    [Plugin] Multiple Offsets (Updated 09-Feb-2014)
    37 Posts 16 Posters 77.6k Views 16 Watching
    • guanjinG Offline
      guanjin
      @sdmitch said:
      Major update posted today. Offsets can be created by three methods
      Constant: Input number of offsets, distance between offsets, direction to
      offset, either inside, outside, or both, and whether the selected face(s) and all
      created faces are to be deleted, select No to keep faces.
      Formula: Enter number of offsets, distance to first offset, direction to offset,
      delete faces Yes or No, select operator + or *, and value to add or multiply by.
      List: Select direction of offsets, delete faces Yes or No, a list of offsets
      seperated by commas, choose type of offset either absolute or a delta value
      to be added to the last offset value. If the offsets are a repeated sequence,
      end the list with *X, where X = the number of repititions for the offset
      sequence entered.
      Great tool invention
      Can realize line migration, generating surface?
      Perhaps we should not be too many requests
      thank you sdmitch
      • guanjinG Offline
        guanjin
        sequence entered.
        DWG files import, Is no surface of
        thank you sdmitch
        • guanjinG Offline
          guanjin
          sequence entered.
          DWG files import, Is no surface of ,
          thank you sdmitch
            I have added some plugins for another things in V8
            All menus Offset Multiples are fine but nothing append! 😲
            Seems there is a conflict with another plugs! 😮
            Must find the the culprit(s)! (resolved see the next page for see the culprit) 😉
              blajnov
              Respected sdmitch, the new version of a plug-in, doesn't work in SketchUp 8 Pro M2...😢
              The previous works perfectly well.
              • guanjinG Offline
                guanjin
                I also SU8M2, no problem
                • sdmitchS Offline
                  sdmitch
                  blajov, sorry about that but I only have SU8 Free at my disposal so there is no way for me to determine why that is the case.
                  http://sdmitch.blogspot.com/
                    Ok for the Conflict in V8 free the culprit is "Windowizer3" ! ☀
                    • kenK Offline
                      ken
                      Sam
                      The multiple offset does not work on my computer,none of the options, constant, formula or list. I have Sketchup, V8, M1. Here is the error message. Hope this helps.
                      Error: #<ArgumentError: wrong number of arguments (3 for 1)>
                      C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Multiple Offsets-A.rb:76:in offset' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Multiple Offsets-A.rb:76:in do_offsets_constant'
                      C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Multiple Offsets-A.rb:74:in each' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Multiple Offsets-A.rb:74:in do_offsets_constant'
                      C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Multiple Offsets-A.rb:72:in each' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Multiple Offsets-A.rb:72:in do_offsets_constant'
                      C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Multiple Offsets-A.rb:49:in do_offsets' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Multiple Offsets-A.rb:30 C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Multiple Offsets-A.rb:76:in call'
                      Thanks in advance for looking at this problem and the plugin.
                      Ken
                      • sdmitchS Offline
                        sdmitch
                        One last update!!!
                          mirale999
                          Great plugin~
                          paranoia is a higher form of awareness...
                          • N Offline
                            nmhai
                            ERROR FOR ME:
                              Thank you very much for the update, Sam. It does exactly what I needed.
                              nmhai: That's not an issue with the plugin. You'd get that with the native offset tool as well. The error is in the setup. You can either fix by deleting the unwanted edges or you start with the inner most profile and offset outward. You might also have a look at TIG's Smart Offset.
                              • cottyC Offline
                                cotty
                                @dave r said:
                                update
                                my SketchUp gallery
                                  darrellhaemer
                                  Can anyone confirm that this extension still works (or doesn't) in SketchUp 2020? I can't seem to get it to have an effect.
                                    It works for me in SketchUp 2021. I would expect it should work in 2020, too.
                                    Click on the picture
                                    BTW, your profile indicates you are using SU2016. Please update your profile.
                                    • HornOxxH Offline
                                      HornOxx
                                      Hi everyone—does anyone know if this plugin also works somehow on SU 2025? Unfortunately, I can't get it to work.
                                      never trust a skinny cook
                                        Rich O Brien Moderator @HornOxx
                                        @HornOxx said in [Plugin] Multiple Offsets (Updated 09-Feb-2014):
                                        Yeah, it is broken. If you check the Console you can see it throws some errors.
                                        We will take a look.
                                          Any error messages in the Ruby Console ?
                                          Are you following the detailed instructions.
                                          It hasn't been supported for sometime - the author has stopped all development on his extensions.
                                          Although it's old it has been reported as working in versions up to a few years ago...
                                            You get this on 2026
                                            #<Sketchup::Face:0x000001956f6860e0> did not offset:
                                            • 2 / 2
