    [Plugin] Multiple Offsets (Updated 09-Feb-2014)
    37 Posts 16 Posters 78.8k Views 16 Watching
    • sdmitchS
      sdmitch
      One last update!!!
      http://sdmitch.blogspot.com/
        mirale999
        Great plugin~
        paranoia is a higher form of awareness...
        • N
          nmhai
          ERROR FOR ME:
            Thank you very much for the update, Sam. It does exactly what I needed.
            nmhai: That's not an issue with the plugin. You'd get that with the native offset tool as well. The error is in the setup. You can either fix by deleting the unwanted edges or you start with the inner most profile and offset outward. You might also have a look at TIG's Smart Offset.
            • cottyC
              cotty
              @dave r said:
              update
              my SketchUp gallery
                darrellhaemer
                Can anyone confirm that this extension still works (or doesn't) in SketchUp 2020? I can't seem to get it to have an effect.
                  It works for me in SketchUp 2021. I would expect it should work in 2020, too.
                  Click on the picture
                  BTW, your profile indicates you are using SU2016. Please update your profile.
                  • HornOxxH
                    HornOxx
                    Hi everyone—does anyone know if this plugin also works somehow on SU 2025? Unfortunately, I can't get it to work.
                    never trust a skinny cook
                      Rich O Brien Moderator @HornOxx
                      @HornOxx said in [Plugin] Multiple Offsets (Updated 09-Feb-2014):
                      Yeah, it is broken. If you check the Console you can see it throws some errors.
                      We will take a look.
                        Any error messages in the Ruby Console ?
                        Are you following the detailed instructions.
                        It hasn't been supported for sometime - the author has stopped all development on his extensions.
                        Although it's old it has been reported as working in versions up to a few years ago...
                          You get this on 2026
                          #<Sketchup::Face:0x000001956f6860e0> did not offset:
                            I was also looking ! It seems to be a simple issue with 'FixNum' being deprecated in the newer Ruby version, replaced by 'Integer'.
                            I'll edit the file and publish an updated version asap.
                            Under the author's © notice it's allowed...
                            • HornOxxH
                              HornOxx
                              ...thanks to you Both for checking this 🤚
                                v5 is now available in the PluginStore / ExtensionStore³
                                https://sketchucation.com/pluginstore?pln=Multiple_Offsets
                                It's now compatible with the newer SketchUp version's Ruby methods [e.g. 'FixNum' was deprecated in favor of 'Integer']
                                The RBZ is now also 'signed' to suit all Loading Policies...
                                Reply Quote 2
                                • HornOxxH
                                  HornOxx
                                  ...and works so well now!! Thanks Tig!
                                  • 2 / 2
