    ๐Ÿ”Œ Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
    [Plugin]Hole on Solid tool v1.6.3 upadate Jan 09, 2012
    134 Posts 43 Posters 86.3k Views 43 Watching
      Or they way he's using it. Not possible to know until we have further information to what exactly doesn't work.
      • irwanwrI Offline
        irwanwr
        it works for me
          tak2hata
          I update this to v1.62.
          Add new function: Multiple hole punching.
          Enjoy!
          @durrroy said:
          I could never get it to work
          Hi,durrroy.
          The face and solid must be in same Group or Component or Model.
          And ComponentInstance for hole must have hole option.
          It is rule of this plugin.
          If this is not solution for your trouble,Please show ruby console from 'menu' -> 'Window' -> 'Ruby console'
          And work some with this plugin,the error message will show when error is happened.
          or Download the example.skp that Dave R uploaded in this topics.and test it.
          Please reply the result.
          Thanks.
          by TAK2HATA
            cocotier
            it doesn't work
              @cocotier said:
              it doesn't work
              Sorry but your post goes into the 'most useless' category !
              Please explain 'how' it doesn't work...
              Any Error messages ?
              Doesn't it do what you expect ?
              If you have the Ruby Console open are there any messages etc etc...
              Does your PC explode... or what ?
              Help us to help you ๐Ÿ˜’
              • simon le bonS Offline
                simon le bon
                Update in Jan 03,2012
                :Add new function,Punching multiple holes.
                It would be very interesting to drill holes by lot in case of large number of windows for exemple...
                this new enhancement is working very fine ๐Ÿ‘
                http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/HoleonSolidtool_tak2hata_010.jpg
                Congratulations dear tak2hata ๐Ÿ‘ ๐Ÿ‘ You've mastered herein a pretty good tool โ˜€
                @cocotier
                Please remember that
                This tool is intended to make holes on "solids" -> closed volumes set as group or component. This is not completely true since the following enhancement:
                Update in Dec 14 ,2011:
                Hole on unoccluded faces group(Tentative)
                The group or component walls we want to pierce don't have to be solid anymore ๐Ÿ‘
                simon
                • irwanwrI Offline
                  irwanwr
                  ๐Ÿ‘ the new feature works well for me too. thank you.
                    boilingsnow
                    Hi,tak2hata.
                    Your Multi Hole Tool is very interesting and useful. But with Multi Hole I can only make holes into a solid using faces as definition of the form for the holes, with a component or group it fails to make holes into any solid...I can see in your video that you are using a group or component. Can you tell me how you can make it?
                      jorge2011
                      excellent and thank you very much.
                      Two requests for future versions.
                      You can add a function: projecting faces in a solid?
                      You can add a function to hole or project a face, in multiple solid?
                        tak2hata
                        Hi,I did not change title of topic in Jan 03,2012.I modeified title.
                        Hi,boilingsnow.
                        hole of component
                        The componet for hole must have cut openning option.
                        Reference about component here. http://support.google.com/sketchup/bin/answer.py?hl=en&answer=114526
                        Hi,jorge2011.
                        I will consider your Proposal.
                        Thanks.
                        by TAK2HATA
                        • guanjinG Offline
                          guanjin
                          Creating the Component Selection cutting openings, holes can not be achieved? ? ?
                            tak2hata
                            [attachment=1:1jixhd7j]<!-- ia1 -->rrrrrrrr.gif<!-- ia1 -->[/attachment:1jixhd7j]
                            Hi,XIAOLONG.
                            Outline for cut openning must be drawn on X-Y Plane( Red and Green axis).
                            When the component is already existed,You rotate axis in that component.
                            And outline must be placed in the root of that component.
                            [attachment=0:1jixhd7j]<!-- ia0 -->outline_must_be_on_xyplane.jpg<!-- ia0 -->[/attachment:1jixhd7j]
                            Watch for reference to create cut openning option.
                            http://youtu.be/0g6irIj---w
                            [flash=640,480:1jixhd7j]http://www.youtube.com/v/0g6irIj---w[/flash:1jixhd7j]
                            Thanks.
                            outline must be on xy-plane
                            by TAK2HATA
                            • guanjinG Offline
                              guanjin
                              @tak2hata said:
                              [attachment=2:24c8pe63]<!-- ia2 -->rrrrrrrr.gif<!-- ia2 -->[/attachment:24c8pe63]
                              Hi,XIAOLONG.
                              [attachment=1:24c8pe63]<!-- ia1 -->outline_must_be_on_xyplane.jpg<!-- ia1 -->[/attachment:24c8pe63]
                              Thanks.
                              Thank you! Have learned to see demo:
                              [attachment=0:24c8pe63]<!-- ia0 -->LLLLL.gif<!-- ia0 -->[/attachment:24c8pe63]
                              ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘
                              • charly2008C Offline
                                charly2008
                                Hello tak2hata,
                                Your tool is impressive. I've done some experiments with it. It works really well. One question I have is it possible a component that contains some single solids to cut completely into the wall.
                                Charly
                                example001-1.skp
                                  tak2hata
                                  Hi,everyone.
                                  I update in jan 09,2012.
                                  Its version is 1.63.
                                  Bug fix.The hole from polygon mades smoothed side faces. it's improved.
                                  I found from dave's post,and irwanwr's message.
                                  Thanks. Dave and irwanwr.
                                  Hi,Charly2008.
                                  That problem is not solved yet.
                                  I will improve it,when I find the solution in future.
                                  Thanks.
                                  by TAK2HATA
                                  • irwanwrI Offline
                                    irwanwr
                                    hi tak2hata,
                                    ๐Ÿ˜ thank you thank you very much for your generosity
                                      charly2008
                                      @tak2hata said:
                                      Hi,Charly2008.
                                      Thanks.
                                      thank you very much for your answer
                                      Charly
                                        jorge2011
                                        Thank you. Excellency update.
                                        Only a small error.
                                        It does not work the command "Ctrl + Z". deleted one by one holes
                                        • U Offline
                                          urs0815
                                          Great plug in ๐Ÿ‘
                                          an option to set the depth of the hole would be great...
                                            jorge2011
                                            tak2hata
                                            See litle fix.you can fix that?
                                            Thank you very much
                                            01.skp
                                            • 2 / 7
