wolfi
            Fredo,
            It seems to work beautifully on my work computer. ☀
            I will reinstall again and hopefully eliminate this bugsplat deal.
            Thank you for your responses and I'll be sure to post my reinstall status.
              d12dozr
              Awesome, no, AWESOME plugin Fredo! Thank you for all your hard work making Sketchup better!!
              http://goo.gl/f7ooYh
              • charly2008C Offline
                charly2008
                It is wonderful that here in the forum are many talented Ruby programmers. Fredo, thanks a million for this additional excellent tool.
                Charly
                • Didier BurD Offline
                  Didier Bur
                  And I'm candidate to be his prime minister 🤣
                  DB
                  • fredo6F Offline
                    NEW RELEASE: ThruPaint v1.0m - 14 Apr 12
                    This update fixes a few issues found in ThruPaint and integrate the translation to Spanish - Spain (Oxer), Spanish - Latin America (Defisto) and Chinese (guanjin)
                    See main post of this thread for more information on ThruPaint.
                    See main post of FredoTools thread for download of FredoTools, which includes the script.
                    • urgenU Offline
                      urgen
                      ....O-O-O! ☀ thank you Fredo! 👍
                      --pupil forever...------
                      • W Offline
                        wolfy
                        @wolfy said:
                        @wolfi
                        Fredo,
                        Hi Fredo,
                        Well the bugsplat continues on my laptop. I've installed the new version with the same result.
                        Again, if the material already lives in the model it works just great. Only when a new material is applied using the plugin do I get a bugsplat.
                        I've tried all types of shapes, groups, components, materails, you name it, all with the same result.
                        I'm using the latest version of SU Pro, Windows 7 64 bit if that helps, and all your other plugins run perfectly smooth.
                        Thanks again Fredo for your excellent work!
                        • fredo6F Offline
                          @wolfi,
                          It might be a conflict with another plugin, which you would not have in the PC at the office.
                          Do you have any plugins dealing with materials or UV mapping?
                          For this, ould you type in the Ruby Console Sketchup::Material.instance_methods.join("\n") and advise on what it returns.
                          • sadyoS Offline
                            sadyo
                            This is an Awesome Plugin Mr Fredo,
                            Just wanna ask, how to get rid or fixing these Red area beside click the Esc button?
                            http://photoserver.ws/images/30gI4f8a92aa048fa.jpg
                            And one thing,
                            If i'm using the Natural UV, material on the Top is look nice, but look a bit mesh at the back.
                            http://photoserver.ws/images/X1Sv4f8a9608d00fc.jpg
                            Is that something i should do ❓
                            Thanks Mr. Fredo
                            • fredo6F Offline
                              @sadyo
                              In the case of your cushion, you could maybe split it in 2 symmetrical parts since the upper face and borders looks fine.
                              The Mesh UV mode looks less adpated because the shape is not generated as a Quadface mesh but with random triangles. Visually, you could however make it a quad mesh if you guide the reconstruction of the mesh by marking diagonals.
                              Keep in mind that ThruPaint is not at all an UV Mapping tool (you should use SketchUV for that). The natural mode just extend the UVs of the initial face to all adjacent faces with a few corrections. But it cannot solve the geometrical problem that it is not possible to warp an arbitray 3D Shape with a flat piece of paper.
                                rv1974
                                Fredo this is yet another pearl!
                                A couple of questions\wishes:
                                1/ How could I get back the native Alt-key eyedropper?
                                2/ How to correct the UVW mapping on the surface #1 (see attached)?
                                3/ If only the Thrupaint could bend the textures along selected curves (AB) (upon unquadrified surfaces (#2) it'd really amazing!
                                Thank you for your efforts!
                                asphalt.skp
                                • fredo6F Offline
                                  You can call the native Paint Tool from ThruPaint (key F9 or small button on the right of palette).
                                  There is a sampler in ThruPaint (press Enter when you mouseover a face), but it is restricted to the model and does not detect projected textures, as this is not available from Ruby.
                                  Unfortunately, this is not possible, because Sketchup uses only Perspective mapping, not bilinear mapping.
                                  This perspective effect is attenuated if you grid the face into smaller cells (quads or triangles), for instance with Curviloft.
                                  I will need to find or develop a small algorithm for quadifying a face nicely. Then you are back to case 2) above. But with a mesh which is dense enough it should work.
                                    rv1974
                                    what a comprehensive support! Frankly I don't deserve it )
                                    The last sentence improvement would be a killer!
                                    Thank you so much!
                                      QuadfaceTools by Thomthom ?
                                      Or the quadrilaterizer by TiG ?
                                        La quadrature du cercle alors! 😉
                                        • fredo6F Offline
                                          Just to be clearer, the density of the mesh is the only way to get the texture 'reasonably' distorted. When quads are too much like a triangle, the perspective distortion shifts the texture mapping.
                                          In the case of your texture, that may help to do the trick, but it's a pity to have to generate so many faces
                                          @Pilou
                                          It is not so easy to generate the right mesh in the general case (and in this particular case).
                                          ...and QuadFaceTools only manages quad meshes which it can triangulate, but not any polygon.
                                          I think Whaat has developed an more adapted algorithm as part of SketchUV.
                                          • alvisA Offline
                                            alvis
                                            Thank you very very very very much.
                                            • 16
                                            • 17
                                            • 3 / 17
