    [Plugin] Multiple Offsets (Updated 09-Feb-2014)
    37 Posts 16 Posters 75.2k Views 16 Watching
      @Simon
      Curious you write 20,30,40,50*3, that must be 20,30,40,50,*3 😉
      Edit : in fact that gives the same result! 💚
      • guanjinG Offline
        guanjin
        @sdmitch said:
        Major update posted today. Offsets can be created by three methods
        Constant: Input number of offsets, distance between offsets, direction to
        offset, either inside, outside, or both, and whether the selected face(s) and all
        created faces are to be deleted, select No to keep faces.
        Formula: Enter number of offsets, distance to first offset, direction to offset,
        delete faces Yes or No, select operator + or *, and value to add or multiply by.
        List: Select direction of offsets, delete faces Yes or No, a list of offsets
        seperated by commas, choose type of offset either absolute or a delta value
        to be added to the last offset value. If the offsets are a repeated sequence,
        end the list with *X, where X = the number of repititions for the offset
        sequence entered.
        Great tool invention
        Can realize line migration, generating surface?
        Perhaps we should not be too many requests
        thank you sdmitch
        • guanjinG Offline
          guanjin
          sequence entered.
          DWG files import, Is no surface of
          thank you sdmitch
          • guanjinG Offline
            guanjin
            sequence entered.
            DWG files import, Is no surface of ,
            thank you sdmitch
              I have added some plugins for another things in V8
              All menus Offset Multiples are fine but nothing append! 😲
              Seems there is a conflict with another plugs! 😮
              Must find the the culprit(s)! (resolved see the next page for see the culprit) 😉
                blajnov
                Respected sdmitch, the new version of a plug-in, doesn't work in SketchUp 8 Pro M2...😢
                The previous works perfectly well.
                • guanjinG Offline
                  guanjin
                  I also SU8M2, no problem
                  • sdmitchS Offline
                    sdmitch
                    blajov, sorry about that but I only have SU8 Free at my disposal so there is no way for me to determine why that is the case.
                    http://sdmitch.blogspot.com/
                      Ok for the Conflict in V8 free the culprit is "Windowizer3" ! ☀
                      • kenK Offline
                        ken
                        Sam
                        The multiple offset does not work on my computer,none of the options, constant, formula or list. I have Sketchup, V8, M1. Here is the error message. Hope this helps.
                        Error: #<ArgumentError: wrong number of arguments (3 for 1)>
                        C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Multiple Offsets-A.rb:76:in offset' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Multiple Offsets-A.rb:76:in do_offsets_constant'
                        C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Multiple Offsets-A.rb:74:in each' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Multiple Offsets-A.rb:74:in do_offsets_constant'
                        C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Multiple Offsets-A.rb:72:in each' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Multiple Offsets-A.rb:72:in do_offsets_constant'
                        C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Multiple Offsets-A.rb:49:in do_offsets' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Multiple Offsets-A.rb:30 C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Multiple Offsets-A.rb:76:in call'
                        Thanks in advance for looking at this problem and the plugin.
                        Ken
                        • sdmitchS Offline
                          sdmitch
                          One last update!!!
                            mirale999
                            Great plugin~
                            paranoia is a higher form of awareness...
                            • N Offline
                              nmhai
                              ERROR FOR ME:
                                Thank you very much for the update, Sam. It does exactly what I needed.
                                nmhai: That's not an issue with the plugin. You'd get that with the native offset tool as well. The error is in the setup. You can either fix by deleting the unwanted edges or you start with the inner most profile and offset outward. You might also have a look at TIG's Smart Offset.
                                • cottyC Offline
                                  cotty
                                  @dave r said:
                                  update
                                  my SketchUp gallery
                                    darrellhaemer
                                    Can anyone confirm that this extension still works (or doesn't) in SketchUp 2020? I can't seem to get it to have an effect.
                                      It works for me in SketchUp 2021. I would expect it should work in 2020, too.
                                      Click on the picture
                                      BTW, your profile indicates you are using SU2016. Please update your profile.
                                      • HornOxxH Offline
                                        HornOxx
                                        Hi everyone—does anyone know if this plugin also works somehow on SU 2025? Unfortunately, I can't get it to work.
                                        never trust a skinny cook
                                          Rich O Brien Moderator @HornOxx
                                          @HornOxx said in [Plugin] Multiple Offsets (Updated 09-Feb-2014):
                                          Yeah, it is broken. If you check the Console you can see it throws some errors.
                                          We will take a look.
                                            Any error messages in the Ruby Console ?
                                            Are you following the detailed instructions.
                                            It hasn't been supported for sometime - the author has stopped all development on his extensions.
                                            Although it's old it has been reported as working in versions up to a few years ago...
                                            • 2 / 2
