    [Plugin] Multiple Offsets (Updated 09-Feb-2014)
    37 Posts 16 Posters 78.8k Views 16 Watching
      dtrarch
      Sam
      Good stuff and thank you. ๐Ÿ‘
      dtr
      • B
        Ben Ritter
        sdmitch, Thank you!
        • sdmitchS
          sdmitch
          Major update posted today. Offsets can be created by three methods
          Constant: Input number of offsets, distance between offsets, direction to
          offset, either inside, outside, or both, and whether the selected face(s) and all
          created faces are to be deleted, select No to keep faces.
          Formula: Enter number of offsets, distance to first offset, direction to offset,
          delete faces Yes or No, select operator + or *, and value to add or multiply by.
          List: Select direction of offsets, delete faces Yes or No, a list of offsets
          seperated by commas, choose type of offset either absolute or a delta value
          to be added to the last offset value. If the offsets are a repeated sequence,
          end the list with *X, where X = the number of repititions for the offset
          sequence entered.
          http://sdmitch.blogspot.com/
          • simon le bonS
            simon le bon
            Thank you Sam,
            It's a gem. ๐Ÿ‘
            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/Boutons/Ruby.png
            older version overwritten by the new one ๐Ÿ˜‰
            ++simon
            • simon le bonS
              simon le bon
              Hi Pilou and Sam,
              Multiple Offsets works for me with Su7
              http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/MultipleOffsets001.jpg
              However problems with the List Options:
              • List:Offset by * 3
                Absolute and Delta choice gives the same result:
              x3 Delta offset (see pict)
              (colored after for a better watch)
              • List: Offsets: + operator don't work and deletes the offseted faces
              simon
                curious nothing append on V7 and V6! ๐Ÿ˜ฎ
                All menu appear but nothing is done! Does this normal ?
                Work like a charm in V8 ! ๐Ÿ˜Ž (aespecially the * x with a list ! ๐Ÿ‘ ๐Ÿ˜‰
                As the "exotic Push Pull" seems have a problem maybe will be a good thing to input it inside this plug during the calculate ?
                Or See my new request ๐Ÿ˜‰
                  @Simon
                  Curious you write 20,30,40,50*3, that must be 20,30,40,50,*3 ๐Ÿ˜‰
                  Edit : in fact that gives the same result! ๐Ÿ’š
                  • guanjinG
                    guanjin
                    sequence entered.
                    Great tool invention
                    Can realize line migration, generating surface?
                    Perhaps we should not be too many requests
                    thank you sdmitch
                    • guanjinG
                      guanjin
                      sequence entered.
                      DWG files import, Is no surface of
                      thank you sdmitch
                      • guanjinG
                        guanjin
                        sequence entered.
                        DWG files import, Is no surface of ,
                        thank you sdmitch
                          I have added some plugins for another things in V8
                          All menus Offset Multiples are fine but nothing append! ๐Ÿ˜ฒ
                          Seems there is a conflict with another plugs! ๐Ÿ˜ฎ
                          Must find the the culprit(s)! (resolved see the next page for see the culprit) ๐Ÿ˜‰
                          • B
                            blajnov
                            Respected sdmitch, the new version of a plug-in, doesn't work in SketchUp 8 Pro M2...๐Ÿ˜ข
                            The previous works perfectly well.
                            • guanjinG
                              guanjin
                              I also SU8M2, no problem
                              • sdmitchS
                                sdmitch
                                blajov, sorry about that but I only have SU8 Free at my disposal so there is no way for me to determine why that is the case.
                                  Ok for the Conflict in V8 free the culprit is "Windowizer3" ! โ˜€
                                  • kenK
                                    ken
                                    Sam
                                    The multiple offset does not work on my computer,none of the options, constant, formula or list. I have Sketchup, V8, M1. Here is the error message. Hope this helps.
                                    Error: #<ArgumentError: wrong number of arguments (3 for 1)>
                                    C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Multiple Offsets-A.rb:76:in offset' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Multiple Offsets-A.rb:76:in do_offsets_constant'
                                    C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Multiple Offsets-A.rb:74:in each' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Multiple Offsets-A.rb:74:in do_offsets_constant'
                                    C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Multiple Offsets-A.rb:72:in each' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Multiple Offsets-A.rb:72:in do_offsets_constant'
                                    C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Multiple Offsets-A.rb:49:in do_offsets' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Multiple Offsets-A.rb:30 C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Multiple Offsets-A.rb:76:in call'
                                    Thanks in advance for looking at this problem and the plugin.
                                    Ken
                                    • sdmitchS
                                      sdmitch
                                      One last update!!!
                                        mirale999
                                        Great plugin~
                                        paranoia is a higher form of awareness...
                                        • N
                                          nmhai
                                          ERROR FOR ME:
                                            Thank you very much for the update, Sam. It does exactly what I needed.
                                            nmhai: That's not an issue with the plugin. You'd get that with the native offset tool as well. The error is in the setup. You can either fix by deleting the unwanted edges or you start with the inner most profile and offset outward. You might also have a look at TIG's Smart Offset.
