    [Plugin Library] LibFredo6 - v16.2b - 22 Sep 26
    2.2k Posts 583 Posters 9.0m Views 585 Watching
      mar k
      Many thanks Fredo !
      You save my black hair
        ScoobyDoo92
        Everytime i try to download instead of getting a .zip file i get a .php file. Anyone got a solution??
        • GaieusG
          H. I heard this from Mac users in the past. Try to change the extension from php to zip and see what happens.
          • mitcorbM
            mitcorb
            In my experience, it may be that the page? loads too fast to pick up the zip, so you get a php temporary placeholder. So, what I have done is cancel the call, wait a short while, and try again until I see the .zip This has worked for me. If you are getting persistent php, then perhaps your security settings are too strong? I am not sure.
              On my MacBook Pro, zip files don't display an extension. The just look like a folder. In fact the icon is a folder. Perhaps you could eliminate the extension altogether. Installing the files consists of simply opening the folder, copying the contents and pasting them into Plugins.
              • n000bieN
                n000bie
                Hi guys, this is my first time posting here but I got a problem that I'm not sure if that's already solved or not, still I've just installed the new LibFredo6 - v4.2a days ago and this is what I get whenever I start Sketchup :
                And this is the how my Plugin folder looks like :
                I'm using Sketchup 8.0.4811, via Windows 7. Can someone plz tell me what I do wrong or just how to fix this, I've been using Joint Push Pull, Round Corner and Tools On Surface for times and there's no problem until this.
                Thnx alot. I always appreciate you and your works, Fredo6.
                • fredo6F
                  Not sure if this will solve the problem, but you have a very old version of FredoScale, called FreeScale.
                  Could you remove:
                  • ZLoader__Freescale.rb
                  • FreeScale_dir_20 folder
                  Thanks.
                  • n000bieN
                    n000bie
                    My greatful thnx to you and your quick respond, problem solved 😄 . Looks like I have to update my Fredo Scale.
                    Thnx again, Fredo, you're the one. 👍
                    • fredo6F
                      NEW RELEASE: LibFredo6 v4.3a - 19 Dec 11
                      LibFredo6 4.3 is a new release which essentially support the publishing of FredoTools suite of Plugins
                      • T
                        tspco
                        Don't know if this is a problem or not, just installed the 20dec11 update of fredo 6
                        SU make 2017, /Twilight Render Hobby
                        Windows 10,64 bit,16GB ram, quad core Athlon 3.6 gHz proc. Anything else you want to know, ask me.
                        • fredo6F
                          These are binary files.
                          It is strange that your unzip utility (I guess 7-zip) tries to open them. It should not.
                          • fredo6F
                            NEW RELEASE: LibFredo6 v4.3b - 22 Dec 11
                            Release 4.3b includes (on top of 4.3a)
                            • a fix to the numeric buttons in Palettes (not visible in Curviloft)
                            • the updated Spanish translation (thanks to Defisto)
                            • E
                              eyffel65girl
                              Fredo your plugin is awesome, but I can't use it! I run Skethcup Pro 7 on my Mac Book Pro. I've installed your plugin (LibFredo6 first, and then RoundCorner) following your detailed instructions; I thought it were an easy things to do, but they don't work! 😢
                              Can you please help me?? I'll always be graitfull !!
                              • O
                                oldswinger
                                Dear Fredo
                                I have downloaded the first 4 plugins from your Plugin Library list "Libfredo6 v4.3b - 22Dec11 but cannot get any toolbar icons appearing when I open my SU8Pro programme.
                                I note your Important Paragraph about the downloading of LibFredo6 in respect of the appearance of the plugin toolbars but inspite of following the download instructions precisely I can only access the 4 plugins via the entry "Fredo6 Collection" in the Tools menu.
                                I have ticked off the plugins Fredo Scale & Tools on Surface in the VIEW/TOOLBAR menu but Curiloft & Roundcorner are not shown in the dropdown menu.
                                I would be extremely gratefull if you could suggest where I am going wrong as without the plugin icons showing in the main toolbar it becomes rather difficult to use the plugins to their best advantage.
                                Best regards
                                OldSwinger
                                • fredo6F
                                  It might come from the Unzip operation, which is a frequent problem, especially on Mac.
                                  Please make sure that in the SU Plugins directory you have the right footprint, that is:
                                  • LibFredo6.rb
                                  • LIBFREDO6_Dir_43 folder
                                  • ROUNDCORNER_Dir_23 folder
                                    rjjvirusx
                                    hooooory
                                    • T
                                      tspco
                                      Is the LibFredo6-34 supposed to stay in the di
                                      rectory after extracting?
                                        You should have a folder called "LIBFREDO6_Dir_43" and a file called "LibFredo6.rb" If you installed the current version you shouldn't have "LibFredo6-34" at all.
                                        • T
                                          tspco
                                          Well it was there, not now now it just shows 4.3
                                          • gullfoG
                                            gullfo
                                            not sure if it is the LibFredo 4.3b or the BezierSpline 1.4f plugin, but if the LibFredo 4.3b is enabled, the BezierSpline 1.4f does not work. i get a Ruby console error for line 592 cannot convert nil to float.
                                            Error: #<TypeError: no implicit conversion to float from nil>
                                            C:/Program Files/Google/Google SketchUp 8/Plugins/BZ_Dir_14/bezierspline_main.rb:592:in -' C:/Program Files/Google/Google SketchUp 8/Plugins/BZ_Dir_14/bezierspline_main.rb:592:in onMouseMove'
                                            Fredo tools works regardless of BezierSplines being enabled or not.
                                            NOTE: I only encountered this error since updating to 4.3b and prior to that it was working correctly.
                                            Glenn
                                            http://www.runnel.com
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 112
                                            • 113
                                            • 17 / 113
