    [Plugin] Multiple Offsets (Updated 09-Feb-2014)
    37 Posts 16 Posters 78.4k Views 16 Watching
    • simon le bonS Offline
      simon le bon
      Thank you Sam,
      It's a gem. ๐Ÿ‘
      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/Boutons/Ruby.png
      older version overwritten by the new one ๐Ÿ˜‰
      ++simon
        simon le bon
        Hi Pilou and Sam,
        Multiple Offsets works for me with Su7
        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/MultipleOffsets001.jpg
        However problems with the List Options:
        • List:Offset by * 3
          Absolute and Delta choice gives the same result:
        x3 Delta offset (see pict)
        (colored after for a better watch)
        • List: Offsets: + operator don't work and deletes the offseted faces
        simon
          curious nothing append on V7 and V6! ๐Ÿ˜ฎ
          All menu appear but nothing is done! Does this normal ?
          Work like a charm in V8 ! ๐Ÿ˜Ž (aespecially the * x with a list ! ๐Ÿ‘ ๐Ÿ˜‰
          As the "exotic Push Pull" seems have a problem maybe will be a good thing to input it inside this plug during the calculate ?
          Or See my new request ๐Ÿ˜‰
            @Simon
            Curious you write 20,30,40,50*3, that must be 20,30,40,50,*3 ๐Ÿ˜‰
            Edit : in fact that gives the same result! ๐Ÿ’š
            • guanjinG Offline
              guanjin
              @sdmitch said:
              Major update posted today. Offsets can be created by three methods
              Constant: Input number of offsets, distance between offsets, direction to
              offset, either inside, outside, or both, and whether the selected face(s) and all
              created faces are to be deleted, select No to keep faces.
              Formula: Enter number of offsets, distance to first offset, direction to offset,
              delete faces Yes or No, select operator + or *, and value to add or multiply by.
              List: Select direction of offsets, delete faces Yes or No, a list of offsets
              seperated by commas, choose type of offset either absolute or a delta value
              to be added to the last offset value. If the offsets are a repeated sequence,
              end the list with *X, where X = the number of repititions for the offset
              sequence entered.
              Great tool invention
              Can realize line migration, generating surface?
              Perhaps we should not be too many requests
              thank you sdmitch
              • guanjinG Offline
                guanjin
                sequence entered.
                DWG files import, Is no surface of
                thank you sdmitch
                • guanjinG Offline
                  guanjin
                  sequence entered.
                  DWG files import, Is no surface of ,
                  thank you sdmitch
                    I have added some plugins for another things in V8
                    All menus Offset Multiples are fine but nothing append! ๐Ÿ˜ฒ
                    Seems there is a conflict with another plugs! ๐Ÿ˜ฎ
                    Must find the the culprit(s)! (resolved see the next page for see the culprit) ๐Ÿ˜‰
                      blajnov
                      Respected sdmitch, the new version of a plug-in, doesn't work in SketchUp 8 Pro M2...๐Ÿ˜ข
                      The previous works perfectly well.
                      • guanjinG Offline
                        guanjin
                        I also SU8M2, no problem
                        • sdmitchS Offline
                          sdmitch
                          blajov, sorry about that but I only have SU8 Free at my disposal so there is no way for me to determine why that is the case.
                          http://sdmitch.blogspot.com/
                            Ok for the Conflict in V8 free the culprit is "Windowizer3" ! โ˜€
                            • kenK Offline
                              ken
                              Sam
                              The multiple offset does not work on my computer,none of the options, constant, formula or list. I have Sketchup, V8, M1. Here is the error message. Hope this helps.
                              Error: #<ArgumentError: wrong number of arguments (3 for 1)>
                              C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Multiple Offsets-A.rb:76:in offset' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Multiple Offsets-A.rb:76:in do_offsets_constant'
                              C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Multiple Offsets-A.rb:74:in each' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Multiple Offsets-A.rb:74:in do_offsets_constant'
                              C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Multiple Offsets-A.rb:72:in each' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Multiple Offsets-A.rb:72:in do_offsets_constant'
                              C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Multiple Offsets-A.rb:49:in do_offsets' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Multiple Offsets-A.rb:30 C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Multiple Offsets-A.rb:76:in call'
                              Thanks in advance for looking at this problem and the plugin.
                              Ken
                              • sdmitchS Offline
                                sdmitch
                                One last update!!!
                                  mirale999
                                  Great plugin~
                                  paranoia is a higher form of awareness...
                                  • N Offline
                                    nmhai
                                    ERROR FOR ME:
                                      Thank you very much for the update, Sam. It does exactly what I needed.
                                      nmhai: That's not an issue with the plugin. You'd get that with the native offset tool as well. The error is in the setup. You can either fix by deleting the unwanted edges or you start with the inner most profile and offset outward. You might also have a look at TIG's Smart Offset.
                                      • cottyC Offline
                                        cotty
                                        @dave r said:
                                        update
                                        โ“
                                        my SketchUp gallery
                                          darrellhaemer
                                          Can anyone confirm that this extension still works (or doesn't) in SketchUp 2020? I can't seem to get it to have an effect.
                                            It works for me in SketchUp 2021. I would expect it should work in 2020, too.
                                            Click on the picture
                                            BTW, your profile indicates you are using SU2016. Please update your profile.
