    [Plugin] Multiple Offsets (Updated 09-Feb-2014)
    37 Posts 16 Posters 77.4k Views 16 Watching
      Ok for the Conflict in V8 free the culprit is "Windowizer3" ! ☀
      • kenK Offline
        ken
        Sam
        The multiple offset does not work on my computer,none of the options, constant, formula or list. I have Sketchup, V8, M1. Here is the error message. Hope this helps.
        Error: #<ArgumentError: wrong number of arguments (3 for 1)>
        C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Multiple Offsets-A.rb:76:in offset' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Multiple Offsets-A.rb:76:in do_offsets_constant'
        C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Multiple Offsets-A.rb:74:in each' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Multiple Offsets-A.rb:74:in do_offsets_constant'
        C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Multiple Offsets-A.rb:72:in each' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Multiple Offsets-A.rb:72:in do_offsets_constant'
        C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Multiple Offsets-A.rb:49:in do_offsets' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Multiple Offsets-A.rb:30 C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Multiple Offsets-A.rb:76:in call'
        Thanks in advance for looking at this problem and the plugin.
        Ken
        • sdmitchS Offline
          sdmitch
          One last update!!!
          http://sdmitch.blogspot.com/
            mirale999
            Great plugin~
            paranoia is a higher form of awareness...
            • N Offline
              nmhai
              ERROR FOR ME:
                Thank you very much for the update, Sam. It does exactly what I needed.
                nmhai: That's not an issue with the plugin. You'd get that with the native offset tool as well. The error is in the setup. You can either fix by deleting the unwanted edges or you start with the inner most profile and offset outward. You might also have a look at TIG's Smart Offset.
                • cottyC Offline
                  cotty
                  @dave r said:
                  update
                  my SketchUp gallery
                    darrellhaemer
                    Can anyone confirm that this extension still works (or doesn't) in SketchUp 2020? I can't seem to get it to have an effect.
                      It works for me in SketchUp 2021. I would expect it should work in 2020, too.
                      Click on the picture
                      BTW, your profile indicates you are using SU2016. Please update your profile.
                      • HornOxxH Offline
                        HornOxx
                        Hi everyone—does anyone know if this plugin also works somehow on SU 2025? Unfortunately, I can't get it to work.
                        never trust a skinny cook
                        • Rich O BrienR Online
                          Rich O Brien Moderator @HornOxx
                          @HornOxx said in [Plugin] Multiple Offsets (Updated 09-Feb-2014):
                          Yeah, it is broken. If you check the Console you can see it throws some errors.
                          We will take a look.
                            Any error messages in the Ruby Console ?
                            Are you following the detailed instructions.
                            It hasn't been supported for sometime - the author has stopped all development on his extensions.
                            Although it's old it has been reported as working in versions up to a few years ago...
                              You get this on 2026
                              #<Sketchup::Face:0x000001956f6860e0> did not offset:
                                I was also looking ! It seems to be a simple issue with 'FixNum' being deprecated in the newer Ruby version, replaced by 'Integer'.
                                I'll edit the file and publish an updated version asap.
                                Under the author's © notice it's allowed...
                                • HornOxxH Offline
                                  HornOxx
                                  ...thanks to you Both for checking this 🤚
                                    v5 is now available in the PluginStore / ExtensionStore³
                                    https://sketchucation.com/pluginstore?pln=Multiple_Offsets
                                    It's now compatible with the newer SketchUp version's Ruby methods [e.g. 'FixNum' was deprecated in favor of 'Integer']
                                    The RBZ is now also 'signed' to suit all Loading Policies...
                                    • HornOxxH Offline
                                      HornOxx
                                      ...and works so well now!! Thanks Tig!
                                      • 2 / 2
